Fibaro Walli Switch & Dimmer
terrorsource
Received a few Fibaro Walli Switches and Dimmers a couple of days ago.
Connected 1 Switch in the outlet and connected it to Domoticz.
It is not fully recognized.
Description:
Unknown: id=010f Unknown: type=1b01, id=1000+
It's creating 11 devices, which looks good to me.
01 - Switch
02 - Instance 1: System
03 - Instance 1: Power Management
04 - Instance 2: Switch
05 - Instance 3: Switch
06 - kWh Meter
07 - Unknown
08 - kWh Meter
09 - Unknown
10 - kWh Meter
11 - Unknown
Will update this topic when i know more about the Walli Dimmer.
Description:
01 - Switch
06 - kWh Meter
07 - Unknown
08 - kWh Meter
09 - Unknown
10 - kWh Meter
11 - Unknown
Snowtiger
Re: Fibaro Walli Switch & Dimmer
Domoticz uses Open Zwave to communicate with Zwave devices. Devices are added by the Community. To see if your device is available check https://github.com/OpenZWave/open-zwave ... ng-Devices
terrorsource
Device is not in OpenZwave yet.Snowtiger wrote: Friday 05 July 2019 23:54 Domoticz uses Open Zwave to communicate with Zwave devices. Devices are added by the Community. To see if your device is available check https://github.com/OpenZWave/open-zwave ... ng-Devices
Starting to build the config for the Switch but it's not easy and takes some time
terrorsource
Fibaro Walli Double Switch is added to the OpenZWave github PR's.
https://github.com/OpenZWave/open-zwave/pull/1869
Snowtiger
Check commit https://github.com/domoticz/domoticz/co ... b79d3dae47terrorsource wrote:Fibaro Walli Double Switch is added to the OpenZWave github PR's.
terrorsource
Thanks. Did you merge them yourself?Snowtiger wrote: Saturday 13 July 2019 14:15Check commit https://github.com/domoticz/domoticz/co ... b79d3dae47terrorsource wrote:Fibaro Walli Double Switch is added to the OpenZWave github PR's.
https://github.com/OpenZWave/open-zwave/pull/1869![]()
I've set up a new Pi with Domoticz. Added the Walli Double Switch but not fully working
Switch2 device is missing
Switch3 device is missing
I cannot press "Apply configuration for this device" button
Config 3001 shows up (not in the config xml)
3001. Instance 1: Protection:
- Unprotected
- Protection by Sequence
- No Operation Possible
Protect a device against unintentional control
Snowtiger
I did not merge them - I just wanted to point you to this change
I assume you now run the latest Beta? A code revert has been done in 11005, check this beta to see if helps.
See Github - https://github.com/domoticz/domoticz/issues/3530
Text - If your node has multiple relays, but only shows one in ozwcp or only one works in Domoticz: the problem has been reported to OpenZWave and is under investigation.
terrorsource
Saw that after my post. I''m now back on the latest stable and waiting for the issues to be solved before i go to a new beta again.Snowtiger wrote: Sunday 14 July 2019 13:09 I did not merge them - I just wanted to point you to this change
Snowtiger
I'm on a stable Bèta
