Trigger depending of time AND device
Posted: Saturday 29 June 2019 8:28
by usky73
Hi all
I am updating all my scripts in DzVent. And this is really a great improvement.
Then I want more !
Is there a way to link 2 trigger conditions : time AND devices instead of time OR devices.
I want my script to run from sunset to morning and only if one device (motion sensor) state change.
At the moment I have only a trigger on the devices but I dont't want to run the script in day time.
Any idea ?
Re: Trigger depending of time AND device
Posted: Saturday 29 June 2019 8:57
by Geuvert
Hi Usky,
Personally I have a timer script running in which I use an if statement to check the state of a switch.
My (simplified) code looks like this:
active = true,
timer = {
'every minute at 14:00-22:16',
execute = function(domoticz, device, switch)
local I2 = domoticz.devices('Qubino Dimmer I2')
if (I2.state == 'On') then
light.switchOn()
I removed some of the code, so not sure is this runs as is.
If this is not what you're looking for I believe you can add a device after the time. Not sure how that works though.
It should look something like:
active = true,
timer = {
devices = {
'Switch 1'
Though I am not sure whether this triggers if both conditions are met (time and device) or if either one is met.
Hope this helps.
Geuvert
Posted: Saturday 29 June 2019 9:45
by waaren
usky73 wrote: Saturday 29 June 2019 8:28
Hi all
Then I want more !
Any idea ?
return
on =
devices = { ['myMotionSensor'] = { 'at nighttime' } }
execute = function(domoticz,item)
if (item.state == 'On') then
domoticz.log('Sensor ' .. item.name .. ' was turned on.',domoticz.LOG_FORCE)
Look
here for more examples
Posted: Saturday 29 June 2019 13:29
by usky73
Thanks a lot to all.
Waaren you got my point. That's exactly what I was looking for. I missed that point in the doc.
Posted: Saturday 29 June 2019 13:44
by usky73
for testing purpose I have tested that :
devices = { ['Hue motion sensor salon'] = {'at civildaytime'} }
but it is not working, any idea ?
Posted: Saturday 29 June 2019 20:00
by usky73
Just did test and it works with other timer parameters but not with 'at civildaytime'
For this value should work for any day time. But it is not the case. Am I correct ?
Posted: Sunday 30 June 2019 11:34
by waaren
usky73 wrote: Saturday 29 June 2019 20:00
You are correct. Nice catch and thanks for reporting. Fixed in next beta.
Re: Trigger depending of time AND device [Solved]
Posted: Sunday 30 June 2019 18:35
by usky73
