Trigger depending of time AND device  [Solved]
usky73
Domoticz version: 2021.1
Post by usky73 »
Hi all
I am updating all my scripts in DzVent. And this is really a great improvement.
Then I want more !
Is there a way to link 2 trigger conditions : time AND devices instead of time OR devices.
I want my script to run from sunset to morning and only if one device (motion sensor) state change.
At the moment I have only a trigger on the devices but I dont't want to run the script in day time.
Any idea ?
Geuvert
Domoticz version: 4.10717
Re: Trigger depending of time AND device
Post by Geuvert »
Hi Usky,
Personally I have a timer script running in which I use an if statement to check the state of a switch.
My (simplified) code looks like this:
    active = true,
		timer =	{
			'every minute at 14:00-22:16',
	execute = function(domoticz, device, switch)
	    local I2    = domoticz.devices('Qubino Dimmer I2')
        if (I2.state == 'On') then
            light.switchOn()
I removed some of the code, so not sure is this runs as is.
If this is not what you're looking for I believe you can add a device after the time. Not sure how that works though.
It should look something like:
    active = true,
		timer =	{
		devices = {
			'Switch 1'
Though I am not sure whether this triggers if both conditions are met (time and device) or if either one is met.
Hope this helps.
Geuvert
usky73 wrote: Saturday 29 June 2019 8:28 Hi all
Then I want more !
Any idea ?
return
   on =
      devices = { ['myMotionSensor'] = { 'at nighttime' } }
   execute = function(domoticz,item)
      if (item.state == 'On') then
         domoticz.log('Sensor ' .. item.name .. ' was turned on.',domoticz.LOG_FORCE)
Look here for more examples
usky73
Post by usky73 »
Thanks a lot to all.
Waaren you got my point. That's exactly what I was looking for. I missed that point in the doc.
usky73
Post by usky73 »
for testing purpose I have tested that :
		devices = { ['Hue motion sensor salon'] = {'at civildaytime'} }
but it is not working, any idea ?
usky73
Post by usky73 »
Just did test and it works with other timer parameters but not with 'at civildaytime'
For this value should work for any day time. But it is not the case. Am I correct ?
usky73 wrote: Saturday 29 June 2019 20:00 Just did test and it works with other timer parameters but not with 'at civildaytime'
You are correct. Nice catch and thanks for reporting. Fixed in next beta.
usky73
Re: Trigger depending of time AND device  [Solved]
Post by usky73 »
