dzVents script Toon for domoticz  [Solved]
nf999
Domoticz version: stable
Post by nf999 »
Note: This is for a regular paid Toon & Eneco subscription, won't work for a hacked Toon.
I created a dzVents script for Toon. Just sharing here. It's the basic setup pulling the status info (p1 info, gasusage and thermostatinfo) from the toon api, and adding functionality to switch on/off autoprogram or scene. Should be enough for most Toon users.
-- api calls based on toonapilib & Toon api documentation
-- Toon api credentials required via 'https://developer.toon.eu'
-- only using Toon's 1st agreement, fine if you have 1 Toon
-- only thermostat, p1 meter and gass supported
-- no hue, smokedetectors or others (I don't have those devices ;-))
Create the required devices as in the dzVents code below, add this script in the setup -> more options -> events section, add Toon api credentials and Eneco login and it should work.
Currently testing, let me know if you have strange results
I'm not connected to either Toon or Eneco, but please spread the timing: in the timer section, to avoid all calls end up at the same time at the Toon api so we can keep using this functionality. Note that in order to avoid gaps you need to pick minutes *:1 to *:4 so nu *:0 or *:5. It will work but will give gaps in the power usage chart.
-- Toon for domoticz via dzVents
-- https://www.domoticz.com/forum/viewtopic.php?f=59&t=28498
-- 2019-06-10 intial setup, authentication and get status
-- 2019-06-11 added update for programState and scenes
-- 2019-06-15 added extra error handling and logging
-- only using Toons 1st agreement, fine if you have 1 Toon
-- create Toon api account at https://developer.toon.eu
local        client_id="enter your api.toon.eu client_id"
local        client_secret="enter your api.toon.eu client_secret"
-- enter Eneco credentials below (if not Eneco, you need to replace eneco below)
local        username="enter your Eneco username"
local        password="enter your Eneco password"
-- create devices in domoticz
-- create new hardware dummy device TOON and add virtual devices from there
-- at start the powerUsage will spike; select the spike click shift-leftmouse
-- to delete the spike ;-)
local toonThermostat = "Toon thermostat"    -- type=Thermostat - SetPoint
local toonTemperature = "Toon temperature"  -- type=Temp - LacrosseTX3
local toonScenes = "Toon scenes"            -- type=Light/switch - selector switch
local toonProgram = "Toon program"          -- type=Light/switch - selector switch
local toonModulation = "Toon modulation level" -- type=percentage
local toonBurnerInfo = "Toon burner info"   -- type=Light/switch - selector switch
local toonBoilerError = "Toon boiler state" -- type=text
local toonNextProgram = "Toon next program" -- type=text
local toonGasUsage = "Toon gas"             -- type=gas
local toonSmartMeter = "Toon smart meter"   -- type=p1 smart meter
local scenesText = { 'Comfort', 'Home', 'Sleep', 'Away', 'Holiday' }
local burnerInfo = { 'Burner off', 'Burner on', 'Hot Water', 'Preheat' }
    logging = {
            -- level = domoticz.LOG_DEBUG -- comment when not in dev
        -- comment timer and create testButton for development
        -- timer manually specified to avoid 5min cutoffs (0) in charts
        -- and add spreading, use *:1 to *:4 as starting point
        timer = { 'at *:3', 'at *:8', 'at *:13', 'at *:18', 'at *:23', 'at *:28', 'at *:33',
            'at *:38', 'at *:43', 'at *:48', 'at *:53', 'at *:58' },
        devices = { toonProgram, toonScenes }, -- toonThermostat removed, no updateSetPoint().silent()
        httpResponses = { 'toon_getToken', 'toon_getAgreements', 'toon_getStatus', 'toon_setThermostat' },
    data = {
        'access_token',
        'access_token_timestamp',
        'access_token_expires_in',
        'refresh_token',
        'agreementId',
        'displayCommonName',
        'action', 'actionData'
    execute = function(dz, item)
        -- execute command to get site
        function os.capture(cmd)
            local s = ""
            local f = assert(io.popen(cmd, 'r'))
            s = assert(f:read('*a'))
            f:close()
            return s
        function get_access_token()
            dz.log('in get_access_token', dz.LOG_DEBUG)
            -- get code, using curl because of the redirect
            local command = "curl --max-time 5 -i -X POST " ..
            "-H 'Host: api.toon.eu' " ..
            "-H 'Content-Type: application/x-www-form-urlencoded' " ..
            "-d 'username=" .. username .. "&password=" .. password ..
            "&tenant_id=eneco&response_type=code&client_id=" .. client_id ..
            "' 'https://api.toon.eu/authorize/legacy'"
            local tmp = os.capture(command)
            local code=string.match(tmp, '?code=(.*)&scope')
            -- get tokens
            dz.openURL({
                url = 'https://api.toon.eu/token',
                method = 'POST',
                callback = 'toon_getToken',
                headers = { ['Content-Type']='application/x-www-form-urlencoded' },
                postData = "client_id=" .. client_id ..
                "&client_secret=" .. client_secret ..
                "&code=" .. code .. "&grant_type=authorization_code"
        function refresh_token()
            dz.log('in refresh_token',dz.LOG_DEBUG)
            dz.openURL({
                method = 'POST',
                "&refresh_token=" .. dz.data.refresh_token .. "&grant_type=refresh_token"
        function get_agreements()
            dz.log('in get_agreements', dz.LOG_DEBUG)
            dz.openURL({
                url='https://api.toon.eu/toon/v3/agreements',
                method='GET',
                callback='toon_getAgreements',
                headers = {
                    Authorization = 'Bearer ' .. dz.data.access_token,
                    ['Content-Type'] = 'application/json',
                    ['Cache-Control'] = 'no-cache'
        function get_status()
            dz.log('in get_status', dz.LOG_DEBUG)
            dz.openURL({
                url='https://api.toon.eu/toon/v3/' .. dz.data.agreementId .. '/status',
                method='GET',
                callback='toon_getStatus',
                headers = {
                    ['Cache-Control'] = 'no-cache',
                    ['X-Agreement-ID'] = dz.data.agreementId,
                    ['X-Common-Name'] = dz.data.displayCommonName
        function set_thermostat(pd)
            dz.log('in set_thermostat: ' .. dz.utils.toJSON(pd), dz.LOG_DEBUG)
            -- adjust json
            if (pd.programState) then
                pd['activeState'] = dz.utils.round(dz.devices(toonScenes).level/10)
                pd['currentSetpoint'] = 0 -- not relevant
            elseif (pd.activeState) then
                pd['programState'] = 2
                dz.devices(toonProgram).switchSelector(20).silent()
            elseif (pd.currentSetpoint) then
                pd['activeState'] = -1
                -- something strange
                dz.log('invalid input for set_thermostat', dz.LOG_ERROR)
                return
            dz.log('set_thermostat json: ' .. dz.utils.toJSON(pd), dz.LOG_DEBUG)
            -- removed, no working put in domoticz??
            -- dz.openURL({
            --     url = 'https://api.toon.eu/toon/v3/' .. dz.data.agreementId .. '/thermostat',
            --     method = 'POST',
            --     callback = 'toon_setThermostat',
            --     postData = pd,
            --     headers = {
            --         Authorization = 'Bearer ' .. dz.data.access_token,
            --         ['Content-Type'] = 'application/json',
            --         ['Cache-Control'] = 'no-cache',
            --         ['X-Agreement-ID'] = dz.data.agreementId,
            --         ['X-Common-Name'] = dz.data.displayCommonName
            local command = "curl --max-time 5 -i -s -X PUT " ..
            "-H 'Authorization: Bearer " .. dz.data.access_token .. "' " ..
            "-H 'Content-Type: application/json' " ..
            "-H 'Cache-Control:  no-cache' " ..
            "-H 'X-Agreement-ID: " .. dz.data.agreementId .. "' " ..
            "-H 'X-Common-Name: " .. dz.data.displayCommonName .. "' " ..
            "-d '" .. dz.utils.toJSON(pd) .. "' " ..
            "'https://api.toon.eu/toon/v3/" .. dz.data.agreementId .. "/thermostat'"
            dz.log('command: ' .. command, dz.LOG_DEBUG)
            dz.log(tmp, dz.LOG_DEBUG)
            local status=string.match(tmp, "HTTP/1.1 (.-)\r\n")
            if (status ~= "200 ") then -- don't forget the space
                dz.log('set_thermostat failed: [' .. status .. ']', dz.LOG_ERROR)
                dz.log('set_thermostat success: [' .. status .. ']', dz.LOG_INFO)
        function next_action()
            dz.log('in next_action', dz.LOG_DEBUG)
            if (dz.data.action == "get_status") then
                get_status()
            elseif (dz.data.action == "set_thermostat") then
                set_thermostat(dz.data.actionData)
                dz.log('next_action missing: ' .. dz.data.action, dz.LOG_ERROR)
        function get_thermostatInfo(ti)
            -- ti == item.json.thermostatInfo
            local t1, t2
            -- toon temp
            t1 = ti.currentDisplayTemp/100
            t2 = dz.devices(toonTemperature).temperature
            if ( t1 ~= t2) then
                dz.devices(toonTemperature).updateTemperature(t1)
            -- toon setpoint
            t1 = ti.currentSetpoint/100
            -- t2 = dz.devices(toonThermostat).setPoint
            -- if (t1 ~= t2) then
                dz.log('updating toonThermostat setPoint', dz.LOG_DEBUG)
                dz.devices(toonThermostat).updateSetPoint(t1).silent()
            -- end
            -- toon programstate
            t1 = ti.programState*10
            t2 = dz.devices(toonProgram).level
            if (t1 ~= t2) then
                dz.devices(toonProgram).switchSelector(t1).silent()
            -- toon scene
            t1 = ti.activeState*10
            t2 = dz.devices(toonScenes).level
            if (t1 ~= t2) then
                dz.devices(toonScenes).switchSelector(t1).silent()
            -- toon modulation level
            t1 = ti.currentModulationLevel
            t2 = dz.devices(toonModulation).percentage
            if (t1 ~= t2) then
                dz.devices(toonModulation).updatePercentage(t1)
            -- toon burnerinfo
            t1 = ti.burnerInfo*10
            t2 = dz.devices(toonBurnerInfo).level
            if (t1 ~= t2) then
                dz.devices(toonBurnerInfo).switchSelector(t1)
            -- boiler errors
            t1 = "no errors"
            t2 = dz.devices(toonBoilerError).text
            if (ti.hasBoilerFault ~= 0) then
                t1 = 'error: ' .. tostring(item.json.thermostatInfo.errorFound)
            if (t1 ~= t2) then
                dz.devices(toonBoilerError).updateText(t1)
                dz.notify('Boiler error', t1, dz.PRIORITY_HIGH, dz.SOUND_FALLING)
            -- nextProgram
            t1 = "Toon autoprogram not active"
            t2 = dz.devices(toonNextProgram).text
            if (ti.nextProgram ~= -1) then
                local d = os.date("%H:%M", item.json.thermostatInfo.nextTime)
                t1 = 'at ' .. d .. ' set to ' .. scenesText[tonumber(item.json.thermostatInfo.nextState+1)]
                .. ' ' .. item.json.thermostatInfo.nextSetpoint/100 ..  '°C'
            if (t1 ~= t2) then
                dz.devices(toonNextProgram).updateText(t1)
        -- control script
        local Time = require('Time')
        local now = Time()
        if (item.isTimer or item.isDevice) then
            -- set action from Device
            if (item.isTimer) then
                dz.log('Timer event was triggered by ' .. item.trigger, dz.LOG_INFO)
                dz.data.action="get_status"
                dz.data.actionData=nil
            elseif (item.isDevice) then
                dz.log('Device event was triggered by ' .. item.name, dz.LOG_INFO)
                if(item.name == toonProgram) then
                    dz.log('update from toonProgram device', dz.LOG_INFO)
                    dz.data.action = "set_thermostat"
                    dz.data.actionData = { programState = math.floor(item.level/10) }
                elseif (item.name == toonScenes) then
                    dz.log('update from toonScenes device', dz.LOG_INFO)
                    dz.data.actionData = { activeState = math.floor(item.level/10) }
                elseif (item.name == toonThermostat) then
                    dz.log('update from toonThermostat device', dz.LOG_INFO)
                    dz.data.actionData = { currentSetpoint = item.setPoint*100 }
                dz.log('update unknown', dz.LOG_ERROR)
                return
            -- debug info
            if (dz.data.access_token ~= nil) then
                dz.log('access_token: ' .. dz.data.access_token, dz.LOG_DEBUG)
            if (dz.data.access_token_timestamp ~= nil) then
                dz.log('access_token_timestamp: ' .. tostring(dz.data.access_token_timestamp.dDate), dz.LOG_DEBUG)
                dz.log('deltaT: ' .. tostring(now.compare(dz.data.access_token_timestamp).secs), dz.LOG_DEBUG)
                dz.log('access_token_expires_in: ' .. dz.data.access_token_expires_in, dz.LOG_DEBUG)
                dz.log('result: ' .. tostring(now.compare(dz.data.access_token_timestamp).secs>tonumber(dz.data.access_token_expires_in)), dz.LOG_DEBUG)
            if (dz.data.refresh_token ~= nil) then
                dz.log('refresh_token: ' .. dz.data.refresh_token, dz.LOG_DEBUG)
            -- poll toon data
            -- compare timestamps
            if (dz.data.access_token == nil or
                dz.data.access_token_timestamp == nil or
                now.compare(dz.data.access_token_timestamp).secs>tonumber(dz.data.access_token_expires_in)) then
                dz.log('need to get new access_token', dz.LOG_INFO)
                    dz.log('getting new access_token via refresh_token', dz.LOG_DEBUG)
                    refresh_token()
                    dz.log('getting new accesst_token via get_access_token', dz.LOG_DEBUG)
                    get_access_token()
            elseif (dz.data.agreementId == nil or dz.data.displayCommonName == nil) then
                dz.log('need to get agreements', dz.LOG_INFO)
                get_agreements()
                dz.log('all available, next_action', dz.LOG_DEBUG)
                next_action()
        elseif (item.isHTTPResponse) then
            -- debug info
            dz.log('HTTPResponse event was triggered by ' .. item.trigger, dz.LOG_INFO)
            -- if no proper response report and stop
            if (not item.ok or item.statusCode ~= 200) then
                dz.log('response NOK, bailing out; ' .. tostring(item.statusCode)
                    .. ": " .. item.statusText, dz.LOG_ERROR)
                dz.log('responseOK: ' .. tostring(item.ok), dz.LOG_DEBUG)
                dz.log('statusCode: ' .. item.statusCode, dz.LOG_DEBUG)
                dz.log('statusText: ' .. item.statusText, dz.LOG_DEBUG)
                if (item.isJSON) then
                    dz.log('json data:', dz.LOG_DEBUG)
                    dz.log(dz.utils.toJSON(item.json), dz.LOG_DEBUG)
                elseif (item.data) then
                    dz.log('non-json data:', dz.LOG_DEBUG)
                    dz.log(item.data, dz.LOG_DEBUG)
                return
            -- handle async http response
            if (item.trigger == 'toon_setThermostat') then
                -- nothing here
            elseif (item.trigger == 'toon_getToken'
                and item.json.access_token) then
                dz.data.access_token = item.json.access_token
                dz.data.access_token_expires_in = item.json.expires_in
                dz.data.access_token_timestamp = now
                dz.data.refresh_token = item.json.refresh_token
                -- skip getting agreementId if already available
                    get_agreements()
                    next_action()
            elseif (item.trigger == "toon_getAgreements" and
                item.json[1].agreementId) then
                dz.data.agreementId = item.json[1].agreementId
                dz.data.displayCommonName = item.json[1].displayCommonName
                dz.log('agreementId:' .. dz.data.agreementId, dz.LOG_DEBUG)
                dz.log('displayCommonName: ' .. dz.data.displayCommonName, dz.LOG_DEBUG)
                next_action()
            elseif (item.trigger == "toon_getStatus") then
                dz.log('callback get_status', dz.LOG_DEBUG)
                -- thermostatInfo
                if (item.json.thermostatInfo) then
                    get_thermostatInfo(item.json.thermostatInfo)
                    dz.log('thermostatInfo missing in response', dz.LOG_ERROR)
                    dz.log(dz.utils.toJSON(item.json), dz.LOG_INFO)
                -- gasUsage
                if (item.json.gasUsage) then
                    dz.devices(toonGasUsage).updateGas(item.json.gasUsage.dayUsage)
                    dz.log('gasUsage missing in response', dz.LOG_ERROR)
                -- powerUsage
                if (item.json.powerUsage) then
                    dz.log('p1: ' ..  item.json.powerUsage.meterReadingLow .. ', ' ..
                        item.json.powerUsage.meterReading .. ', ' ..
                        item.json.powerUsage.meterReadingLowProdu .. ', ' ..
                        item.json.powerUsage.meterReadingProdu .. ', ' ..
                        item.json.powerUsage.value .. ', ' ..
                        item.json.powerUsage.valueProduced, dz.LOG_INFO)
                    dz.devices(toonSmartMeter).updateP1(
                        item.json.powerUsage.meterReadingLow,
                        item.json.powerUsage.meterReading, item.json.powerUsage.meterReadingLowProdu,
                        item.json.powerUsage.meterReadingProdu, item.json.powerUsage.value,
                        item.json.powerUsage.valueProduced)
                    dz.log('powerUsage missing in response', dz.LOG_ERROR)
                dz.log('unknwon trigger HTTPResponse: ' .. item.trigger, dz.LOG_ERROR)
passion75
Re: dzVents script Toon for domoticz
Post by passion75 »
I am a newbie in scripting....i’m having a Windows install.. do I need some extra things to install...
Is there a Manual of it
passion75 wrote: Wednesday 26 June 2019 21:31 I am a newbie in scripting....i’m having a Windows install.. do I need some extra things to install...
No need to install anything extra if you use dzVents, Lua or Blockly. For Python or PHP some additional software needs to be installed.
dzVents is documented in this wiki
When not yet familiar with dzVents please start with reading Get started before implementing. Special attention please for
"In Domoticz go to Setup > Settings > Other and in the section EventSystem make sure the checkbox 'dzVents disabled' is not checked. Also make sure that in the Security section in the settings you allow 127.0.0.1 to not need a password. dzVents uses that port to send certain commands to Domoticz. Finally make sure you have set your current location in Setup > Settings > System > Location, otherwise there is no way to determine nighttime/daytime state."
nf999
Post by nf999 »
yep, what waaren says. I prefer to not have to install all kinds of extra stuff ;-) So this script should be working out of the box with domoticz with 1 exception that curl is required, since not all options for http calls are covered by dzVents.openUrl
fyi I use curl to avoid redirects (dzVents.openURL follows redirects automatically) and to PUT a call (PUT method does not work in domoticz) Especially the redirect avoidance is critical to be able to login.
LoudRex
Error dzVents with Toon code
Post by LoudRex »
Hello all,
I am having trouble using domoticz and connecting and retreiving data using a non-Rooted Toon with Eneco-subscription.
I've imported this code and replaced it with most of my login settings (now anonamized).
local        client_id="****"
local        client_secret="****"
local        username="***"
local        password="***"
    logging = {
    data = {
        'access_token',
        'refresh_token',
        'agreementId',
            local s = ""
            f:close()
            return s
            -- get tokens
            dz.openURL({
                method = 'POST',
            dz.openURL({
                method = 'POST',
            dz.openURL({
                method='GET',
                headers = {
            dz.openURL({
                method='GET',
                headers = {
            -- adjust json
                return
            -- dz.openURL({
            --     method = 'POST',
            --     postData = pd,
            --     headers = {
                get_status()
            local t1, t2
            -- toon temp
            if ( t1 ~= t2) then
            -- toon setpoint
            -- end
            if (t1 ~= t2) then
            -- toon scene
            if (t1 ~= t2) then
            if (t1 ~= t2) then
            -- toon burnerinfo
            if (t1 ~= t2) then
            -- boiler errors
            t1 = "no errors"
            if (t1 ~= t2) then
            -- nextProgram
            if (t1 ~= t2) then
        -- control script
        local now = Time()
                return
            -- debug info
            -- poll toon data
                    refresh_token()
                    get_access_token()
                get_agreements()
                next_action()
            -- debug info
                return
                -- nothing here
                    get_agreements()
                    next_action()
                next_action()
                -- thermostatInfo
                -- gasUsage
                -- powerUsage
Everything is working fine (except for the counters) but in the Domoticz log, everything looks ok.
The only error in the log I get from this script is:
2021-01-20 04:03:01.053 Error: dzVents: Error: (3.0.2) An error occurred when calling event handler Toon via dzVents
2021-01-20 04:03:01.054 Error: dzVents: Error: (3.0.2) ...g/scripts/dzVents/generated_scripts/Toon via dzVents.lua:94: attempt to concatenate a nil value (local 'code')
As I am not a great scripter yet, I do not know how to solve this error line and let the counters do their job.
Because the gasUsage and powerUsage counters are still after a few minutes on 0 watt and 0 cubic metre...
I hope I posted my question right in this category.
Many thanks for helping me out.
Kind Regards,
LoudRex
PS. I have these two on my devices tab, don't know if they are correctly set-up...
pdejong1977
Post by pdejong1977 »
I have the same problem as LoudRex. Until November 2020 the script worked fine but since then I get the same error and no Toon values in my Domoticz. Does anyone have an idea for the solution?
janz1961
Post by janz1961 »
I haven't done much debugging yet, but just to keep the thread alive: I'm also getting al lot of:
2022-01-03 19:33:00.627 Error: dzVents: Error: (3.1.7) An error occurred when calling event handler TOON
2022-01-03 19:33:00.627 Error: dzVents: Error: (3.1.7) ...x86)\Domoticz\scripts\dzVents\generated_scripts/TOON.lua:94: attempt to concatenate a nil value (local 'code')
What I'm curious about is how it works with the callback URL. This seems to indicate that Domoticz needs to be accessible from the Internet. Now in my case it is, but it requires authentication. And if I look in my firewall logs, I see
2022:01:03-19:18:40 sophos httpd[7106]: [url_hardening:error] [pid 7106:tid 4071074672] [client 192.241.211.78:45032] Hostname in HTTP request (My IP Address) does not match the server name (<my FQDN>)
Obviously, it is the FQDN that I specified for the TOON API, not the IP
pdejong1977
Does someone have an idea for a solution for this?
