error with dzventz script  [SOLVED]
mcmikev
Post by mcmikev »
Running latest (from source) domoticz version 4.10926 and have a script that works with a rfxcom device.
The script is this
    active = true,
        devices = {
            'KaKu-GangBgg'
	logging = {
    level = domoticz.LOG_INFO, --log level can be domoticz.LOG_INFO, domoticz.LOG_MODULE_EXEC_INFO, domoticz.LOG_DEBUG or domoticz.LOG_ERROR
    marker = "KaKu-GangBgg" --info to see what device did what in the log
        if (device.name == 'KaKu-GangBgg' and device.state == 'On') then
	    domoticz.devices('DIM-GangkastR-Boven').dimTo(25)
	    domoticz.devices('DIM-GangkastG-Onder').dimTo(25)
	    domoticz.devices('Gangkast').switchSelector(20) end
        if (device.name == 'KaKu-GangBgg' and device.state == 'Off') then
	    domoticz.devices('DIM-GangkastR-Boven').dimTo(0)
	    domoticz.devices('DIM-GangkastG-Onder').dimTo(0)
	    domoticz.devices('Gangkast').switchSelector(Off) end
The error I get is only when I turn the switch off. With turining ON there is no issue at all. The light goes off and on as expected but there is this error :
2019-06-23 14:04:38.347 Error: dzVents: Error: (2.4.23) KaKu-GangBgg: An error occurred when calling event handler 2-Gang-KakuTrap
2019-06-23 14:04:38.347 Error: dzVents: Error: (2.4.23) KaKu-GangBgg: ...moticz/dzVents/runtime/device-adapters/switch_device.lua:118: attempt to perform arithmetic on local 'val' (a nil value)
What can be the cause of this error?
Re: error with dzventz script
mcmikev wrote: Sunday 23 June 2019 14:06 The script is this
What can be the cause of the error?
The error is in the word Off
If you want to use it as a string then it is 'Off'. Other option is to replace it with 0.
Lua is interpreting the Off as variable but as this is not set, it is nil
mcmikev
Re: error with dzventz script  [SOLVED]
Post by mcmikev »
Replaced the Off with 0 (zero) as level and the error is gone.
Thanks!!
