HansieNL
Post
by HansieNL »
I got a text block with Buienradar info.
blocks[345] = {} //Buienradar (text)
blocks[345]['title'] = 'Buienradar';
blocks[345]['switch'] = true;
blocks[345]['width'] = 12;
blocks[345]['image'] = '../custom/img/rain-off.png';
function afterGetDevices(){
// Buienradar
if (alldevices[345].Data == 'Voorlopig droog') {
$('.block_345 .col-icon').addClass('off-ico');
$('.block_345 .col-data').addClass('off-stat');
else {
$('.block_345 .col-icon').removeClass('off-ico');
$('.block_345 .col-data').removeClass('off-stat');
I wanna also change the image icon if the text is not "Voorlopig droog". Can someone tell me how to get this done?
Thanks in advance.
Blah blah blah
Lokonli
Post
by Lokonli »
HansieNL wrote: Saturday 22 June 2019 11:17
// Buienradar
else {
Thanks in advance.
Try the following:
You can change the image by adding the following function to custom.js:
(it works for a normal switch. I did not test with a text block)
function getStatus_345(idx,value,device){
if (device.Data == 'Voorlopig droog') {
blocks[345]['image'] = 'blinds_open.png'
else {
blocks[345]['image'] = 'blinds_closed.png'
HansieNL
Post
by HansieNL »
Thanks a lot. Thanks again.
Blah blah blah
