Doorbell notification
akamming
Post by akamming »
I automated my doorbell using Fibaro Smart Implant. Hereby the small script i created to send the notification. If you follow the comments it is easy to find out what you need to change to make it work in your installation.
		devices = {
			'Beldrukker'                       -- change to the name sensor of the doorbell button
		logging = {
 		level = domoticz.LOG_DEBUG, 			-- Adjust loglevel to your needs
     	marker = 'Deurbel'                      -- Ajust logmarker yo your needs
	    -- debugging
		domoticz.log('Device ' .. device.name .. ' was changed to'..device.state, domoticz.LOG_DEBUG)
		if (device.active) then
		    -- debug
		    domoticz.log("button  was pushed, sending notification",domoticz.LOG_INFO)
    		-- notify the user
    		domoticz.notify("Deurbel","Er staat iemand voor de deur....",domoticz.PRIORITY_HIGH) -- adjust message to you needs
    	    -- debug
    	    domoticz.log("button  was released, do nothig...",domoticz.LOG_DEBUG)
rgroothuis
Re: Doorbell notification
Post by rgroothuis »
From the script I see you are not enabling any bell or so. So I guess you are using the smart implant in the mode that the input is connected to the output. Meaning the doorbell is enabled when the button is pushed.
I want to control this from a script, so that I can disable the bell at night for example. I need to disconnect the input and the output of the smart implant, but nobody seems to have a solution in Domoticz for this. Do you have a suggestion?
