Uploading data from 3phase smart meter to PvOutput
mcpoowl
Post by mcpoowl »
Hi guys,
I've recently installed some solar panels on my roof, and connected my smart meter to my Domoticz instance. Previously I just got 1 device (when looking at Power), and that was just the meter itself, but now it's totally different, and I'm struggling with uploading all the data to Pvoutput.
Now, I get 6 devices:
Usage L1
Usage L2
Usage L3
Delivery L1
Delivery L2
Delivery L3
Has anyone been able to upload this data succesfully to pvoutput. All the scripts I've found don't take the L1,L2,L3 into account, and thus won't work, and I guess there needs to be some aggregation.
Any tips would be highly appreciated!
Thanks in advance!
Re: Uploading data from 3phase smart meter to PvOutput
mcpoowl wrote: Friday 21 June 2019 19:56 I've recently installed some solar panels on my roof, and connected my smart meter to my Domoticz instance. Previously I just got 1 device (when looking at Power), and that was just the meter itself, but now it's totally different, and I'm struggling with uploading all the data to Pvoutput. Now, I get 6 devices; I guess there needs to be some aggregation.
A dzVents solution could look like this.
When not yet familiar with dzVents please start with reading Get started Before implementing. Special attention please for
"In Domoticz go to Setup > Settings > Other and in the section EventSystem make sure the checkbox 'dzVents disabled' is not checked. Also make sure that in the Security section in the settings you allow 127.0.0.1 to not need a password. dzVents uses that port to send certain commands to Domoticz. Finally make sure you have set your current location in Setup > Settings > System > Location, otherwise there is no way to determine nighttime/daytime state."
local stringVar = 'PVOutput'
            on =    {
                        timer = { 'every 4 minutes'},
                        httpResponses = { stringVar },
       logging =    {
                        level   =   domoticz.LOG_ERROR,
                        marker  =   "pvOutput"
    execute = function(dz, item)
        local function post2PVOutput(PVSettings, postData)
            dz.openURL({
                url = PVSettings.url,
                method = 'POST',
                headers = {
                    ['X-Pvoutput-Apikey'] = PVSettings.api,
                    ['X-Pvoutput-SystemId'] = PVSettings.id
                callback = stringVar,
                postData = postData
        local function makepostData()
            local P1-1 = dz.devices('L1')
            local P1-2 = dz.devices('L2')
            local P1-3 = dz.devices('L3')
            local temperature = dz.devices('myTemperature') -- change to your outside temp device
            local voltage = dz.devices('myVoltage') -- change to a device with a voltage value
            local round = dz.utils.round
            local postdDataAsString =
            'd=' .. os.date("%Y%m%d") ..
            '&t=' .. os.date("%H:%M") ..
            '&v1=' .. tostring(P1-1.usageDelivered + P1-2.usageDelivered + P1-3.usageDelivered ) ..
            '&v2=' .. tostring(P1-1.return1 + P1-2.return1 + P1-3.return1 + P1-1.return2 + P1-2.return2 + P1-3.return2  ) ..
            '&v3=' .. P1.usage1 + P1.usage2 ..
            '&v4=' .. P1.usage ..
            '&v5=' .. round(temperature.temperature,1) ..
            '&v6=' .. dz.utils.round(voltage.voltage,1)
            '&c1= ..  c1
            '&n= .. n
                                            Donation mode only parms
            '&delay=' .. Delay
            '&v7=' .. WaterConsumption
            '&v8=' .. InverterFrequency
            '&v11=' .. InverterTemp
            '&v12=' .. GasConsumption
            return postdDataAsString
        if item.isHTTPResponse then
            dz.log("Return from PVOutput \n" .. item.data,dz.LOG_DEBUG)
            PVSettings =
            url = 'HTTPS://pvoutput.org/service/r2/addstatus.jsp',
            api = dz.variables('PVoutput_API').value, -- create this (string Type) uservar and put your API in
            id  = dz.variables('PVoutput_ID').value, -- create this (string Type) uservar and put your PVoutput ID in
            post2PVOutput(PVSettings, makepostData())
mcpoowl
Post by mcpoowl »
Hi waaren,
Thanks for your reply and your script.
I don't think that script is going to work though, since my Usage L1 / Delivery L1 etc devices aren't actual P1 devices, but Usage, Electric devices, thus they won't have the .return1 function. See screen below.
NB: The Consumption device is a little test of mine, so forget that one ;-)
mcpoowl wrote: Friday 21 June 2019 23:01 I don't think that script is going to work though, since my Usage L1 / Delivery L1 etc devices aren't actual P1 devices, but Usage, Electric devices, thus they won't have the .return1 function. See screen below.
Looking at your screenshot, I see that your P1 "Power" is already an aggregate of the other devices. So no real modification needed compared to the script I use (apart from the fact that I have a Youless sensor to measure my production directly from the solarPanels kWh meter)
Can you try this one ?
local scriptVar = 'PVOutput'
            on =    {
                        httpResponses = { scriptVar },
       logging =    {
                        marker  =   "pvOutput"
            dz.openURL({
                method = 'POST',
                headers = {
                callback = scriptVar,
                postData = postData
            local P1 = dz.devices('Power')
            local Youless = dz.devices('Youless')
            '&v1=' .. ( P1.return1 + P1.return2 ) ..
            '&v2=' .. P1.usageDelivered ..
            '&v3=' .. ( P1.usage1 + P1.usage2 ) ..
            '&v6=' .. round(voltage.voltage,1)
                v1 - energy generation
                v2 - power generation
                v3 - energy consumption
                v4 - power consumption
                v5 - temperature
                v6 - voltage
            '&c1= ..  c1
            '&n= .. n
            '&delay=' .. Delay
            PVSettings =
mcpoowl
Post by mcpoowl »
Hi waaren,
Thanks for sticking with me. I used your script, and edited the devices where needed, but I keep getting a 400 BAD REQUEST error. Maybe one of the values is too high? This is the log message I generated:
2019-06-23 20:24:00.201 Status: dzVents: Info: pvOutput: Calling PvOutput with HTTPS://pvoutput.org/service/r2/addstatus.jsp with data d=20190623&t=20:24&v1=86505&v2=0&v3=21439325&v4=127&v5=27.5&v6=234.1
//edit: When I post it as a GET request, I get more info:
Bad request 400: Energy value [86505] too high for system size [3720]
//edit2: When I add the c=1 and n=1 flags to the call, I get an 200 OK, so that works, but I'm not sure my data is correct?
mcpoowl wrote: Sunday 23 June 2019 20:26 Maybe one of the values is too high? This is the log message I generated:
Had another look but I seem to have messed up something in my own script or something has changed on the pvOutput side. Will have a look later this week and come back to you.
I indeed messed up something in my own script when I did some tests. Sorry for the confusion caused.
If you change the postdataAsString declaration to
            '&v1=' .. P1.return1 + P1.return2 ..
            '&v6=' .. dz.utils.round(voltage.voltage,1) ..
            '&c1=1'
You get the results in pvoutput.
Day overview
Day overview
mcpoowl
Post by mcpoowl »
Thanks waaren, I'll check tonight, and post back tomorrow!
//edit: Seems to be working now! https://pvoutput.org/intraday.jsp?id=40263&sid=36810
