Page 1 of 3
M709 1080p Mini Camera with WiFi (extremely small)
Posted: Tuesday 18 June 2019 11:50
by ben53252642
Hey folks,
I'm continuing my evaluation of various mini camera's this time with the M709 1080p Mini Camera.
The M709 next to my Gear S3 Smart Watch for size comparison.
This is a very impressive camera that delivers a full 1080p resolution with night vision in an extremely small form factor.
It also has a magnetic base on the back and side of the camera and comes with a stick on mounting bracket.
Hardware:
Processor: hi3518 erbcv200
WiFi chip: MediaTek BL-R7601MU3 (MT7601U)
SPI Flash chip: Winbond 25Q64JVS10
MJPEG Stream (1080p, runs at around 3 frames per second)
http://192.168.0.167:80/media/?action=stream&user=USERNAME&pwd=PASSWORD
HTTP Video Stream which includes audio (720p 30 frames per second)
http://192.168.0.167/videostream.asf?user=USERNAME&pwd=PASSWORD&resolution=64
Tested resolutions:
(320x240): resolution=8
(640x480): resolution=32
(1280x720): resolution=64
JPEG Snapshot 1080p (This URL is what you will need to use if you want to integrate the camera directly into Domoticz)
http://192.168.0.167/media/?action=snapshot&user=USERNAME&pwd=PASSWORD
I did not need to use an app to setup the camera, I was able to connect to it directly via WiFi and configure it via a web interface:
1) Connected via WiFi
2) Camera default IP is: 192.168.10.1
3) Default login is username: admin with no password
With multiple cameras I discovered a problem when I attempted to set a long password containing special characters, the camera denied all access until I reset the unit, since then I've been using 12 character length alpha numeric passwords with no special characters.
Note that until I got the camera connected to my WiFi AP the connection to the camera was very unstable with frequent timeouts, I just kept retrying until I had it connected to my WiFi AP then it worked fast.
Results of a "nmap -p- ipaddress" scan (took about 1 hour):
PORT STATE SERVICE
80/tcp open http
10213/tcp open unknown
Interesting URLs:
/get_params.cgi
/get_status.cgi
/get_camera_params.cgi
/set_video_prm.cgi
/advanced_cfg.asp
/voice_detection_cfg.asp
/stream_cfg.asp
/get_batchk_cfg.cgi
/get_advol.cgi
/upnp_cfg.asp
/ddns_cfg.asp
/ftp_cfg.asp
/reboot.cgi
/get_misc.cgi
/wifi_scan.cgi
/get_wifi_scan_result.cgi
/get_hwver.cgi
/check_user.cgi?user=USERNAME&pwd=PASSWORD
/set_alias.cgi
/video/snapshot.asp?cam_idx=0&img_size=83886800
/videostream.cgi?resolution=128
Enabled auto IR Led (set to 0 to disable):
/set_misc.cgi?irled_mode=1
Set Power line frequency (0 = 50hz, 1 = 60hz, 2 = disable):
/set_misc.cgi?pwr_freq=2
Set Brightness (values between 0 and 10):
/camera_control.cgi?param=2&value=6
Set Contrast (values between 0 and 10):
/camera_control.cgi?param=3&value=6
Flip image (persists over device reboots):
/camera_control.cgi?param=5&value=1
To disable the OSD "on screen display" which overlays the following on the camera image:
* battery level top right
* camera name bottom left
* time top left
Instructions to disable OSD: Login to web gui, create a backup configuration and export it (download to your PC), edit and change the line "osd_show=1" to "osd_show=0", save the file and restore it to the camera. The camera will reboot and the OSD should be disabled.
Adjust the infrared LED light activation sensitivity (I had to do this on one of my M709 cameras), the IR was activated even when the room lights were turned on. Note I had to set the IR LED status to close and then auto in the /setting.asp > System > Misc Settings before modifications at the below url seemed to take effect. The adjustment needed was very minor, I changed "IR Low Limit" from the default 15 to 13 and set "IR High Limit" to 25 which solved my problem.
/advanced_cfg.asp
Thermal tests:
Unfortunately my infrared thermometer was unable to get a reasonably accurate reading measuring the heat off the top of the Hi3518 chipset, I ended up using a cooking thermometer which gave me these results:
Without included thermal pad and heat shield: 55.4 degrees Celsius
With included thermal pad and heat shield: 40.8 degrees Celsius
Ambient room temperature was 25.5 degrees Celsius
My complaints about this camera:
1) Have not found a way to adjust the asf of mjpeg frame-rate
2) Have not found a way to adjust the asf bitrate, hi3518 chipset is known that it can be set up to 6000kbps, how to change? It appears to be hard-set at around 1000kbps or similar vbr quality setting.
3) Have not found a way to get 1080p resolution video at a reasonable frame-rate (for example even 10fps would be acceptable for me).
4) The power button design should just be a switch on or off that persists across reboots.
5) Wish there was an option to order the camera without a battery.
Other things I like about this camera:
1) The infrared LED's when active do not appear to be visible to a human eye at night which is fantastic if intending to use these cameras as sensors around a home.
Security concerns:
1) Web interface, video and audio are all sent over the network with zero encryption. This means the security of the camera feeds is entirely dependent on the WiFi WPA2 AES and there being no untrusted users on the WiFi network.
2) By default the camera joins a P2P network, this option needs to be disabled in the web interface.
So far I have not been able to get root access to this camera, when I do though I'd like to:
1) Investigate the possibility of enabling https for Web interface, video and audio to secure traffic over the local network either via the built in goahead web server or by adding a small ssl reverse proxy and firewall.
2) Attempt to get a 15 fps 1080p stream.
WORK STILL IN PROGRESS
Re: M709 1080p Mini Camera with WiFi (extremely small)
Posted: Tuesday 18 June 2019 14:46
by ben53252642
Ended up doing a few hardware mods:
1) Remove LEDs
2) Modify switch so the camera starts automatically on power restore
3) Remove Lithium Ion battery
Can confirm that the camera works just fine with the battery removed.
As you can see most of the space inside the case is used for the battery. It's surprising how light weight the camera is without the battery.
Posted: Friday 21 June 2019 14:07
by ben53252642
I setup an M709 in the kitchen to monitor the cats, I am impressed with the image quality for such a small camera.
Note my highly professional mounting on the side of the USB power adapter. 8-)
Photo at night with lights on:
Photo at night with lights off (Camera is using its IR LED's), picture is very grainy.
Posted: Wednesday 17 July 2019 17:06
by bueno79
hi,
this camera works on power supply, no battery right ?
Posted: Wednesday 17 July 2019 17:21
by ben53252642
Can confirm the camera works fine on USB power with or without the battery removed (I have 9 of these cameras setup with the battery removed).
Note that modification of the power button required a small amount of soldering (can post pictures of you need).
I originally ordered 3 of these cameras and lost 2 to learning how to take it apart and do the modifications. I ordered an additional 10 cameras and lost 1 again to accidentally breaking it.
If you need 1 camera and intend to modify the power switch I suggest ordering 3 and accepting there is a moderate risk 1 or more will break if you attempt the power button modification.
If you are happy to keep the internal battery then it works fine on power AND battery, no need to modify.
The cameras seem very reliable, I have not had a single unexpected reboot from any of mine. If you keep the battery, once you turn the unit on if it is connected to USB power I don't think you will have to turn it on again unless there is an extended power outage that also drains the cameras built in battery.
Posted: Saturday 02 November 2019 16:51
by JimmyH1969
I ordered 3 and can not get them to work without the use of the app.
Port 80 is not open at the device so i can only configure the device by using the app.
According to the supplyer they changed the camera so it can only be operated from the app.... anyone for 3 camera's? :(
Posted: Sunday 03 November 2019 4:00
by ben53252642
What are the results of running this nmap command against the cameras IP address?
nmap -p- ipaddress
Note that it can take about an hour to complete.
Posted: Sunday 03 November 2019 15:09
by JimmyH1969
Oke, but the results are not that good... :mrgreen:
Scanning 192.168.1.39 [65535 ports]
Discovered open port 554/tcp on 192.168.1.39
Discovered open port 51503/tcp on 192.168.1.39
PORT STATE SERVICE VERSION
554/tcp open rtsp
| fingerprint-strings:
| HTTPOptions, RTSPRequest, SIPOptions:
| RTSP/1.0 400 Bad Request
| Server: Hopeway RealServer/V1.0
|_ Connection: Close
|_rtsp-methods: ERROR: Script execution failed (use -d to debug)
51503/tcp open rtsp
|_ Connection: Close
2 services unrecognized despite returning data.
Posted: Sunday 03 November 2019 15:13
by ben53252642
Try this in VLC media player (open this URL):
rtsp://192.168.1.39:554
Looks like they removed the http web server and added rtsp support.
That's very easy to work with.
Posted: Sunday 03 November 2019 16:04
by JimmyH1969
to bad, already tried that and does not work either.
In dutch:
Uw invoer kan niet geopend worden:
VLC kon de MRL 'rtsp://192.168.1.39:554' niet openen. Controleer het logboek voor details.
Posted: Sunday 03 November 2019 16:09
by ben53252642
Try this:
rtsp://192.168.1.39:554/rtsp_live0
The video will be there, you just need to find the address.
Posted: Sunday 03 November 2019 16:26
by JimmyH1969
same error.
I know i just need to find the right adress. I already googled and tried a lot, so far no luck.
But, even when getting the right url, Domoticz is not going to like it.
Tnx for trying/helping btw.
Posted: Sunday 03 November 2019 16:29
by ben53252642
Actually Domoticz will be fine with it, many people have cameras that only do rtsp on this forum.
The solution is just to get ffmpeg to take still shots from the video stream for Domoticz using a script.
If you figure out the rtsp video url (which you could probably get by sniffing traffic between the camera and app) we can talk further about how to do the integration with Domoticz.
What your looking for is rtsp://ipaddress:554/themagicaddress
Posted: Sunday 03 November 2019 18:19
by JimmyH1969
Yep, but sniffing between app and camera is not that easy. I will ask the supplier first, but he's not verry cooperative :D
I can send them back and get a refund, but i like the size of these cam's... anyway, to be continued..
Posted: Wednesday 06 November 2019 16:07
by JimmyH1969
It took a few days, but got the streams using wireshark...
rtsp://192.168.1.39:554/fc9ad3b449a4db1d9f8d0c814a00dba2_0
rtsp://192.168.1.39:554/fc9ad3b449a4db1d9f8d0c814a00dba2_1
This is just the first cam. Not sure if they all use the same url. But, So far....
Posted: Thursday 07 November 2019 9:13
by ben53252642
Nice work! I've never seen an rtsp url like that, I wouldn't be surprised if it was randomly generated for each camera. Still it's not very secure if all you had to do was use wireshark to find the url... ;)
Also there might be a control mechanism the app uses to do things like flip the camera image. You may be able to decipher it (if you need access to the features).
Posted: Thursday 07 November 2019 9:54
by JimmyH1969
Yes it generates the url every time you (re)connect it to your WiFi. So after resetting to factory defaults and reconnecting it, it is:
rtsp://192.168.1.39:554/005a8f514b7a61782da336f201d10299_0
rtsp://192.168.1.39:554/005a8f514b7a61782da336f201d10299_1
Never mind, as long as it's not resetted to defaults there's no problem. I will change common setting with the app and IR switches on automaticly when it's to dark. I connected it to NetcamStudio and from there we go to Domoticz. Works like a charm.
Tnx for helping out!
Posted: Friday 29 November 2019 10:58
by EldigoR
Hi JimmyH1969,
I have almost the same camera and you posts have been very helpful!
I found these RSTP stream:
rtsp://192.168.1.76:554/9FHGD03A7C24082D95D46AD337EB68H8_0
rtsp://192.168.1.76:554/9FHGD03A7C24082D95D46AD337EB68H8_1
I'm now looking the turn off and on the IR LEDS without use of the app.
I was able to capture the command from the app to the camera to turn on the IR LED
It is just TCP packet with JSON DATA
{"infrared_led":1,"msg_index":42,"msg_name":"SetMiniIpcLed","ipc_pwd":"9FHGD03A7C24082D95D46AD337EB68H8","ipc_id":"38574691068"}
I haven't been able to send such a message to the camera my self.
Have you been able to turn of the IR LEDS by hand ?
Posted: Friday 29 November 2019 12:54
by JimmyH1969
No i did not try that. Is there any reason you want to turn them on manually? (just curious)
There should be a way to use that string in a json call i think, but i have no idea yet.
Hope you get your answer and post it here. Good luck
Jimmy
Posted: Friday 29 November 2019 13:38
by EldigoR
OK, no problem,
My camera does not switches IR on automatically, only scheduled on hours.
I want to let Domoticz controle the IR LEDS (day/night)
This is my Camera by the way:
https://nl.aliexpress.com/item/33006271385.html
