Neo Coolcam door/window sensor in OZW 1.6
Posted: Saturday 15 June 2019 20:54
by philchillbill
I've noticed that in the recent betas with OZW 1.6, my zwave nodes show up fine under devices except for my Neo Coolcam Door/Window contacts which all have 0000 device ids. Is there any way to get Domoticz to see these or do I just have to wait for a better beta? Triple-clicking the include button does not help. I cannot exclude/re-include because Domoticz crashes with a core dump if I attempt this. I also cannot open the control panel without a crash.
I'm on Ubuntu on an Intel NUC with an Aeon Labs z-stick gen 5.
Re: Neo Coolcam door/window sensor in OZW 1.6
Posted: Sunday 16 June 2019 8:24
by gizmocuz
Try to select this node and press the button "Refresh Node Info" then press the button on the node (within 3 seconds)
If that does not help (it should..) then try "Include normal/secure" again (no need to exclude)
You also run the latest domoticz code ?
Posted: Sunday 16 June 2019 9:52
by philchillbill
Just tried it now with 10914 which at least allowed me to open the control panel without an immediate crash. Refresh node info didn't help. Include node again just resulted in a freeze. Definitely more stable that it has been on previous betas but still no Neo's.
I did notice that when I reverted to the latest stable with ./updaterelease, there was an immediate crash with a message that the newer db was incompatible so I had to restore my db copy from before the beta. Never had that one before.
Posted: Sunday 16 June 2019 13:32
by gizmocuz
There have been made a openzwave patch in the meter class, that could have caused the crash
Yes there have been a internal update in the database/filesystem, that does not happen often, but yes this is the reason for the message
When you selected 'Include Node' it was freezing straight away ? or did you triple click the button on the node ? was it a normal include or a secure include ?
Posted: Sunday 16 June 2019 15:36
by philchillbill
It was a normal include. The modal with the rotating busy-indicator and the abort button just stayed there rotating forever until I killed Domoticz. The timing of the triple-click didn't make a difference.
Posted: Thursday 01 August 2019 18:51
by philchillbill
I waited until 4.11069 before trying this again and now the Neo Coolcam nodes were retrievable after triple-pressing. Solved (thanks) !
Posted: Sunday 04 August 2019 9:13
by sincze
I created a summary of this for future reference here: Based on Domoticz V4.10988
https://github.com/domoticz/domoticz/is ... -514125507
