I've noticed that in the recent betas with OZW 1.6, my zwave nodes show up fine under devices except for my Neo Coolcam Door/Window contacts which all have 0000 device ids. Is there any way to get Domoticz to see these or do I just have to wait for a better beta? Triple-clicking the include button does not help. I cannot exclude/re-include because Domoticz crashes with a core dump if I attempt this. I also cannot open the control panel without a crash.
I'm on Ubuntu on an Intel NUC with an Aeon Labs z-stick gen 5.
Neo Coolcam door/window sensor in OZW 1.6 Topic is solved
- philchillbill
- gizmocuz
Re: Neo Coolcam door/window sensor in OZW 1.6
Try to select this node and press the button "Refresh Node Info" then press the button on the node (within 3 seconds)
If that does not help (it should..) then try "Include normal/secure" again (no need to exclude)
You also run the latest domoticz code ?
- philchillbill
Just tried it now with 10914 which at least allowed me to open the control panel without an immediate crash. Refresh node info didn't help. Include node again just resulted in a freeze. Definitely more stable that it has been on previous betas but still no Neo's.
I did notice that when I reverted to the latest stable with ./updaterelease, there was an immediate crash with a message that the newer db was incompatible so I had to restore my db copy from before the beta. Never had that one before.
- gizmocuz
There have been made a openzwave patch in the meter class, that could have caused the crash
Yes there have been a internal update in the database/filesystem, that does not happen often, but yes this is the reason for the message
When you selected 'Include Node' it was freezing straight away ? or did you triple click the button on the node ? was it a normal include or a secure include ?
- philchillbill
It was a normal include. The modal with the rotating busy-indicator and the abort button just stayed there rotating forever until I killed Domoticz. The timing of the triple-click didn't make a difference.
- philchillbill
I waited until 4.11069 before trying this again and now the Neo Coolcam nodes were retrievable after triple-pressing. Solved (thanks) !
- sincze
- Domoticz version: 2024.4
I created a summary of this for future reference here: Based on Domoticz V4.10988
https://github.com/domoticz/domoticz/is ... -514125507
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
