Cant figure out how to do what seems be a easy thing. I have an Nexa transmitter that sends on/off to domiticz when my robotic lawnmover leaves and return for charging. I want domoticz to send me an notification when the robot been away for 2 hours. How could I do this? In other word, when therese been Off recieved from the switch for mote then 2h i will get the notification.
Send notification after switch been off for 2h
- waaren
Re: Send notification after switch been off for 2h
Unfortunately there is no native domoticz timer to help here. The script below uses the afterNNN method of dzVents to emulate this.Ivanhoe1 wrote: Tuesday 11 June 2019 20:05 Hi,
Cant figure out how to do what seems be a easy thing. I have an Nexa transmitter that sends on/off to domoticz when my robotic lawnmower leaves and return for charging. I want domoticz to send me an notification when the robot been away for 2 hours. How could I do this? In other words, when there has been no Off received from the switch for more then 2 hours i will get the notification.
When not yet familiar with dzVents please start with reading Get started Before implementing. Special attention please for "In Domoticz go to Setup > Settings > Other and in the section EventSystem make sure the checkbox 'dzVents disabled' is not checked. Also make sure that in the Security section in the settings you allow 127.0.0.1 to not need a password. dzVents uses that port to send certain commands to Domoticz. Finally make sure you have set your current location in Setup > Settings > System > Location, otherwise there is no way to determine nighttime/daytime state."
scriptVar = "yourSwitchDelay"
lawnmowerSwitch = "lawnmowerActive"
on = { devices = { lawnmowerSwitch }, -- change to 'name' or ID of your lawnMower active switch
httpResponses = { scriptVar}},
logging = { level = domoticz.LOG_DEBUG,
marker = scriptVar },
execute = function(dz, item)
local delay = 7200 -- delay in seconds Adjust to your needs
local jsonString = dz.settings['Domoticz url'] .. "/json.htm?type=command¶m=addlogmessage&message=Waiting%20is%20over"
if item.isHTTPResponse then
if dz.devices(lawnmowerSwitch).active and lawnmowerSwitch.lastUpdate.secondsAgo > ( delay - 100 ) then
dz.notify('Lawnmower','Lawnmower away for '.. lawnmowerSwitch.lastUpdate.secondsAgo ..' seconds',dz.PRIORITY_NORMAL)
elseif item.active then -- lawnmowerSwitch switched to On
dz.openURL ({ url = jsonString,
method = "GET",
callback = scriptVar }).afterSec(delay) -- to come back after delay seconds
}Debian buster, bullseye on RPI-4, Intel NUC.
Ivanhoe1
Thanks alot waaren for the help!
Ivanhoe1
Tried the script but ran in to a problem with "attempt to index field 'lastUpdate' (a nil value) ". Log below.
Should the uservarible be an integer?
2019-06-18 22:13:01.395 Status: User: Admin initiated a switch command (244/Lawnmoverswitch/Off)
2019-06-18 22:13:01.537 Status: dzVents: Info: LawnmoverGone: ------ Start internal script: Robot4: Device: "Lawnmoverswitch (RFXCOM)", Index: 244
2019-06-18 22:13:01.537 Status: dzVents: Info: LawnmoverGone: ------ Finished Robot4
2019-06-18 22:13:05.981 (RFXCOM) Temp + Humidity (Kallvind temp)
2019-06-18 22:13:09.264 (RFXCOM) Lighting 2 (Lawnmoverswitch)
2019-06-18 22:13:09.256 Status: User: Admin initiated a switch command (244/Lawnmoverswitch/On)
2019-06-18 22:13:09.408 Status: dzVents: Info: LawnmoverGone: ------ Start internal script: Robot4: Device: "Lawnmoverswitch (RFXCOM)", Index: 244
2019-06-18 22:13:09.408 Status: dzVents: Debug: LawnmoverGone: OpenURL: url = http://127.0.0.1:8088/json.htm?type=com ... 0is%20over
2019-06-18 22:13:09.408 Status: dzVents: Debug: LawnmoverGone: OpenURL: method = GET
2019-06-18 22:13:09.408 Status: dzVents: Debug: LawnmoverGone: OpenURL: post data = nil
2019-06-18 22:13:09.408 Status: dzVents: Debug: LawnmoverGone: OpenURL: headers = nil
2019-06-18 22:13:09.408 Status: dzVents: Debug: LawnmoverGone: OpenURL: callback = LawnmoverGone
2019-06-18 22:13:09.409 Status: dzVents: Info: LawnmoverGone: ------ Finished Robot4
2019-06-18 22:13:09.409 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2019-06-18 22:13:14.421 Status: Waiting is over
2019-06-18 22:13:14.539 Status: dzVents: Info: LawnmoverGone: ------ Start internal script: Robot4: HTTPResponse: "LawnmoverGone"
2019-06-18 22:13:14.581 Status: dzVents: Debug: LawnmoverGone: Processing device-adapter for Lawnmoverswitch: Switch device adapter
2019-06-18 22:13:14.581 Status: dzVents: Error (2.4.19): LawnmoverGone: An error occured when calling event handler Robot4
2019-06-18 22:13:14.581 Status: dzVents: Error (2.4.19): LawnmoverGone: ...pi/domoticz/scripts/dzVents/generated_scripts/Robot4.lua:16: attempt to index field 'lastUpdate' (a nil value)
2019-06-18 22:13:14.581 Status: dzVents: Info: LawnmoverGone: ------ Finished Robot4
- waaren
No I made a couple of mistakes in copy / pasting the script to the forum. Probably a bit too late or too much wine at that time of nightIvanhoe1 wrote: Tuesday 18 June 2019 22:19 Tried the script but ran in to a problem with "attempt to index field 'lastUpdate' (a nil value) ". Log below.
Can you please try again with this ?
lawnmoverSwitch = "lawnmoverActive"
on = { devices = { lawnmoverSwitch }, -- change to 'name' or ID of your lawnMower active switch
mySwitch = dz.devices(lawnmoverSwitch)
if mySwitch.active and mySwitch.lastUpdate.secondsAgo > ( delay - 100 ) then
dz.notify('Lawnmover','Lawnmover away for '.. mySwitch.lastUpdate.secondsAgo ..' seconds',dz.PRIORITY_NORMAL)
elseif item.active then -- lawnmoverSwitch switched to On
method = "GET",
Ivanhoe1
Works like a charm! Thanks!
Now you deserve another bottle of wine.
