Cannot open ../dzVents/runtime/dzVents.lua: Too many open files
- Domoticz version: >=Béta
Since a few weeks my domoticz "randomly" isn't reachable on its webserver and all LUA scripts aren't working.
Looking at the Domoticz Logfile i see this message constantly showing up:
2019-06-10 11:47:43.548 Error: EventSystem: in /home/XXXX/dev-domoticz/dzVents/runtime/dzVents.lua: cannot open /home/XXXX/dev-domoticz/dzVents/runtime/dzVents.lua: Too many open files
After a "domoticz restart" it works again, but I have no idea whats going on. Especcialy because I didn't change much.
Currently I'm on version 4.10732, the version before the upgrade to the new OpenZwave. Don't want to update because of the bug/faults I see on git relating to this new OpenZwave version.
Any Idea what can cause this error message?
Domotica/graphs "freak" :)
NUC8i3BEH(8gb/250gb),
Lubuntu 19.04,
Aeotec Z-Stick S2(Gen5)
HarmonyElite
HUE(5 bulbs, 2 blooms)
NetAtmo(complete setup)
MiLight iboxV6(2 MiLightBulbs)
IP-Cam
https://www.frijduurzaam.nl
Lubuntu 19.04,
HarmonyElite
IP-Cam
- waaren
Re: Cannot open ../dzVents/runtime/dzVents.lua: Too many open files
Can you check your limits and processes with open files when you see this error? You can use these commands.Freemann wrote: ↑Monday 10 June 2019 12:01 Since a few weeks my domoticz "randomly" isn't reachable on its webserver and all LUA scripts aren't working.
ulimit -Hn # system hard limit max 4096 for standard user 1048576 for root on my RPI
ulimit -n # soft (user) limit for all users (1024 on my system)
sudo lsof > /tmp/lsof.log
sudo cat /tmp/lsof.log | awk '{ print $2 " " $1 ; }' | sort -rn | uniq -c | sort -rn > /tmp/ordered_lsof.log
echo Top 20 processes with open files
head -20 /tmp/ordered_lsof.log
echo
echo Total open files $(awk '{n += $1}; END{print n}' /tmp/ordered_lsof.log)
echo
ok will do!
you having this prepare/ready, means it happens more often?
monitoring the top20 for about 10mins and don't see any changing figures.
What are the figures saying?
Here's a first report;
[edit]
O wait... stupid... was only running the last command, but this it then running on the previous not changed file.
Did run the command all again and here's a second set of figures;
So java is growing, python is getting smaller... is there a way to find out where this is coming from?
30666 2910 java
17425 1844 python
7067 3141 mongod
3696 1150 dockerd
3625 27237 domoticz
2635 1738 mysqld
1440 961 pcmanfm-q
1295 964 lxqt-pane
1030 965 lxqt-poli
968 8141 update-ma
925 1016 update-no
910 807 container
884 963 lxqt-noti
808 962 lxqt-glob
711 880 lxqt-sess
640 854 Xorg
621 969 lxqt-runn
597 1140 qlipper
597 1138 lxqt-powe
592 993 pulseaudi
[edit]
31768 2910 java
15416 1844 python
7067 3141 mongod
3696 1150 dockerd
3683 27237 domoticz
2635 1738 mysqld
1440 961 pcmanfm-q
1295 964 lxqt-pane
1030 965 lxqt-poli
968 8141 update-ma
925 1016 update-no
910 807 container
884 963 lxqt-noti
808 962 lxqt-glob
711 880 lxqt-sess
688 854 Xorg
630 1519 docker-pr
621 969 lxqt-runn
597 1140 qlipper
597 1138 lxqt-powe
Lubuntu 19.04,
HarmonyElite
IP-Cam
Lubuntu 19.04,
HarmonyElite
IP-Cam
- waaren
The first column tells you ho many file(descriptor)s the process from the second column have opened at the moment the lsof command was given. So it would be interresting to see how many are open when you see the error. There is a (soft)limit per process and a hard limit system wide.
I had it once and that turned out to be caused by a bash job that rescheduled itself and did not stop. So too many jobs on my systemyou having this prepare/ready, means it happens more often?
Luckily Google has a far better long term memory than I do.
If I compare your top 20 with mine
4872 4030 mysqld
361 22571 MainWorke
360 1720 llvmpipe-
280 1326 node
260 502 node
242 22571 WebServer
241 22571 Webem_ssn
241 22571 RFXCOM
240 22571 RFLink
240 22571 PluginMgr
240 22571 OZW-drive
240 22571 EventSyst
240 22571 Domoticz_
202 1251 smbd
194 1313 lpqd
174 1253 cleanupd
171 1252 smbd-noti
167 1239 winbindd
166 1236 winbindd
162 1275 winbindd
OK, had Home-Assistant for testing running in a Docker container. Stopped HA and Python is of the list.
That keeps Java all alone on top, thinking that the Ubiquiti Unifi Controller container is the next potential point to look at.
31046 2910 java
9546 3141 mongod
4002 27237 domoticz
3432 1150 dockerd
2635 1738 mysqld
1440 961 pcmanfm-q
1295 964 lxqt-pane
1030 965 lxqt-poli
968 8141 update-ma
925 1016 update-no
884 963 lxqt-noti
858 807 container
808 962 lxqt-glob
711 880 lxqt-sess
664 854 Xorg
621 969 lxqt-runn
597 1140 qlipper
597 1138 lxqt-powe
592 993 pulseaudi
579 1142 nm-tray
Lubuntu 19.04,
HarmonyElite
IP-Cam
Lubuntu 19.04,
HarmonyElite
IP-Cam
Ok, this evening another "to many files..":
Here the output of the above commands;
2019-06-14 22:03:35.260 Error: EventSystem: in /home/marco/dev-domoticz/dzVents/runtime/dzVents.lua: cannot open /home/marco/dev-domoticz/dzVents/runtime/dzVents.lua: Too many open files
xx@dxx:~$ echo Top 20 processes with open files
xx@xx:~$ head -20 /tmp/ordered_lsof.log
31378 27237 domoticz
30430 31924 java
19728 1403 python
6623 32007 mongod
4818 1150 dockerd
2666 910 mysqld
1440 961 pcmanfm-q
1295 964 lxqt-pane
1290 807 container
1168 5153 influxd
1030 965 lxqt-poli
988 8141 update-ma
925 1016 update-no
884 963 lxqt-noti
808 962 lxqt-glob
798 639 docker-pr
756 5126 docker-pr
711 880 lxqt-sess
704 854 Xorg
621 969 lxqt-runn
xx@xx:~$ echo
xx@xx:~$ echo Total open files $(awk '{n += $1}; END{print n}' /tmp/ordered_lsof.log)
Total open files 133180
Lubuntu 19.04,
HarmonyElite
IP-Cam
Lubuntu 19.04,
HarmonyElite
IP-Cam
- waaren
Are you sure you are running on a RPI ? These figures do look more as if you are trying to compete with the Google datacentersFreemann wrote: ↑Friday 14 June 2019 22:06 Ok, this evening another "too many files..":Here the output of the above commands;Code: Select all
On my production Raspberry with over 300 active devices, many scripts, some python plugins, mysql databases and MQTT my total number
is 17666 and even on my NAS (Synology 916+) with many active packages including a domoticz instance I only have 67000.
Having said that I find the number for domoticz on your system in itself already quite high.
what do you see with
lsof -p $(pidof domoticz)
Maybe other forum members can share the figures they count on their systems so you have more numbers to compare yours with.
I'm running LUbuntu 19.04 with 12 docker containers on a NUC with 256g ssd and 8g mem.
Performance is totally no issue.
The high Python number is caused by Home-Assistant.
The high Java number is caused by the Ubiquiti Unifi-Controller.
The high Domoticz number is caused by....
htop shows:
xx@xx:~$ [b]sudo lsof -p $(pidof domoticz)[/b]
[sudo] password for xx:
lsof: WARNING: can't stat() fuse.gvfsd-fuse file system /run/user/1000/gvfs
Output information may be incomplete.
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
domoticz 23468 root cwd DIR 8,3 4096 262145 /xxxx/xxxx/dev-domoticz
domoticz 23468 root rtd DIR 8,3 4096 2 /
domoticz 23468 root txt REG 8,3 13500496 267226 /xxxx/xxxx/dev-domoticz/domoticz
domoticz 23468 root mem REG 8,3 14256 798023 /usr/lib/x86_64-linux-gnu/libnss_mdns4_minimal.so.2
domoticz 23468 root mem REG 8,3 51672 798019 /usr/lib/x86_64-linux-gnu/libnss_files-2.29.so
domoticz 23468 root mem REG 8,3 5698832 795947 /usr/lib/locale/locale-archive
domoticz 23468 root mem REG 8,3 14688 798249 /usr/lib/x86_64-linux-gnu/libutil-2.29.so
domoticz 23468 root mem REG 8,3 243840 797708 /usr/lib/x86_64-linux-gnu/libexpat.so.1.6.8
domoticz 23468 root mem REG 8,3 5080176 798120 /usr/lib/x86_64-linux-gnu/libpython3.7m.so.1.0
domoticz 23468 root mem REG 8,3 43384 797646 /usr/lib/x86_64-linux-gnu/libcrypt-2.29.so
domoticz 23468 root mem REG 8,3 1175000 798197 /usr/lib/x86_64-linux-gnu/libsqlite3.so.0.8.6
domoticz 23468 root mem REG 8,3 304984 797854 /usr/lib/x86_64-linux-gnu/libhx509.so.5.0.0
domoticz 23468 root mem REG 8,3 64496 797843 /usr/lib/x86_64-linux-gnu/libheimbase.so.1.0.0
domoticz 23468 root mem REG 8,3 165880 798289 /usr/lib/x86_64-linux-gnu/libwind.so.0.0.0
domoticz 23468 root mem REG 8,3 96872 798145 /usr/lib/x86_64-linux-gnu/libroken.so.18.1.0
domoticz 23468 root mem REG 8,3 217560 797842 /usr/lib/x86_64-linux-gnu/libhcrypto.so.4.1.0
domoticz 23468 root mem REG 8,3 669888 797555 /usr/lib/x86_64-linux-gnu/libasn1.so.8.0.0
domoticz 23468 root mem REG 8,3 577560 797912 /usr/lib/x86_64-linux-gnu/libkrb5.so.26.0.0
domoticz 23468 root mem REG 8,3 43552 797844 /usr/lib/x86_64-linux-gnu/libheimntlm.so.0.1.0
domoticz 23468 root mem REG 8,3 22448 797909 /usr/lib/x86_64-linux-gnu/libkeyutils.so.1.8
domoticz 23468 root mem REG 8,3 35128 797723 /usr/lib/x86_64-linux-gnu/libffi.so.6.0.4
domoticz 23468 root mem REG 8,3 269808 797811 /usr/lib/x86_64-linux-gnu/libgssapi.so.3.0.0
domoticz 23468 root mem REG 8,3 113392 798162 /usr/lib/x86_64-linux-gnu/libsasl2.so.2.0.25
domoticz 23468 root mem REG 8,3 97072 798139 /usr/lib/x86_64-linux-gnu/libresolv-2.29.so
domoticz 23468 root mem REG 8,3 51840 797914 /usr/lib/x86_64-linux-gnu/libkrb5support.so.0.1
domoticz 23468 root mem REG 8,3 18344 797642 /usr/lib/x86_64-linux-gnu/libcom_err.so.2.1
domoticz 23468 root mem REG 8,3 203200 797901 /usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1
domoticz 23468 root mem REG 8,3 893664 797913 /usr/lib/x86_64-linux-gnu/libkrb5.so.3.3
domoticz 23468 root mem REG 8,3 75776 798217 /usr/lib/x86_64-linux-gnu/libtasn1.so.6.5.5
domoticz 23468 root mem REG 8,3 1236720 798050 /usr/lib/x86_64-linux-gnu/libp11-kit.so.0.3.0
domoticz 23468 root mem REG 8,3 522592 797794 /usr/lib/x86_64-linux-gnu/libgmp.so.10.3.2
domoticz 23468 root mem REG 8,3 224072 797848 /usr/lib/x86_64-linux-gnu/libhogweed.so.4.5
domoticz 23468 root mem REG 8,3 1566760 798239 /usr/lib/x86_64-linux-gnu/libunistring.so.2.1.0
domoticz 23468 root mem REG 8,3 63736 797919 /usr/lib/x86_64-linux-gnu/liblber-2.4.so.2.10.10
domoticz 23468 root mem REG 8,3 331120 797921 /usr/lib/x86_64-linux-gnu/libldap_r-2.4.so.2.10.10
domoticz 23468 root mem REG 8,3 309552 797812 /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2
domoticz 23468 root mem REG 8,3 1707392 790062 /usr/lib/x86_64-linux-gnu/libgnutls.so.30.23.0
domoticz 23468 root mem REG 8,3 223400 798002 /usr/lib/x86_64-linux-gnu/libnettle.so.6.5
domoticz 23468 root mem REG 8,3 67424 798111 /usr/lib/x86_64-linux-gnu/libpsl.so.5.3.1
domoticz 23468 root mem REG 8,3 522824 798201 /usr/lib/x86_64-linux-gnu/libssh.so.4.7.3
domoticz 23468 root mem REG 8,3 113512 798151 /usr/lib/x86_64-linux-gnu/librtmp.so.1
domoticz 23468 root mem REG 8,3 120752 797870 /usr/lib/x86_64-linux-gnu/libidn2.so.0.3.4
domoticz 23468 root mem REG 8,3 157904 798006 /usr/lib/x86_64-linux-gnu/libnghttp2.so.14.17.1
domoticz 23468 root mem REG 8,3 2000480 797609 /usr/lib/x86_64-linux-gnu/libc-2.29.so
domoticz 23468 root mem REG 8,3 1365096 797943 /usr/lib/x86_64-linux-gnu/libm-2.29.so
domoticz 23468 root mem REG 8,3 18656 797677 /usr/lib/x86_64-linux-gnu/libdl-2.29.so
domoticz 23468 root mem REG 8,3 149840 798113 /usr/lib/x86_64-linux-gnu/libpthread-2.29.so
domoticz 23468 root mem REG 8,3 567736 790438 /usr/lib/x86_64-linux-gnu/libcurl-gnutls.so.4.5.0
domoticz 23468 root mem REG 8,3 108768 798349 /usr/lib/x86_64-linux-gnu/libz.so.1.2.11
domoticz 23468 root mem REG 8,3 39880 798149 /usr/lib/x86_64-linux-gnu/librt-2.29.so
domoticz 23468 root mem REG 8,3 149704 798236 /usr/lib/x86_64-linux-gnu/libudev.so.1.6.12
domoticz 23468 root mem REG 8,3 30880 790636 /usr/lib/x86_64-linux-gnu/libusb-0.1.so.4.4.4
domoticz 23468 root mem REG 8,3 2925408 797648 /usr/lib/x86_64-linux-gnu/libcrypto.so.1.1
domoticz 23468 root mem REG 8,3 585504 798203 /usr/lib/x86_64-linux-gnu/libssl.so.1.1
domoticz 23468 root mem REG 8,3 31032 798018 /usr/lib/x86_64-linux-gnu/libnss_dns-2.29.so
domoticz 23468 root mem REG 8,3 26402 1314274 /usr/lib/x86_64-linux-gnu/gconv/gconv-modules.cache
domoticz 23468 root mem-r REG 8,3 32768 267165 /xxxx/xxxx/dev-domoticz/domoticz.db-shm
domoticz 23468 root mem REG 8,3 179032 797344 /usr/lib/x86_64-linux-gnu/ld-2.29.so
domoticz 23468 root 0u CHR 1,3 0t0 6 /dev/null
domoticz 23468 root 1u CHR 1,3 0t0 6 /dev/null
domoticz 23468 root 2u CHR 1,3 0t0 6 /dev/null
domoticz 23468 root 3u a_inode 0,13 0 12924 [eventfd]
domoticz 23468 root 4u a_inode 0,13 0 12924 [eventpoll]
domoticz 23468 root 5u a_inode 0,13 0 12924 [timerfd]
domoticz 23468 root 6w REG 0,48 62102490 24 /tmp/domoticz.txt
domoticz 23468 root 7r REG 0,4 0 13008 /proc/sys/kernel/osrelease
domoticz 23468 root 8r REG 0,4 0 4026532044 /proc/version
domoticz 23468 root 9u unix 0xffff8db9a6327c00 0t0 12808280 type=DGRAM
domoticz 23468 root 10uW REG 0,23 6 1012 /run/domoticz.pid
domoticz 23468 root 11ur REG 8,3 30771200 266026 /xxxx/xxxx/dev-domoticz/domoticz.db
domoticz 23468 root 12u REG 8,3 1050128 265881 /xxxx/xxxx/dev-domoticz/domoticz.db-wal
domoticz 23468 root 13ur REG 8,3 32768 267165 /xxxx/xxxx/dev-domoticz/domoticz.db-shm
domoticz 23468 root 14u a_inode 0,13 0 12924 [eventfd]
domoticz 23468 root 15u a_inode 0,13 0 12924 [eventpoll]
domoticz 23468 root 16u a_inode 0,13 0 12924 [timerfd]
domoticz 23468 root 17u IPv6 12808291 0t0 TCP *:XXXX (LISTEN)
domoticz 23468 root 18u a_inode 0,13 0 12924 [eventfd]
domoticz 23468 root 19u a_inode 0,13 0 12924 [eventpoll]
domoticz 23468 root 20u a_inode 0,13 0 12924 [timerfd]
domoticz 23468 root 21u a_inode 0,13 0 12924 [eventfd]
domoticz 23468 root 22u a_inode 0,13 0 12924 [eventpoll]
domoticz 23468 root 23u a_inode 0,13 0 12924 [timerfd]
domoticz 23468 root 24u IPv6 12808300 0t0 TCP *:6144 (LISTEN)
domoticz 23468 root 25u sock 0,9 0t0 12808310 protocol: TCP
domoticz 23468 root 26u IPv4 12807756 0t0 UDP *:52270
domoticz 23468 root 27w REG 8,3 69292 267201 /xxxx/xxxx/dev-domoticz/Config/OZW_Log.txt
domoticz 23468 root 28uW CHR 166,0 0t0 461 /dev/ttyXXXX
domoticz 23468 root 29u unix 0xffff8db8e3ee9400 0t0 12843304 type=STREAM
domoticz 23468 root 30u unix 0xffff8db8e3eea800 0t0 12843305 type=STREAM
domoticz 23468 root 31u sock 0,9 0t0 12811519 protocol: TCP
domoticz 23468 root 32u sock 0,9 0t0 12815626 protocol: TCP
domoticz 23468 root 33u sock 0,9 0t0 12818987 protocol: TCP
domoticz 23468 root 34u sock 0,9 0t0 12824354 protocol: TCP
domoticz 23468 root 35u sock 0,9 0t0 12833227 protocol: TCP
domoticz 23468 root 36u sock 0,9 0t0 12838816 protocol: TCP
1 [||||||||||||||||| 22.5%] Tasks: 157, 700 thr; 1 running
2 [||||||||||||||| 19.0%] Load average: 0.30 0.56 0.52
3 [||||||||||||||||||||||| 30.9%] Uptime: 9 days, 00:33:45
4 [|||||||||| 12.1%]
Mem[|||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||2.47G/7.66G]
Swp[||| 27.8M/977M]
Lubuntu 19.04,
HarmonyElite
IP-Cam
Lubuntu 19.04,
HarmonyElite
IP-Cam
- Domoticz version: 4.10915
My system is very low on numbers.
Top 20 and total
Top 20 and total
pi@raspberrypi:~ $ head -20 /tmp/ordered_lsof.log
376 1086 llvmpipe-
264 19849 MainWorke
176 19849 EventSyst
175 19849 PluginMgr
175 19849 OZW-drive
175 1355 menu-cach
175 1355 lxpanel
175 1355 gmain
175 1355 gdbus
175 1292 menu-cach
175 1292 lxpanel
175 1292 gmain
175 1292 gdbus
174 19849 WebServer
174 19849 Webem_ssn
132 1247 gvfsd-fus
128 1141 master
127 3323 gdbus
127 3323 deja-dup
127 3323 dconf
Total open files 12699
- waaren
There is no direct relation to the numbers from lsof and CPU / memory usage, This is about open file (descriptor) s.
If possible you should raise the soft (per user) and / or hard (system wide) limits of max open files.
In this situation it will be very worthwhile to search for the many possibilities the lsof command has, to investigate what the cause of the many open files could be.
There are countless examples and very easy to find. The same is true for adjusting the hard and soft max open file limits.
I'm having the same issue. It might be noteworthy to mention that I'm also running the unifi controller on the PI. Were you able to track down the issue?
