Execute same switch On / On AFTER xx
Posted: Sunday 09 June 2019 15:08
by deve87
I want to run
commandArray['Door bell'] = 'On AFTER 5'
commandArray['Door bell'] = 'On AFTER 7'
If I try
commandArray[1]={['Door bell'] = 'On AFTER 5'}
commandArray[2]={['Door bell'] = 'On AFTER 7'}
It only execute the first [1] line
How can I do this?
Re: Execute same switch On / On AFTER xx
Posted: Sunday 09 June 2019 15:56
by waaren
deve87 wrote: Sunday 09 June 2019 15:08
I want to run
- Door bell On after 5 seconds
- Door bell On after 7 seconds
How can I do this?
commandArray[#commandArray + 1] = {['Door bell'] ='On AFTER 5 SECONDS' }
commandArray[#commandArray + 1] = {['Door bell'] ='On AFTER 7 SECONDS' }
Posted: Sunday 09 June 2019 16:05
by deve87
Yes also tried that. Same result
Posted: Sunday 09 June 2019 16:28
by waaren
deve87 wrote: Sunday 09 June 2019 16:05
Should work
What do you see in the log ? Can you share the complete script. It might just help in finding the issue
I tested with this Lua (V4.10881)
commandArray[#commandArray + 1] = {['Door bell'] ='On AFTER 9 SECONDS' }
commandArray[#commandArray + 1] = {['Door bell'] ='On AFTER 11 SECONDS' }
commandArray[#commandArray + 1] = {['Door bell'] ='On AFTER 13 SECONDS' }
commandArray[#commandArray + 1] = {['Door bell'] ='On AFTER 15 SECONDS' }
commandArray[#commandArray + 1] = {['Door bell'] ='On AFTER 17 SECONDS' }
commandArray[#commandArray + 1] = {['Door bell'] ='On AFTER 19 SECONDS' }
relevant domoticz log
2019-06-09 16:16:06.036 (Virtual) Light/Switch (Door bell)
2019-06-09 16:16:08.056 (Virtual) Light/Switch (Door bell)
2019-06-09 16:16:10.035 (Virtual) Light/Switch (Door bell)
2019-06-09 16:16:12.057 (Virtual) Light/Switch (Door bell)
2019-06-09 16:16:14.041 (Virtual) Light/Switch (Door bell)
2019-06-09 16:16:16.066 (Virtual) Light/Switch (Door bell)
2019-06-09 16:16:18.045 (Virtual) Light/Switch (Door bell)
2019-06-09 16:16:20.044 (Virtual) Light/Switch (Door bell)
- Door bell.png (141.66 KiB) Viewed 1173 times
Posted: Sunday 09 June 2019 16:45
by deve87
I haven't actually tried with SECONDS behind. Shall trie that and post back
Posted: Sunday 09 June 2019 18:10
by deve87
Ok. It don't work. Only triggers one line
if uservariables['Multimedia'] == 0 and otherdevices['Se På Data'] == 'On' then
commandArray[#commandArray + 1] = {['TV Source'] = 'On AFTER 1 SECONDS' }
commandArray[#commandArray + 1] = {['TV Source'] = 'On AFTER 3 SECONDS' }
if otherdevices['Se På Data'] == 'On' then
commandArray['Se På Data'] = 'Off'
Running stabel V4.10717
Posted: Sunday 09 June 2019 18:42
by deve87
I figur it out. I had a second scripts setting the device to Off if it becomes On. If I disabled that, it works.
