Dashticz - modify OWM icon in the big weather section
Posted: Sunday 09 June 2019 10:32
by dekoene
I'm struggeling with my custom.css to make the icon in the OWM weather section bigger. From a distance I couldn't read the degrees so I made them bigger but I can't find the correct reference to the Icon in order to make it bigger as well.
Does anyone know how to do this? I see often dashboards where this icon is really small. So I suppose some more people would benefit from it.
The section in my dashboard:
OWM Weather big.JPG (50.87 KiB) Viewed 2473 times
The section in my Custom.css:
.col-xs-12
font-size: 55px;
font-weight: 30;}
.big .weatherdegrees {
font-size: 55px;
font-weight: 10;}
.big .weatherloc {
display: inline-block;
margin-top: -4px;
font-size: 35px;
font-weight: normal;
margin-right: 4px;
text-align:left;}
Re: Dashticz - modify OWM icon in the big weather section
Posted: Sunday 09 June 2019 14:31
by HansieNL
Can you try:
.weather ::before {
font-size: 36px !important;
Posted: Sunday 09 June 2019 22:48
by dekoene
Like this?
.col-xs-12
.weather ::before {
font-size: 36px !important;}
font-size: 55px;
font-weight: 10;}
.big .weatherloc {
margin-top: -4px;
font-size: 35px;
margin-right: 4px;
text-align:left;}
That doesnt seem to do the trick...
Another sugestion?
Where is the icon defined? Maybe I can change it in the original json or css file?
Posted: Monday 10 June 2019 22:07
by Lokonli
dekoene wrote: Sunday 09 June 2019 10:32 Hi all,
.col-xs-12
font-size: 55px;
font-weight: 30;}
font-size: 55px;
font-weight: 10;}
.big .weatherloc {
margin-top: -4px;
font-size: 35px;
margin-right: 4px;
text-align:left;}
There are 4 parts:
* The block
* The skycon icon
* The temperature
* The city
You can style the size as follows:
.block_currentweather_big_owm {
  height: 200px !important;
 .block_currentweather_big_owm .skycon {
  max-width: 200px;
  width: 200px;
 .block_currentweather_big_owm .title {
  font-size: 50pt;
  margin-left: 100px;
 .block_currentweather_big_owm .weatherloc {
  font-size: 50pt;
Posted: Tuesday 11 June 2019 21:25
by dekoene
Great - that worked!
Posted: Tuesday 22 December 2020 19:09
by madpatrick
Is it possible to create a seprate block name with currentweather_big_owm to make 2 different setting.
I want to put the temperature and icon on the stanby screen with a different color and font then on the normal screen in custom.css
Something like this
blocks[Own_weather]		= { 'currentweather_big_owm'}
Posted: Tuesday 22 December 2020 19:45
by Chris12
Lokonli wrote: Monday 10 June 2019 22:07
There are 4 parts:
* The block
* The skycon icon
* The temperature
* The city
  max-width: 200px;
  width: 200px;
  font-size: 50pt;
  margin-left: 100px;
  font-size: 50pt;
How can you align the icon and the text? in my dashboard those are slightly shifted.
The icon is always at the bottom, and the text is centered.
Posted: Tuesday 22 December 2020 21:50
by Lokonli
Please add a screen shot, and indicate what you would like to have changed.
Posted: Tuesday 22 December 2020 22:56
by Lokonli
madpatrick wrote: Tuesday 22 December 2020 19:09 Hi,
Something like this
If you put .standby in front of the class definition in custom.css then only the block on the standby screen will be changed.
So like:
.standby .block_currentweather_big_owm
Posted: Wednesday 23 December 2020 8:21
by Chris12
Lokonli wrote: Tuesday 22 December 2020 21:50 Please add a screen shot, and indicate what you would like to have changed.
Hi Lokonli thank you for looking into this small issue.
As you can see in the screenshot below, the cloud-icon is not inline with the text showing the temperature and city.
in my custom.css I got these parts of weather related css:
[data-id="currentweather_big"].big .weatherloc,
[data-id="currentweather_big"].big .weatherdegrees {
  font-size: 15px;  /*default font you see is 24px, decrease that number at will if you want a smaller font or increase otherwise*/
  icon-size: 20px !important
  height: 80px !important;
  max-width: 85px;
  width: 85px;
  text-align: left;
  font-size: 70pt;
  margin-left: 50px;
  font-size: 150pt;
Posted: Wednesday 23 December 2020 8:36
by Chris12
One other thing I'm also struggeling with regarding the weather icons.
On my standby-screen I want the days of the week with a bigger font, and also when possible the weather icons itself a little bigger (or bold)
Also the space between the weather forcast and the clock I cannot determine why that's so large.
my standby screen config:
//Standby screen configuration
var columns_standby = {}
	columns_standby[1] = {}
	columns_standby[1]['blocks'] = ['weather_owm', 'basicclock',];
	columns_standby[1]['standby_after'] = 3;
blocks['basicclock'] = {
    width: 12,
	scale: 0.3,
Posted: Wednesday 23 December 2020 9:20
by madpatrick
For it is the centering of the weather icon.
The text can be centered, but the icon is not moving
Posted: Wednesday 23 December 2020 9:24
by madpatrick
Chris12 wrote: Wednesday 23 December 2020 8:21
  max-width: 85px;
  width: 85px;
  text-align: left;
  font-size: 70pt;
  margin-left: 50px;
  font-size: 150pt;
Chris,
You can add this to your custom.css (copy of mu setting)
/* ---------------OWM Weather ---------------  */
.block_currentweather_big_owm 			{height: 80px !important;}
.block_currentweather_big_owm .skycon 		{width: 80px;margin-top: -5px;margin-left: -20px;display: inline-block !important;text-align:center !important;}
.block_currentweather_big_owm .title 		{color:#f4ffcc !important;}
.block_currentweather_big_owm .weatherdegrees 	{color:#f4ffcc !important;margin-left: 10px;font-size: 30px !important;}
.block_currentweather_big_owm .weatherloc 	{color:#f4ffcc !important;margin-left: 10px;font-size: 24px !important;}
Play around with margin or padding options
Posted: Wednesday 23 December 2020 14:02
by Chris12
madpatrick wrote: Wednesday 23 December 2020 9:24 You can add this to your custom.css (copy of mu setting)
Thanks this one is solved! Any ideas about the standby screen, how to change the weather icon/text there of the 'weather_owm'?
Posted: Wednesday 23 December 2020 14:53
by madpatrick
I think you need to replace .blocks into .standby
Posted: Thursday 24 December 2020 14:04
by Chris12
Now using the following which is fine for me:
 /* Standby screen items */
 .screenstandby {
    background-color: black !important
.standby .basicclock {
	display: flex !important;
	font-size: 20px;
	justify-content: center !important;
	align-items: center !important;
	background-color: rgb(0,0,0) !important;
	height: 400px !important; }
.standby .block_weather_owm  .skycon 					{width: 150% !important;}
.standby .block_weather_owm  .weatherfull > div div.day			{font-size: 60px !important;font-weight: bold !important;}
.standby .block_weather_owm  .weatherfull > div div.day.owmdescription	{font-size: 40px !important;}
.standby .block_weather_owm  .weatherfull > div div			{font-size: 40px !important;}
.standby .block_weather_owm  .weatherfull > div div.temp		{font-size: 60px !important;}
.standby .block_weather_owm  .weatherfull > div div.temp .nightT	{font-size: 40px !important;}
@Lokonli, a minor thing noticed, is that the days of the week do not start with a capital char. Like Saturday instead of saturday
And the basic clock is showing the day in english, and not in native language ie. dutch. Or does this follow the system/browser defined language?
Posted: Thursday 24 December 2020 14:42
by Lokonli
basicclock follows the language setting:
config['language'] = 'nl_NL'
Posted: Thursday 24 December 2020 14:54
by Chris12
Lokonli wrote: Thursday 24 December 2020 14:42 basicclock follows the language setting:
Thanks! overlooked that setting.
@Lokonli, the days of the week do not start with a capital char. Like Saturday instead of saturday. You recognize this as a bug/enhancement?
Posted: Thursday 24 December 2020 15:21
by Lokonli
Chris12 wrote: Thursday 24 December 2020 14:54
basicclock and miniclock follow the standard language rules.
Thursday is with a first capital
donderdag is lower char only.
The garbage and calendar blocks follow the setting from config['calendarlanguage']
Do you somewhere see thursday instead of Thursday? Then I would consider that as a bug.
donderdag is correct. I would consider Donderdag as a bug :)
Posted: Thursday 24 December 2020 15:53
by madpatrick
Lokonli,
Is it possible to make the color of the icon adjustable ?
Is see in /js/weather_own.js that is a fixed color
var skycon = '<script>';
  skycon += 'var skycons = new Skycons({"color": "white"});';
