Problem with script sunscreen
Posted: Thursday 23 May 2019 19:29
by EdwinK
Since sometime I've been using this script, created by user Rembo
- Spoiler: show
-- Define all the sensors which needs to be considered for the sunscreen to close
local sensors = {
temperature = {
active = true,
device = 'Temperature', --'Buienradar - Temperature',
closeRule = function(device)
return device.temperature <= 19
wind = {
active = true,
device = 'Buienradar - Wind',
return device.speed >= 50 or device.gust >= 150
rain = {
active = true,
device = 'Rain',
return device.rainRate > 0
rainExpected = {
active = false,
device = 'IsItGonnaRain', -- This needs to be a virtual sensor of type 'percentage'
return device.percentage > 15
uv = {
active = false,
device = 'Wu - Uv',
return device.uv <= 2
lux = {
active = true,
device = 'LUX',
return device.lux <= 500
local sunscreenDevice = 'Sunscreen' -- Define the name of your sunscreen device
local dryRun = 'Y' -- Enable dry run mode to test the sunscreen script without actually activating the sunscreen
-- Define the name of a virtual switch which you can use to disable the sunscreen automation script, Set to false to disable this feature
local manualOverrideSwitch = 'Sunscreen - Manual'
local timeBetweenOpens = 10 -- Minutes to wait after a sunscreen close before opening it again.
local LogFile= '/home/pi/domoticz/Logs/Sunscreen.csv ~m.csv'
local LogAction = 'N'
local message = '.'
active = true,
on = { timer = {'every minute'} },
logging = { level = domoticz.LOG_DEBUG,
marker = 'Sunscreen' },
data = { safedMessage = { initial = "-" } },
execute = function(domoticz)
-- FUNCTIONS
function LogActions()
-- LogFile=string.gsub(LogFile,"~d",os.date("%Y-%m-%d"))
LogFile=string.gsub(LogFile,"~m",os.date("%Y-%m"))
if not My.File_exists(LogFile) then
f=io.open(LogFile,"a")
f:write("Datum ; Tijd ; dryRun ; Manual_or_Auto ; Message")
f:write("\r\n")
f=io.open(LogFile,"r")
c=f:read("*line")
f:close()
if domoticz.data.safedMessage == message then
domoticz.log("Same message skip write action",domoticz.LOG_DEBUG)
domoticz.data.safedMessage = message
f:write(os.date("%Y-%m-%d;%H:%M:%S") .. ";" .. dryRun .. ";" .. domoticz.devices(manualOverrideSwitch).state .. ";" .. message )
f:write("\r\n")
f:close()
local function switchOn(sunscreen, message)
if LogAction == 'Y' or LogAction == 'A' then LogActions() end
if (sunscreen.state == 'Closed') then
if dryRun == 'N' then
sunscreen.switchOn()
--domoticz.notify('Sunscreen', message)
domoticz.log(message, domoticz.LOG_INFO)
domoticz.log('Sunscreen is already down' , domoticz.LOG_INFO)
local function switchOff(sunscreen, message)
if (sunscreen.state == 'Open') then
sunscreen.switchOff()
-- PROGRAM STARTS
if (manualOverrideSwitch and domoticz.devices(manualOverrideSwitch).state == 'On') then
domoticz.log('Automatic sunscreen script is manually disabled', domoticz.LOG_DEBUG)
return
local sunscreen = domoticz.devices(sunscreenDevice)
-- Sunscreen must always be up during nighttime
if (domoticz.time.isNightTime) then
message = 'Raising sunscreen, It is night'
return
-- Check all sensor tresholds and if any exeeded close sunscreen
for sensorType, sensor in pairs(sensors) do
if (sensor['active'] == true) then
local device = domoticz.devices(sensor['device'])
local closeRule = sensor['closeRule']
domoticz.log('Checking sensor: ' .. sensorType, domoticz.LOG_DEBUG)
if (closeRule(device)) then
message = (sensorType .. ' treshold exceeded , Sunscreen up')
switchOff(sunscreen, message )
domoticz.log(message, domoticz.LOG_DEBUG)
-- Return early when we exeed any tresholds
return
domoticz.log('Sensor not active skipping: ' .. sensorType, domoticz.LOG_DEBUG)
-- All tresholds OK, sunscreen may be lowered
if (sunscreen.lastUpdate.minutesAgo > timeBetweenOpens) then
message = 'Sun is shining, all thresholds OK, lowering sunscreen'
It sued to be working. But now that the weather is getting in the higher regions I noticed that it didn't actually let the sunscreen raise/lower. I can however send the command directly from the dashboard and then it's working. But not automatically. But.. the log reads:
2019-05-23 19:27:00.314 Status: dzVents: Info: Sunscreen: ------ Start internal script: SunScreen:, trigger: every minute
2019-05-23 19:27:00.316 Status: dzVents: Debug: Sunscreen: Processing device-adapter for Sunscreen - Manual: Switch device adapter
2019-05-23 19:27:00.317 Status: dzVents: Debug: Sunscreen: Processing device-adapter for Sunscreen: Switch device adapter
2019-05-23 19:27:00.317 Status: dzVents: Debug: Sunscreen: Checking sensor: lux
2019-05-23 19:27:00.317 Status: dzVents: Debug: Sunscreen: Sensor not active skipping: uv
2019-05-23 19:27:00.318 Status: dzVents: Debug: Sunscreen: Processing device-adapter for Buienradar - Wind: Wind device adapter
2019-05-23 19:27:00.318 Status: dzVents: Debug: Sunscreen: Checking sensor: wind
2019-05-23 19:27:00.319 Status: dzVents: Debug: Sunscreen: Processing device-adapter for Temperature: Temperature device adapter
2019-05-23 19:27:00.319 Status: dzVents: Debug: Sunscreen: Checking sensor: temperature
2019-05-23 19:27:00.319 Status: dzVents: Debug: Sunscreen: Sensor not active skipping: rainExpected
2019-05-23 19:27:00.320 Status: dzVents: Debug: Sunscreen: Processing device-adapter for Rain: Rain device
2019-05-23 19:27:00.320 Status: dzVents: Debug: Sunscreen: Checking sensor: rain
2019-05-23 19:27:00.320 Status: dzVents: Info: Sunscreen: Sun is shining, all thresholds OK, lowering sunscreen
2019-05-23 19:27:00.320 Status: dzVents: Info: Sunscreen: ------ Finished SunScreen
So you would think it is working.
Re: Problem with script sunscreen
Posted: Friday 24 May 2019 0:52
by waaren
EdwinK wrote: Thursday 23 May 2019 19:29
It used to be working. But now that the weather is getting in the higher regions I noticed that it didn't actually let the sunscreen raise/lower. I can however send the command directly from the dashboard and then it's working. But not automatically. But.. the log reads:
local dryRun = 'Y' ?? -- Enable dry run mode to test the sunscreen script without actually activating the sunscreen
Posted: Friday 24 May 2019 12:29
by EdwinK
Damn.. Overlooked that one. Had it turned on to test somethings. Changed it back and screen was lowering it self right away.
Now trying to find a good rain percentage script and an UV one.
Posted: Sunday 06 June 2021 12:39
by EdwinK
And now again it doesn't work well.
The script is executing, and tells met that the screen is down, but in fact it isn't. This time I checked if the dryrun is turned off,
local dryRun = 'N' -- Enable dry run mode to test the sunscreen script without actually activating the sunscreen
and also the switch in local manualOverrideSwitch = 'Sunscreen - Manual' is set to automatic.
the screen itself will be lowered when I click the button on the tablet. So,, also the KaKu device is working.
The script:
-- Define all the sensors which needs to be considered for the sunscreen to raise
local sensors = {
temperature = {
active = true,
device = 'TempHumBaro',
wind = {
active = true,
device = 'Wind',
rain = {
active = true,
device = 'Rain',
rainExpected = {
active = false,
device = 'BR Regen Percentage', -- This needs to be a virtual sensor of type 'percentage'
uv = {
active = true,
device = 'UV Index',
lux = {
active = true,
device = 'LUX',
local LogFile = '/home/pi/domoticz/Logs/Sunscreen.csv ~m.csv'
local message = '.'
active = true,
-- FUNCTIONS
f:write("\r\n")
c=f:read("*line")
f:close()
f:write("\r\n")
f:close()
domoticz.log('Zonnescherm is al uit' , domoticz.LOG_INFO)
-- PROGRAM STARTS
domoticz.log('Script is handmatig uitgezet', domoticz.LOG_DEBUG)
return
message = 'Zonneschermm omhoog, het is nacht'
return
message = (sensorType .. ' drempel overschreden , scherm omhoog')
return
domoticz.log('Sensor niet actief: ' .. sensorType, domoticz.LOG_DEBUG)
message = 'Zon schijnt, drempels ok, scherm omlaag'
Posted: Wednesday 25 August 2021 21:56
by ricvee
About the switch in local manualOverrideSwitch = 'Sunscreen - Manual':
I made a Dummy switch Sunscreen - Manual, but how to make this work?
Do you connect this Dummy to the device Sunscreen as a Slave or something?
I do not understand how I can switch this switch automatic when I manually switch the Sunscreen,
Can you help me out?
Posted: Wednesday 25 August 2021 22:32
by EdwinK
Make that switch, and in the script in the line with"
local manualOverrideSwitch = '[[Your Switch]]'
you the name of your switch.
Posted: Thursday 26 August 2021 7:45
by ricvee
I did make that virtual switch, but I don't understand how this switch is being triggered.
Posted: Thursday 26 August 2021 9:40
by waltervl
ricvee wrote: Thursday 26 August 2021 7:45
If you switch that virtual override switch manually to ON the script will stop controlling the sunscreens. If you switch it to OFF it will continue controlling the sunscreens.
return
Posted: Thursday 26 August 2021 13:11
by ricvee
Ok, thanks!
Posted: Friday 17 September 2021 15:36
by EdwinK
Again i have the problem that my sunscreen isn't working anymore.
This is my script (user @Rembo created it some time ago)
- Spoiler: show
local sensors = {
temperature = {
active = true,
wind = {
active = true,
device = 'Wind',
rain = {
active = true,
device = 'Rain',
rainExpected = {
active = true,
uv = {
active = true,
lux = {
active = true,
device = 'LUX',
-- local manualOverrideSwitch = 'Sunscreen - Manual'
local message = '.'
active = true,
logging = { level = domoticz.LOG_INFO,
-- FUNCTIONS
f:write("\r\n")
c=f:read("*line")
f:close()
f:write("\r\n")
f:close()
domoticz.log('Zonnescherm is al neer' , domoticz.LOG_INFO)
-- PROGRAM STARTS
return
return
return
Instead of a KaKu/CoCo switch I now use a Shelly 2.5 in roller/shutter mode. I made sure it had to correct name, but somehow I'm missing something.
Posted: Friday 17 September 2021 15:47
by waltervl
@EdwinK Hard to see what is wrong without knowing what you changed exactly.....
And is there an error shown? What is not working anymore?
Posted: Friday 17 September 2021 16:34
by EdwinK
The problem is that there are no errors shown. According to the log the screen is down, when it's not. I changed from KaKu to Shelly 2.5, changed the name of the device so that it is the same as with is in the script.
Status:
2021-09-17 16:25:00.683 Status: dzVents: Info: Sunscreen: ------ Start internal script: SunScreen:, trigger: "every minute"
2021-09-17 16:25:00.689 Status: dzVents: Info: Sunscreen: Zonnescherm is al neer
2021-09-17 16:25:00.689 Status: dzVents: Info: Sunscreen: ------ Finished SunScreen
2021-09-17 16:26:00.152 Status: dzVents: Info: Sunscreen: ------ Start internal script: SunScreen:, trigger: "every minute"
2021-09-17 16:26:00.159 Status: dzVents: Info: Sunscreen: Zonnescherm is al neer
So the script its self is working somehow it's just not lowering the screen.
Posted: Friday 17 September 2021 18:01
by waltervl
Did you check the state of the blinds switch in events? Open/Close, On/Off?
Do you use the same states to check?
Blinds Open/Close, On/Off could be the other way around.
Else log the states in extra debug logging to see what is going on.
