Problem with script sunscreen Topic is solved
EdwinK
Post by EdwinK »
Since sometime I've been using this script, created by user Rembo
-- Define all the sensors which needs to be considered for the sunscreen to close
local sensors = {
temperature = {
active = true,
device = 'Temperature', --'Buienradar - Temperature',
closeRule = function(device)
return device.temperature <= 19
wind = {
active = true,
device = 'Buienradar - Wind',
return device.speed >= 50 or device.gust >= 150
rain = {
active = true,
device = 'Rain',
return device.rainRate > 0
rainExpected = {
active = false,
device = 'IsItGonnaRain', -- This needs to be a virtual sensor of type 'percentage'
return device.percentage > 15
uv = {
active = false,
device = 'Wu - Uv',
return device.uv <= 2
lux = {
active = true,
device = 'LUX',
return device.lux <= 500
local sunscreenDevice = 'Sunscreen' -- Define the name of your sunscreen device
local dryRun = 'Y' -- Enable dry run mode to test the sunscreen script without actually activating the sunscreen
-- Define the name of a virtual switch which you can use to disable the sunscreen automation script, Set to false to disable this feature
local manualOverrideSwitch = 'Sunscreen - Manual'
local timeBetweenOpens = 10 -- Minutes to wait after a sunscreen close before opening it again.
local LogFile= '/home/pi/domoticz/Logs/Sunscreen.csv ~m.csv'
local LogAction = 'N'
local message = '.'
    active = true,
    on      =   {   timer   =   {'every minute'} },
    logging =   {   level   =   domoticz.LOG_DEBUG,
                    marker  =   'Sunscreen' },
    data    =   {   safedMessage = { initial = "-" } },
execute = function(domoticz)
    -- FUNCTIONS
    function LogActions()
        -- LogFile=string.gsub(LogFile,"~d",os.date("%Y-%m-%d"))
        LogFile=string.gsub(LogFile,"~m",os.date("%Y-%m"))
        if not My.File_exists(LogFile) then
            f=io.open(LogFile,"a")
            f:write("Datum ; Tijd ; dryRun ; Manual_or_Auto ; Message")
            f:write("\r\n")
            f=io.open(LogFile,"r")
            c=f:read("*line")
            f:close()
        if domoticz.data.safedMessage == message then
            domoticz.log("Same message skip write action",domoticz.LOG_DEBUG)
            domoticz.data.safedMessage = message
            f:write(os.date("%Y-%m-%d;%H:%M:%S") .. ";" .. dryRun .. ";" .. domoticz.devices(manualOverrideSwitch).state .. ";" .. message )
            f:write("\r\n")
        f:close()
    local function switchOn(sunscreen, message)
        if LogAction == 'Y' or LogAction == 'A' then LogActions() end
        if (sunscreen.state == 'Closed') then
            if dryRun == 'N' then
                sunscreen.switchOn()
                --domoticz.notify('Sunscreen', message)
            domoticz.log(message, domoticz.LOG_INFO)
            domoticz.log('Sunscreen is already down' , domoticz.LOG_INFO)
    local function switchOff(sunscreen, message)
        if (sunscreen.state == 'Open') then
                sunscreen.switchOff()
    -- PROGRAM STARTS
    if (manualOverrideSwitch and domoticz.devices(manualOverrideSwitch).state == 'On') then
        domoticz.log('Automatic sunscreen script is manually disabled', domoticz.LOG_DEBUG)
        return
    local sunscreen = domoticz.devices(sunscreenDevice)
    -- Sunscreen must always be up during nighttime
    if (domoticz.time.isNightTime) then
        message = 'Raising sunscreen, It is night'
        return
    -- Check all sensor tresholds and if any exeeded close sunscreen
    for sensorType, sensor in pairs(sensors) do
        if (sensor['active'] == true) then
            local device = domoticz.devices(sensor['device'])
            local closeRule = sensor['closeRule']
            domoticz.log('Checking sensor: ' .. sensorType, domoticz.LOG_DEBUG)
            if (closeRule(device)) then
                message = (sensorType .. ' treshold exceeded , Sunscreen up')
                switchOff(sunscreen, message )
                domoticz.log(message, domoticz.LOG_DEBUG)
                -- Return early when we exeed any tresholds
                return
            domoticz.log('Sensor not active skipping: ' .. sensorType, domoticz.LOG_DEBUG)
    -- All tresholds OK, sunscreen may be lowered
    if (sunscreen.lastUpdate.minutesAgo > timeBetweenOpens) then
        message = 'Sun is shining, all thresholds OK, lowering sunscreen'
It sued to be working. But now that the weather is getting in the higher regions I noticed that it didn't actually let the sunscreen raise/lower. I can however send the command directly from the dashboard and then it's working. But not automatically. But.. the log reads:
2019-05-23 19:27:00.314 Status: dzVents: Info: Sunscreen: ------ Start internal script: SunScreen:, trigger: every minute
2019-05-23 19:27:00.316 Status: dzVents: Debug: Sunscreen: Processing device-adapter for Sunscreen - Manual: Switch device adapter
2019-05-23 19:27:00.317 Status: dzVents: Debug: Sunscreen: Processing device-adapter for Sunscreen: Switch device adapter
2019-05-23 19:27:00.317 Status: dzVents: Debug: Sunscreen: Checking sensor: lux
2019-05-23 19:27:00.317 Status: dzVents: Debug: Sunscreen: Sensor not active skipping: uv
2019-05-23 19:27:00.318 Status: dzVents: Debug: Sunscreen: Processing device-adapter for Buienradar - Wind: Wind device adapter
2019-05-23 19:27:00.318 Status: dzVents: Debug: Sunscreen: Checking sensor: wind
2019-05-23 19:27:00.319 Status: dzVents: Debug: Sunscreen: Processing device-adapter for Temperature: Temperature device adapter
2019-05-23 19:27:00.319 Status: dzVents: Debug: Sunscreen: Checking sensor: temperature
2019-05-23 19:27:00.319 Status: dzVents: Debug: Sunscreen: Sensor not active skipping: rainExpected
2019-05-23 19:27:00.320 Status: dzVents: Debug: Sunscreen: Processing device-adapter for Rain: Rain device
2019-05-23 19:27:00.320 Status: dzVents: Debug: Sunscreen: Checking sensor: rain
2019-05-23 19:27:00.320 Status: dzVents: Info: Sunscreen: Sun is shining, all thresholds OK, lowering sunscreen
2019-05-23 19:27:00.320 Status: dzVents: Info: Sunscreen: ------ Finished SunScreen
So you would think it is working.
Re: Problem with script sunscreen
EdwinK wrote: Thursday 23 May 2019 19:29 Since sometime I've been using this script, created by user Rembo
It used to be working. But now that the weather is getting in the higher regions I noticed that it didn't actually let the sunscreen raise/lower. I can however send the command directly from the dashboard and then it's working. But not automatically. But.. the log reads:
local dryRun = 'Y' ?? -- Enable dry run mode to test the sunscreen script without actually activating the sunscreen
EdwinK
Post by EdwinK »
Damn.. Overlooked that one. Had it turned on to test somethings. Changed it back and screen was lowering it self right away.
Now trying to find a good rain percentage script and an UV one.
EdwinK
Post by EdwinK »
And now again it doesn't work well.
The script is executing, and tells met that the screen is down, but in fact it isn't. This time I checked if the dryrun is turned off,
local dryRun = 'N' -- Enable dry run mode to test the sunscreen script without actually activating the sunscreen
and also the switch in local manualOverrideSwitch = 'Sunscreen - Manual' is set to automatic.
the screen itself will be lowered when I click the button on the tablet. So,, also the KaKu device is working.
The script:
-- Define all the sensors which needs to be considered for the sunscreen to raise
local sensors = {
temperature = {
active = true,
device = 'TempHumBaro',
wind = {
active = true,
device = 'Wind',
rain = {
active = true,
device = 'Rain',
rainExpected = {
active = false,
device = 'BR Regen Percentage', -- This needs to be a virtual sensor of type 'percentage'
uv = {
active = true,
device = 'UV Index',
lux = {
active = true,
device = 'LUX',
local LogFile               = '/home/pi/domoticz/Logs/Sunscreen.csv ~m.csv'
local message               = '.'
    active = true,
    -- FUNCTIONS
            f:write("\r\n")
            c=f:read("*line")
            f:close()
            f:write("\r\n")
        f:close()
            domoticz.log('Zonnescherm is al uit' , domoticz.LOG_INFO)
    -- PROGRAM STARTS
        domoticz.log('Script is handmatig uitgezet', domoticz.LOG_DEBUG)
        return
        message = 'Zonneschermm omhoog, het is nacht'
        return
                message = (sensorType .. ' drempel overschreden , scherm omhoog')
                return
            domoticz.log('Sensor niet actief: ' .. sensorType, domoticz.LOG_DEBUG)
        message = 'Zon schijnt, drempels ok, scherm omlaag'
ricvee
Domoticz version: Stable
Post by ricvee »
About the switch in local manualOverrideSwitch = 'Sunscreen - Manual':
I made a Dummy switch Sunscreen - Manual, but how to make this work?
Do you connect this Dummy to the device Sunscreen as a Slave or something?
I do not understand how I can switch this switch automatic when I manually switch the Sunscreen,
Can you help me out?
EdwinK
Post by EdwinK »
Make that switch, and in the script in the line with"
local manualOverrideSwitch = '[[Your Switch]]'
you the name of your switch.
ricvee
Post by ricvee »
I did make that virtual switch, but I don't understand how this switch is being triggered.
Domoticz version: 2024.7
ricvee wrote: Thursday 26 August 2021 7:45 I did make that virtual switch, but I don't understand how this switch is being triggered.
If you switch that virtual override switch manually to ON the script will stop controlling the sunscreens. If you switch it to OFF it will continue controlling the sunscreens.
        return
ricvee
Post by ricvee »
Ok, thanks!
EdwinK
Post by EdwinK »
Again i have the problem that my sunscreen isn't working anymore.
This is my script (user @Rembo created it some time ago)
local sensors = {
temperature = {
active = true,
wind = {
active = true,
device = 'Wind',
rain = {
active = true,
device = 'Rain',
rainExpected = {
active = true,
uv = {
active = true,
lux = {
active = true,
device = 'LUX',
-- local manualOverrideSwitch = 'Sunscreen - Manual'
local message = '.'
active = true,
logging = { level = domoticz.LOG_INFO,
-- FUNCTIONS
f:write("\r\n")
c=f:read("*line")
f:close()
f:write("\r\n")
f:close()
domoticz.log('Zonnescherm is al neer' , domoticz.LOG_INFO)
-- PROGRAM STARTS
return
return
return
Instead of a KaKu/CoCo switch I now use a Shelly 2.5 in roller/shutter mode. I made sure it had to correct name, but somehow I'm missing something.
@EdwinK Hard to see what is wrong without knowing what you changed exactly.....
And is there an error shown? What is not working anymore?
EdwinK
Post by EdwinK »
The problem is that there are no errors shown. According to the log the screen is down, when it's not. I changed from KaKu to Shelly 2.5, changed the name of the device so that it is the same as with is in the script.
Status:
2021-09-17 16:25:00.683 Status: dzVents: Info: Sunscreen: ------ Start internal script: SunScreen:, trigger: "every minute"
2021-09-17 16:25:00.689 Status: dzVents: Info: Sunscreen: Zonnescherm is al neer
2021-09-17 16:25:00.689 Status: dzVents: Info: Sunscreen: ------ Finished SunScreen
2021-09-17 16:26:00.152 Status: dzVents: Info: Sunscreen: ------ Start internal script: SunScreen:, trigger: "every minute"
2021-09-17 16:26:00.159 Status: dzVents: Info: Sunscreen: Zonnescherm is al neer
So the script its self is working somehow it's just not lowering the screen.
Did you check the state of the blinds switch in events? Open/Close, On/Off?
Do you use the same states to check?
Blinds Open/Close, On/Off could be the other way around.
Else log the states in extra debug logging to see what is going on.
