TKB HOME Z-Wave Plus Wall Thermostat TZE93.716
AimoPaukku
Domoticz version: Stable
Post by AimoPaukku »
I have latest beta and i cant get this thermostat function properly...
In harware this: Unknown: id=0118 Unknown: type=0311, id=0505+
In devices:
Thermostat SetPoint - 0 degrees (does not update to/from device)
General Thermostat Mode - Off (turns device on and off properly)
Thermostat Clock - Monday 12:58 (does not update to/from device)
My knowledge stops here, what can i do next?
AimoPaukku
Re: TKB HOME Z-Wave Plus Wall Thermostat TZE93.716
Im starting to be pretty desperate… Is there anyone who can help me?
I have a house with a many floor heaters and i cant find any reasonable priced thermostat working with domoticz.
All info i can find is in this pdf
http://www.tkbhome.com/upimg/file/1127231680855.pdf
chrisfraser05
Post by chrisfraser05 »
did you get anywhere with it?
AimoPaukku
No, i hope something appears before winter...
Plarp
Post by Plarp »
I got it working, sortoff.
I created a config file for TKB Home TZE93 and placed it inside the folder .../config/wenzhou.
Then i edited the file manufacturer_specific.xml and added line <Product type="0311" id="0505" name="TZE93 Heating Thermostat" config="wenzhou/tze93.xml"/> under <Manufacturer id="0118" name="TKB Home">.
I attached my device xml file to this post, hope it helps. It is not perfect but i got my thermostats working. Remember to backup files before you make anychanges.
tze93.xml
TKB Home TZE93.xxx device file
(2.69 KiB) Downloaded 126 times
