Page 1 of 3
Upload gas usage to mindergas.nl
Posted: Sunday 19 May 2019 20:02
by roblom
So this is my first dzvents script ever, what do you think of it? Please give some feedback.
It collects the gas usage from the smartmeter and uploads it to the mindergas.nl database.
/home/pi/domoticz/scripts/dzVents/scripts/upload_gas_usage_to_minderGas.lua
Author : Roblom
Description : This script collects the gas values from Domoticz (for example from the smart meter) and uploads the values to a MinderGas account.
For more information about MinderGas, see the API instructions on their website on https://mindergas.nl/member/api
local AUTH_TOKEN = 'xxxxxxxxxxxxxx' -- Fill in here your Mindergas authentication token
active = true,
--timer = {'at 00:05'},
timer = {'every minute'},
httpResponses = {'UploadToMindergas'}
logging = {
level = domoticz.LOG_DEBUG,
marker = 'Mindergas'
if item.isTimer then
local GasUsageCounter = domoticz.devices('Gas (P1)').counter
local TodaysDate = tostring(domoticz.time.rawDate)
domoticz.log('The gas usage is ' .. GasUsageCounter, domoticz.LOG_INFO)
domoticz.log('The date is ' .. TodaysDate, domoticz.LOG_INFO )
domoticz.openURL({
url = 'https://www.mindergas.nl/api/gas_meter_readings',
method = 'POST',
headers = {
['Content-Type'] = 'application/json',
['AUTH-TOKEN'] = AUTH_TOKEN
callback = 'UploadToMindergas',
postData = {
['date'] = TodaysDate,
['reading'] = GasUsageCounter
elseif (item.isHTTPResponse) then
if (item.statusCode == 201) then
domoticz.log('Gas usage data is sucessfully upoaded to Mindergas.nl.', domoticz.LOG_INFO)
if (item.statusCode == 401) then
domoticz.log('There was an authorisation problem with the Mindergas.nl database.', domoticz.LOG_ERROR)
if (item.statusCode == 422) then
domoticz.log('There was an unprocessable enrty while trying to upload the gas usage data to Mindergas.nl', domoticz.LOG_ERROR)
domoticz.notify('Domoticz error', 'An error occured while trying to upload the gas usage data to Mindergas.nl', PRIORITY_NORMAL)
Re: Upload gas usage to mindergas.nl
Posted: Sunday 19 May 2019 22:05
by waaren
roblom wrote: Sunday 19 May 2019 20:02
@robblom, my compliments; looking good.
some small not important remarks:
You included your Mindergas authentication token as plain text in your script. What you could do is to put the token in a domoticz uservariable and read that during the execution of the script. In that way the token is not direct readable n the script. You could even make it really fancy if you store the key encoded en decode it during execution. Many examples to encode / decode in Lua can be found on the internet.
is excellent. Could be replaced by
if item.ok then -- self.statusCode >= 200 and self.statusCode <= 299
to test for a more generic statsusCode to reflect success.
You use the string "trigger" to trigger the script on the openURL callback. If you develop more scripts you might want to use a more distinctive name.
Posted: Sunday 19 May 2019 22:41
by roblom
Thanks for the compliments, it's not that complicated script but was a good example to learn dzVents. As I'm no programmer at all I'm learning through trial and error but have good autodidact skills and dzVents is quite easy to learn.
About the authentication token, I removed it from the above example, thanks for pointing out.
but putting it in a user variable is of course an option, but would this be a real advantage in security purpose? Because a user variable is also readable in domoticz GUI itself.
The statusCode that are described in the mindergas API are only 201, 401 and 422 so therefore I only put in those. If the status is not 201, 401 or 422 there will be send a notification for extra attention.
The 'trigger' name is indeed not that distinctive, changed that to 'UploadToMindergas'.
Again, thanks for the feedback, quite useful!
Posted: Sunday 19 May 2019 23:27
by waaren
roblom wrote: Sunday 19 May 2019 22:41
True if you edit and save your scripts via the internal event editor. I am used to an external editor and do not store my scripts in the database. So if you encrypt / decrypt the value in the uservariable, users with access to the gui and without access to the OS file system would not be able to see the decrypted api-key; but I doubt if there is a really secure way to handle a situation where the api-key need to be part of the url.
Posted: Monday 20 May 2019 20:42
by roblom
I also use a external editor (Notepad++). As I don't find it a big security issue, I leave it as it is for now. Thanks for your feedaback.
Posted: Tuesday 21 May 2019 8:39
by EdwinK
Looks great, but
2019-05-21 08:36:01.238 Status: dzVents: Info: Handling httpResponse-events for: "UploadToMindergas
2019-05-21 08:36:01.238 Status: dzVents: Info: Mindergas: ------ Start internal script: Minder Gas: HTTPResponse: "UploadToMindergas"
2019-05-21 08:36:01.238 Status: dzVents: Error (2.4.21): Mindergas: HTTP/1.1 response: 422 ==>> Unprocessable Entity
2019-05-21 08:36:01.238 Status: dzVents: Error (2.4.21): Mindergas: There was an unprocessable enrty while trying to upload the gas usage data to Mindergas.nl
2019-05-21 08:36:01.238 Status: dzVents: Info: Mindergas: ------ Finished Minder Gas
2019-05-21 08:37:00.582 Status: dzVents: Info: Mindergas: ------ Start internal script: Minder Gas:, trigger: every minute
2019-05-21 08:37:00.582 Status: dzVents: Info: Mindergas: The gas usage is 1184.658
2019-05-21 08:37:00.582 Status: dzVents: Info: Mindergas: The date is 2019-05-21
2019-05-21 08:37:00.587 Status: dzVents: Debug: Mindergas: OpenURL: url =
2019-05-21 08:37:00.587 Status: dzVents: Debug: Mindergas: OpenURL: method = POST
2019-05-21 08:37:00.587 Status: dzVents: Debug: Mindergas: OpenURL: post data = {"date":"2019-05-21","reading":1184.658}
2019-05-21 08:37:00.587 Status: dzVents: Debug: Mindergas: OpenURL: headers = {["Content-Type"]="application/json", ["AUTH-TOKEN"]="WdC_oA8VqqLjB6ijYmzC"}
2019-05-21 08:37:00.587 Status: dzVents: Debug: Mindergas: OpenURL: callback = UploadToMindergas
2019-05-21 08:37:00.587 Status: dzVents: Info: Mindergas: ------ Finished Minder Gas
Posted: Tuesday 21 May 2019 8:46
by EdwinK
It seems the meter is updated at mindergas.nl, just throwing an error in the logs.
Posted: Tuesday 21 May 2019 10:56
by waaren
EdwinK wrote: Tuesday 21 May 2019 8:46
Could it be that this entry is already at mindergas ? That would also generate this returnCode
Posted: Tuesday 21 May 2019 11:29
by roblom
waaren wrote: Tuesday 21 May 2019 10:56
That is correct, the 422 error is
422 Unprocessable Entity
Er is een validatiefout opgetreden. Dit kan komen door:
Er is al een meterstand voor de opgegeven datum.
De meterstand is geen getal.
De meterstand is kleiner dan de vorige meterstand.
De meterstand is groter dan de volgende meterstand.
De datum ligt in de toekomst.
De datum ligt voor 31 december 2005.
So if you say the data is uploaded in the mindergas database then the 422 error is because you try to put in the same values that are already in. So when you change the script to that it is only running once a day, you have no errors anymore.
Posted: Tuesday 21 May 2019 19:22
by EdwinK
Okay. Will change the script to run less often. Thanks
Posted: Tuesday 21 May 2019 22:58
by Tukker
And can you upload the finished script too?
It's very interesting.
To get results that can be compared over the years (I'm on mindergas since 2013) I will upload it once a moth and as from now it'll be automagic upload!
Posted: Thursday 24 October 2019 0:39
by maxtrash
Thanks, works like a charm.
Posted: Friday 25 October 2019 20:25
by BOverdevest
maxtrash wrote: Thursday 24 October 2019 0:39
indeed and thanks for pushing this topic to the top again, or I would have missed this one...
Posted: Tuesday 29 October 2019 18:29
by jandahmen
pls publish the last good working script, so we can learn too. regards jan dahmen
Posted: Tuesday 05 November 2019 22:16
by BOverdevest
jandahmen wrote: Tuesday 29 October 2019 18:29
See post #1, worked for me, with some adjustment to make it work on my system.
Author : Roblom
active = true,
--timer = {'every minute'},
httpResponses = {'UploadToMindergas'}},
logging = { level = domoticz.LOG_ERROR, marker = 'Mindergas' },
local GasUsageCounter = domoticz.devices('P1GasMeterStand').counter
domoticz.openURL({
method = 'POST',
headers = {
postData = {
local SubSystem = domoticz.NSS_TELEGRAM
local Priority = domoticz.PRIORITY_NORMAL
local Sound = domoticz.SOUND_DEFAULT
local Tittle = "MinderGas - "
local Message = "Geen idee :" .. item.statusCode
if (item.statusCode == 201) then Message ='Gas usage data is sucessfully upoaded.'
elseif (item.statusCode == 401) then Message = 'There was an authorisation problem with the Mindergas.nl database.'
elseif (item.statusCode == 422) then Message = 'There was an unprocessable enrty while trying to upload the gas usage data to Mindergas.nl'
domoticz.log(Message, domoticz.LOG_INFO)
domoticz.notify(Tittle,Message,Priority,Sound,"",SubSystem)
De volgende HTTP status codes worden geretourneerd:
201 Created
De meterstand is succesvol verwerkt en opgeslagen.
401 Unauthorized
Het authenticatietoken is ongeldig of zit niet in de request.
Posted: Friday 12 June 2020 15:09
by Akerboom
thanks for the script!
Posted: Tuesday 17 November 2020 15:27
by dutchronnie
I do use this script some time without any problems.
But since a few days the readings are not uploaded anymore, and do i get the this error
I didn't change anything, but is is not working anymore.
Does sombody know what the problem could be?
Author : Roblom
local AUTH_TOKEN = 'KKgjpoiJJeJPG'kjhgf' -- Fill in here your Mindergas authentication token
active = true,
logging = {
domoticz.openURL({
method = 'POST',
headers = {
postData = {
Posted: Tuesday 17 November 2020 15:38
by waaren
dutchronnie wrote: Tuesday 17 November 2020 15:27
"An error occured while trying to upload the gas usage data to Mindergas.nl',"
If you insert below line directly after line 61 it will show some potential useful information
domoticz.log(item, domoticz.LOG_FORCE)
Re: Upload gas usage to mindergas.nl [Solved]
Posted: Tuesday 17 November 2020 19:23
by dutchronnie
I added the line in the script, i hope i can see it tommorow.
I found the following rules in the log file from domoticz
2020-11-15 00:03:01.237 Error: dzVents: Error: (3.0.16) Mindergas: HTTP/1.1 response: 401 ==>> Unauthorized
2020-11-15 00:03:01.238 Error: dzVents: Error: (3.0.16) Mindergas: There was an authorisation problem with the Mindergas.nl database.
2020-11-16 00:05:01.755 Error: dzVents: Error: (3.0.16) Mindergas: HTTP/1.1 response: 401 ==>> Unauthorized
2020-11-16 00:05:01.755 Error: dzVents: Error: (3.0.16) Mindergas: There was an authorisation problem with the Mindergas.nl database.
2020-11-17 00:05:01.694 Error: dzVents: Error: (3.0.16) Mindergas: HTTP/1.1 response: 401 ==>> Unauthorized
2020-11-17 00:05:01.694 Error: dzVents: Error: (3.0.16) Mindergas: There was an authorisation problem with the Mindergas.nl database.
Authorisation problem, strange. i checked the api, but it is alright.
On mindergas i can add the values to the database by hand, so there is nothing wrong with the database.
Posted: Monday 30 November 2020 17:43
by alpafranken
dutchronnie wrote: Tuesday 17 November 2020 19:23
The problem is your local AUTH_TOKEN = 'KKgjpoiJJeJPG'kjhgf' your token has an ' in it which causes the variable to malfunction.
