Trigger was another topic on this site. https://www.domoticz.com/forum/viewtopi ... RL#p184824
So this is a rebuild from that script. But is does a good job.. Maybe it could be better...
-- status fijnstofmeter.lua
myHttpResponse = "getDomoticzErrorLog"
on = { httpResponses = { myHttpResponse },
timer = { "every 5 minutes"},
-- devices = { "getErrorTrigger"} -- Only used for development and testing
logging = { level = domoticz.LOG_INFO,
marker = " status http://192.168.xx.xx/data.json" },
data = { lastlogtime = { initial = 0 }},
execute = function(dz, trigger)
local violationMessage = "Error opening url: http://192.168.1.41/data.json" -- Change to reflect the messages you want to catch
local function askDomoticzForLogLines()
local lastLogTime = dz.data.lastlogtime -- get time last logrequest
local logLevel = 4 -- loglevel (1=normal,2=Status,4=error,268435455=all
local jsonString = "/json.htm?type=command" ..
"¶m=getlog" ..
"&lastlogtime=" .. tostring(lastLogTime) ..
"&loglevel=" .. tostring(logLevel)
local logURL = dz.settings["Domoticz url"] .. jsonString
dz.openURL ({ url = logURL,
method = "GET",
callback = myHttpResponse
dz.data.lastlogtime = os.time(os.date('*t')) -- store current Time as seconds from epoch
dz.log(logURL,dz.LOG_DEBUG)
local function findViolation()
local violation = ""
if trigger.json.result ~= nil then -- Only when there are errormessages in the log
local resultTable = trigger.json.result
for i = #resultTable,1,-1 do -- traverse backwards to get latest violation first
if string.find(resultTable[i].message,violationMessage) and
not(string.find(resultTable[i].message,"dzVents")) then -- We don't want debug messages to interfere
violation = violation .. "\n".. resultTable[i].message
return violation
if trigger.isDevice or trigger.isTimer then
askDomoticzForLogLines() -- get the relevant loglines
elseif trigger.ok then
local violation = findViolation()
if violation == "" then
dz.log("No (new) violations found",dz.LOG_DEBUG)
dz.log("violation(s) found: " .. violation,dz.LOG_INFO)
dz.notify("fijnstofmeter offline!!",violation, dz.PRIORITY_NORMAL,nil,nil,dz.NSS_PUSHOVER)
dz.log("Access problem to log",dz.LOG_ERROR)
