Issues with Fibaro Dimmer 2
jadijkstra2000
Post by jadijkstra2000 »
I have a strange thing with one of my dimmers (I have more...). All dimmers work fine in Domoticz, that is not an issue, but when I push the button on the wall, one light goes always to maximum (100%) output, dim function through the push button works, but when I turn the light off and then on again, it starts at 100% again,...al my other Dimmer2 dimmers don't have this issue...
Any thoughts about this?
ksacca
Re: Issues with Fibaro Dimmer 2
Post by ksacca »
If you check the node configuration of this dimmer, what is set in parameter "19. Forced switch on brightness level"?
This should be set to 0, otherwise the brightness level will always be set to a specific value when using your wall switch.
jadijkstra2000
Yes I did, it is 0...
jadijkstra2000
Dimmer2 has an other problem.
With the switch I only can turn on to max, or min, not something in between.
So, dimming with the switch is not possible. However, the last dimming percentage is stored...
I can dim with Domoticz, no problem....
