preserve custom SSL certificate when updating
Posted: Tuesday 14 May 2019 10:04
by Hielkep
When i use my own SSL certificate in domoticz, the certificate is overwritten by the deafult one when using ./updatebeta command.
could there be an extra line added to updatebeta (and updaterelease) that copies an own certificate over the selfsigned one?
suggestion: when file custom_server_certificate.pem exists, then copy that one to server_certificate.pem.
or more work:
implement adding custom certificate in domoticz settings page
Re: preserve custom SSL certificate when updating
Posted: Monday 28 October 2019 7:56
by PHIL63
Sorry to dig up an old subject, but it's painful in the long run to hand in the certificate every time.
If there is a way to not install the domoticz certificate when updating beta install.....
In Windows installation program adding a flag like "IfNotExists" on the installation line in Inno Setup for example.
Same thing on the Raspbian install if possible :)
Posted: Tuesday 12 November 2019 4:28
by tobydeteckel
Just edit the "domoticz.sh" file in "/etc/init.d" map.
add..
DAEMON_ARGS="$DAEMON_ARGS -sslcert /home/server/domoticz/server_cert1.pem"
and save your certificate named "server_cert1.pem"
when domoticz update the "server_cert1.pem" file wont be touched.
hopefully this will help you.
Posted: Tuesday 12 November 2019 6:12
by PHIL63
Thanks for this solution :)
Posted: Tuesday 12 November 2019 23:23
by tobydeteckel
Youre Welcome!
