preserve custom SSL certificate when updating
Hielkep
Post by Hielkep »
When i use my own SSL certificate in domoticz, the certificate is overwritten by the deafult one when using ./updatebeta command.
could there be an extra line added to updatebeta (and updaterelease) that copies an own certificate over the selfsigned one?
suggestion: when file custom_server_certificate.pem exists, then copy that one to server_certificate.pem.
or more work:
implement adding custom certificate in domoticz settings page
PHIL63
Re: preserve custom SSL certificate when updating
Post by PHIL63 »
Sorry to dig up an old subject, but it's painful in the long run to hand in the certificate every time.
If there is a way to not install the domoticz certificate when updating beta install.....
In Windows installation program adding a flag like "IfNotExists" on the installation line in Inno Setup for example.
Same thing on the Raspbian install if possible :)
tobydeteckel
Domoticz version: V12461
Post by tobydeteckel »
Just edit the "domoticz.sh" file in "/etc/init.d" map.
add..
DAEMON_ARGS="$DAEMON_ARGS -sslcert /home/server/domoticz/server_cert1.pem"
and save your certificate named "server_cert1.pem"
when domoticz update the "server_cert1.pem" file wont be touched.
hopefully this will help you.
PHIL63
Post by PHIL63 »
Thanks for this solution :)
tobydeteckel
Youre Welcome!
