Sunscreen script v0.02
Posted: Friday 27 June 2014 11:23
Together with a friend I developed a Sunscreen script that checks the weather conditions and automate the screen.
Of course the script must be configured for your settings and device names (begin of script). But maybe you can use some parts.
Variable / Thresholds declaration.
Reading weather underground devices.
Split values from these devices.
Calculate results with thresholds
Log results to Domoticz log
Check if manual Override is active:
- Less than x minutes
- Only during Daytime or Always
When screen is Up/Open:
- Don't close it within x minutes after open
- Close screen
- Optional Log to log file (conditions and results)
- Optional Send Telegram notification
When screen is Down/Closed:
- Open screen
This is a first release. If interesting I will post new versions.
Suggestions are Welcome.
- Close screen
- Open screen
-- Time_Sunscreen
-- Check the weather conditions with Weather Underground for controlling the suncreen.
-- Release note
-- 14-06-2014 Redesigned for generic use
-- 17-06-2014 Include a Temperature condition
-- Manual override setting for daytime only
-- 26-06-2014 Optional waiting time after open
-- Option for logging to log file
-- Variable
Version = 0.021
Version_Type = 'Beta'
TH_Wind = 30 -- Treshold wind
TH_Gust = 50 -- Treshold windstoten
TH_Rain = 0 -- Treshold regen/neerslag
TH_Uv_Close = 2.5 -- treshold voor Uv close
TH_Uv_Open = 1.2 -- treshold voor Uv open
TH_Tp_Close = 20 -- treshold voor Temperature close
TH_Tp_Open = 15 -- treshold voor Temperature close
ActionClose = 'On'
ActionOpen = 'Off'
ManualTime = 'D' -- D=Daytime / A=All
Debugging = 'Y'
Man_to_Auto = 240 -- Minutes manual override
SwitchTime = 10
LogAction = 'Y' -- A=All, Y=Only on change
LogFile = '/home/pi/domoticz/Log/Sunscreen.log'
DeviceName = 'Sunscreen'
DeviceManual = 'Sunscreen - Manual'
TelegramName = 'Leon_Mol'
-- Retrieve values from devices
Wu_Dev_Temp = otherdevices_svalues['WU Temperature']
Wu_Dev_Rain = otherdevices_svalues['WU Rain']
Wu_Dev_UvMe = otherdevices_svalues['WU UV']
print ("______________________________________________________________________")
print (">> Sunscreen LUA Contitions.....v" .. Version .. "....." .. Version_Type)
-- Split values from devices
Part=1
for match in (Wu_Dev_Temp..';'):gmatch("(.-)"..';') do
if Part==3 then Wu_Wind = tonumber(match) end
if Part==4 then Wu_Gust = tonumber(match) end
if Part==5 then Wu_Temp = tonumber(match) end
Part=Part+1
Part=1
for match in (Wu_Dev_Rain..';'):gmatch("(.-)"..';') do
if Part==2 then Wu_Rain = tonumber(match) end
Part=Part+1
Part=1
for match in (Wu_Dev_UvMe ..';'):gmatch("(.-)"..';') do
if Part==1 then Wu_Uv = tonumber(match) end
Part=Part+1
if LogAction=='Y' or LogAction=='A' then
f=io.open(LogFile,"a")
-- Calculate pre results
if (timeofday['Daytime']) then Res_Dayl=1 else Res_Dayl=0 end
if Wu_Wind <= TH_Wind then Res_Wind=1 else Res_Wind=0 end
if Wu_Gust <= TH_Gust then Res_Gust=1 else Res_Gust=0 end
if Wu_Rain <= TH_Rain then Res_Rain=1 else Res_Rain=0 end
if Wu_Uv >= TH_Uv_Close then Res_UvCl=1 else Res_UvCl=0 end
if Wu_Temp >= TH_Tp_Close then Res_TpCl=1 else Res_TpCl=0 end
if Wu_Uv <= TH_Uv_Open then Res_UvOp=1 else Res_UvOp=0 end
if Wu_Temp <= TH_Tp_Open then Res_TpOp=1 else Res_TpOp=0 end
-- Print decision info in the log
print ( "These conditions are valid when sunscreen is up: " )
print ( Res_Dayl .. " - Daytime : True" )
print ( Res_Dayl .. " - Daytime : False" )
print ( Res_Wind .. " - Wind : " .. Wu_Wind .. " <= Th : " .. TH_Wind )
print ( Res_Gust .. " - Gust : " .. Wu_Gust .. " <= Th : " .. TH_Gust )
print ( Res_Rain .. " - Rain : " .. Wu_Rain .. " <= Th : " .. TH_Rain )
print ( Res_UvCl .. " - UV Close : " .. Wu_Uv .. " >= Th : " .. TH_Uv_Close )
print ( Res_TpCl .. " - Temp Close : " .. Wu_Temp .. " >= Th : " .. TH_Tp_Close )
print ( "These conditions are valid when sunscreen is down: " )
print ( Res_UvOp .. " - UV Open : " .. Wu_Uv .. " <= Th : " .. TH_Uv_Open )
print ( Res_TpOp .. " - Temp Open : " .. Wu_Temp .. " <= Th : " .. TH_Tp_Open )
-- Manual override for x minutes
if (otherdevices[DeviceManual]) == 'On' then
now = os.date("*t")
T1 = os.time(now)
Man_to_Auto = Man_to_Auto * 60
s = otherdevices_lastupdate[DeviceManual]
year = string.sub(s, 1, 4)
month = string.sub(s, 6, 7)
day = string.sub(s, 9, 10)
hour = string.sub(s, 12, 13)
T2 = os.time{year=year, month=month, day=day, hour=hour, min=minutes, sec=seconds}
if os.difftime (T1,T2) > Man_to_Auto then
commandArray[DeviceManual] = 'Off'
if ManualTime~="D" and Res_Dayl==0 then
-- Outside daytime period, turn manual override off
if (otherdevices[DeviceName]) == 'Open' then
print ("Current state: Up / Open")
if Res_Dayl + Res_Wind + Res_Gust + Res_Rain + Res_UvCl + Res_TpCl == 6 then
print ("Sunscreen Manual")
t1 = os.time()
s = otherdevices_lastupdate[DeviceName]
difference = (os.difftime (t1, t2))
if difference <= SwitchTime then
print ("Recent open, wait for switchtime")
-- Close
print ("Action: Down / Close")
commandArray[DeviceName] = ActionClose
f:write(os.date("%Y-%m-%d;%H:%M:%S") .. ";DOWN;" .. Version .. ";" .. Res_Dayl .. ";" .. Res_Wind .. ";" .. Res_Gust .. ";" .. Res_Rain .. ";" .. Res_UvCl .. ";" .. Res_TpCl .. ";" .. Res_UvOp .. ";" .. Res_TpOp .. ";" .. Wu_Wind .. ";" .. Wu_Gust .. ";" .. Wu_Rain .. ";" .. Wu_Uv .. ";" .. Wu_Temp)
f:write("\n")
if TelegramName == nil then else
-- Telegram notification for close
os.execute('su pi ./home/pi/domoticz/scripts/lua/Telegram.sh ' .. TelegramName .. ' "Sunscreen closed."')
print ("Action: None")
if (otherdevices[DeviceName]) == 'Closed' then
print ("Current state: Down / Closed")
if Res_Dayl + Res_Wind + Res_Gust + Res_Rain < 4 or Res_UvOp==1 or Res_TpOp==1 then
-- Open
print ("Action: Up / Open")
commandArray[DeviceName] = ActionOpen
f:write(os.date("%Y-%m-%d;%H:%M:%S") .. ";OPEN;" .. Version .. ";" .. Res_Dayl .. ";" .. Res_Wind .. ";" .. Res_Gust .. ";" .. Res_Rain .. ";" .. Res_UvCl .. ";" .. Res_TpCl .. ";" .. Res_UvOp .. ";" .. Res_TpOp .. ";" .. Wu_Wind .. ";" .. Wu_Gust .. ";" .. Wu_Rain .. ";" .. Wu_Uv .. ";" .. Wu_Temp)
f:write("\n")
-- Telegram notification for open
os.execute('su pi ./home/pi/domoticz/scripts/lua/Telegram.sh ' .. TelegramName .. ' "Sunscreen open."')
print (" Action: None")
if LogAction=='A' then
f:write(os.date("%Y-%m-%d;%H:%M:%S") .. ";IDLE;" .. Version .. ";" .. Res_Dayl .. ";" .. Res_Wind .. ";" .. Res_Gust .. ";" .. Res_Rain .. ";" .. Res_UvCl .. ";" .. Res_TpCl .. ";" .. Res_UvOp .. ";" .. Res_TpOp .. ";" .. Wu_Wind .. ";" .. Wu_Gust .. ";" .. Wu_Rain .. ";" .. Wu_Uv .. ";" .. Wu_Temp)
f:write("\n")
f:close()
