Sunscreen script v0.02
MrFrankie
Domoticz version: V2.2585
Post by MrFrankie »
Together with a friend I developed a Sunscreen script that checks the weather conditions and automate the screen.
Of course the script must be configured for your settings and device names (begin of script). But maybe you can use some parts.
Variable / Thresholds declaration.
Reading weather underground devices.
Split values from these devices.
Calculate results with thresholds
Log results to Domoticz log
Check if manual Override is active:
- Less than x minutes
- Only during Daytime or Always
When screen is Up/Open:
- Don't close it within x minutes after open
- Close screen
- Optional Log to log file (conditions and results)
- Optional Send Telegram notification
When screen is Down/Closed:
- Open screen
This is a first release. If interesting I will post new versions.
Suggestions are Welcome.
-- Time_Sunscreen
-- Check the weather conditions with Weather Underground for controlling the suncreen.
-- Release note
-- 14-06-2014  Redesigned for generic use
-- 17-06-2014  Include a Temperature condition
--             Manual override setting for daytime only
-- 26-06-2014  Optional waiting time after open
--             Option for logging to log file
--      Variable
Version       = 0.021
Version_Type  = 'Beta'
TH_Wind       = 30      -- Treshold wind
TH_Gust       = 50      -- Treshold windstoten
TH_Rain       = 0           -- Treshold regen/neerslag
TH_Uv_Close   = 2.5          -- treshold voor Uv close
TH_Uv_Open    = 1.2          -- treshold voor Uv open
TH_Tp_Close   = 20          -- treshold voor Temperature close
TH_Tp_Open    = 15          -- treshold voor Temperature close
ActionClose   = 'On'
ActionOpen    = 'Off'
ManualTime    = 'D'             -- D=Daytime / A=All
Debugging     = 'Y'
Man_to_Auto   = 240             -- Minutes manual override
SwitchTime    = 10
LogAction     = 'Y'             -- A=All, Y=Only on change
LogFile       = '/home/pi/domoticz/Log/Sunscreen.log'
DeviceName    = 'Sunscreen'
DeviceManual  = 'Sunscreen - Manual'
TelegramName  = 'Leon_Mol'
-- Retrieve values from devices
Wu_Dev_Temp = otherdevices_svalues['WU Temperature']
Wu_Dev_Rain = otherdevices_svalues['WU Rain']
Wu_Dev_UvMe = otherdevices_svalues['WU UV']
print ("______________________________________________________________________")
print (">> Sunscreen LUA Contitions.....v" .. Version .. "....." .. Version_Type)
-- Split values from devices
Part=1
for match in (Wu_Dev_Temp..';'):gmatch("(.-)"..';') do
   if Part==3 then Wu_Wind = tonumber(match) end
   if Part==4 then Wu_Gust = tonumber(match) end
   if Part==5 then Wu_Temp = tonumber(match) end
   Part=Part+1
Part=1
for match in (Wu_Dev_Rain..';'):gmatch("(.-)"..';') do
   if Part==2 then Wu_Rain = tonumber(match) end
   Part=Part+1
Part=1
for match in (Wu_Dev_UvMe ..';'):gmatch("(.-)"..';') do
   if Part==1 then Wu_Uv = tonumber(match) end
   Part=Part+1
if LogAction=='Y' or LogAction=='A' then
   f=io.open(LogFile,"a")
-- Calculate pre results
if (timeofday['Daytime'])   then Res_Dayl=1 else Res_Dayl=0 end
if Wu_Wind <= TH_Wind       then Res_Wind=1 else Res_Wind=0 end
if Wu_Gust <= TH_Gust       then Res_Gust=1 else Res_Gust=0 end
if Wu_Rain <= TH_Rain       then Res_Rain=1 else Res_Rain=0 end
if Wu_Uv   >= TH_Uv_Close   then Res_UvCl=1 else Res_UvCl=0 end
if Wu_Temp >= TH_Tp_Close   then Res_TpCl=1 else Res_TpCl=0 end
if Wu_Uv   <= TH_Uv_Open    then Res_UvOp=1 else Res_UvOp=0 end
if Wu_Temp <= TH_Tp_Open    then Res_TpOp=1 else Res_TpOp=0 end
-- Print decision info in the log
print ( "These conditions are valid when sunscreen is up: " )
   print (  Res_Dayl .. " - Daytime   : True" )
   print (  Res_Dayl .. " - Daytime   : False" )
print ( Res_Wind .. " - Wind        : " .. Wu_Wind .. " <= Th : " .. TH_Wind )
print ( Res_Gust .. " - Gust        : " .. Wu_Gust .. " <= Th : " .. TH_Gust )
print ( Res_Rain .. " - Rain        : " .. Wu_Rain .. " <= Th : " .. TH_Rain )
print ( Res_UvCl .. " - UV Close    : " .. Wu_Uv   .. " >= Th : " .. TH_Uv_Close )
print ( Res_TpCl .. " - Temp Close  : " .. Wu_Temp .. " >= Th : " .. TH_Tp_Close )
print ( "These conditions are valid when sunscreen is down: " )
print ( Res_UvOp .. " - UV Open     : " .. Wu_Uv   .. " <= Th : " .. TH_Uv_Open )
print ( Res_TpOp .. " - Temp Open   : " .. Wu_Temp .. " <= Th : " .. TH_Tp_Open )
-- Manual override for x minutes
if (otherdevices[DeviceManual]) == 'On' then
   now = os.date("*t")
        T1  = os.time(now)
   Man_to_Auto = Man_to_Auto * 60
   s = otherdevices_lastupdate[DeviceManual]
        year = string.sub(s, 1, 4)
        month = string.sub(s, 6, 7)
        day = string.sub(s, 9, 10)
        hour = string.sub(s, 12, 13)
        T2 = os.time{year=year, month=month, day=day, hour=hour, min=minutes, sec=seconds}
   if os.difftime (T1,T2) > Man_to_Auto then
   commandArray[DeviceManual] = 'Off'
        if ManualTime~="D" and Res_Dayl==0 then
        -- Outside daytime period, turn manual override off
if (otherdevices[DeviceName]) == 'Open' then
   print ("Current state: Up / Open")
   if Res_Dayl + Res_Wind + Res_Gust + Res_Rain + Res_UvCl + Res_TpCl == 6 then
         print ("Sunscreen Manual")
         t1 = os.time()
         s = otherdevices_lastupdate[DeviceName]
         difference = (os.difftime (t1, t2))
         if difference <= SwitchTime then
            print ("Recent open, wait for switchtime")
                      -- Close
            print ("Action: Down / Close")
                           commandArray[DeviceName] = ActionClose
                              f:write(os.date("%Y-%m-%d;%H:%M:%S") .. ";DOWN;" .. Version .. ";" .. Res_Dayl .. ";" .. Res_Wind .. ";" .. Res_Gust .. ";" .. Res_Rain .. ";" .. Res_UvCl .. ";" .. Res_TpCl .. ";" .. Res_UvOp .. ";" .. Res_TpOp .. ";" .. Wu_Wind .. ";" .. Wu_Gust .. ";" .. Wu_Rain .. ";" .. Wu_Uv .. ";" .. Wu_Temp)
                              f:write("\n")
                           if TelegramName == nil then else
                              -- Telegram notification for close
                              os.execute('su pi ./home/pi/domoticz/scripts/lua/Telegram.sh ' .. TelegramName .. ' "Sunscreen closed."')
      print ("Action: None")
if (otherdevices[DeviceName]) == 'Closed' then
   print ("Current state: Down / Closed")
   if Res_Dayl + Res_Wind + Res_Gust + Res_Rain < 4 or Res_UvOp==1 or Res_TpOp==1 then
                        -- Open
                         print ("Action: Up / Open")
                        commandArray[DeviceName] = ActionOpen
                              f:write(os.date("%Y-%m-%d;%H:%M:%S") .. ";OPEN;" .. Version .. ";" .. Res_Dayl .. ";" .. Res_Wind .. ";" .. Res_Gust .. ";" .. Res_Rain .. ";" .. Res_UvCl .. ";" .. Res_TpCl .. ";" .. Res_UvOp .. ";" .. Res_TpOp .. ";" .. Wu_Wind .. ";" .. Wu_Gust .. ";" .. Wu_Rain .. ";" .. Wu_Uv .. ";" .. Wu_Temp)
                              f:write("\n")
                           -- Telegram notification for open
                           os.execute('su pi ./home/pi/domoticz/scripts/lua/Telegram.sh ' .. TelegramName .. ' "Sunscreen open."')
      print ("  Action: None")
if LogAction=='A' then
                              f:write(os.date("%Y-%m-%d;%H:%M:%S") .. ";IDLE;" .. Version .. ";" .. Res_Dayl .. ";" .. Res_Wind .. ";" .. Res_Gust .. ";" .. Res_Rain .. ";" .. Res_UvCl .. ";" .. Res_TpCl .. ";" .. Res_UvOp .. ";" .. Res_TpOp .. ";" .. Wu_Wind .. ";" .. Wu_Gust .. ";" .. Wu_Rain .. ";" .. Wu_Uv .. ";" .. Wu_Temp)
                              f:write("\n")
  f:close()
remb0
Re: Sunscreen script v0.02
Post by remb0 »
I use it already and it's really great! thanks mate. I look forward to comments and possible some feedback.
Plaagje
Domoticz version: Latest
Post by Plaagje »
Got the following error:
Error: /home/pi/domoticz/scripts/lua/script_time_sunscreen.lua:192: attempt to index global 'f' (a nil value)
when opening
and
Error: /home/pi/domoticz/scripts/lua/script_time_sunscreen.lua:165: attempt to index global 'f' (a nil value)
when closing
the lines refer to:
and
this error shows only when the sunscreen is opening or closing, after it opened or closed, there is no error message.
the rest of the script seems fine
EDIT: When i change f:write to io.write, then i'm getting no errors...
BartdaMan
Post by BartdaMan »
Installed the script, but Domoticz log shows:
2016-06-25 12:50:00.018 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_zonwering.lua: /home/pi/domoticz/scripts/lua/script_time_zonwering.lua:54: attempt to concatenate global 'Wu_Dev_Temp' (a nil value)
How do I change the WU devices so that Wu_Dev_Temp is no longer a nil value?
Thanks in advance for any tips.
Plaagje
Post by Plaagje »
BartdaMan wrote:Installed the script, but Domoticz log shows:
The error tell you that it cant retrieve any values from the sensors listed in the script
You have to rename all the devices in the script according to your names
WU Temperature should be the name for your temperature sensor
the script listed in this post has 3 devices listed under:
remb0
Post by remb0 »
that's correct! but there is a newer version of this script that you can found in this forum.
