Slimme Meter P1 Interface no L2
GerardRoefs
Post by GerardRoefs »
Being quite new to Domoticz I have the following question:
Slimme Meter P1 cable is connected to Raspberry PI 3B+.
I can "see" L1-Power, L1-Usage, L1-Voltage and L1-Delivery.
But why can'r I "see"the figures for L2?
There are only devices for the L1.
FireWizard
Re: Slimme Meter P1 Interface no L2
Post by FireWizard »
Do you have a 3 phase meter?
GerardRoefs
It is a 1fase Sagemcom XS210
FireWizard
In this case, it is normal that you have only L1, because you have 1 phase smart meter.
There is no more information available.
In the latest release you will find:
- Voltage L1
- Power Consumption L1
- Power Delivery L1 (if you have solar panels)
- Power Usage L1
And if your gas meter is connected, you will have the Gas Usage
If you have 3 phase system and so you have a 3 phase smart meter, only then you will get the same information for L2 and L3.
Regards.
GerardRoefs
Thanks for your answers.
Indeed,Gas can be seen.
But now i'm confused:
1. If I read out the Sagemcom manually, it gives me figures about L1 and L2.
2. Above that, if I look to the graphics I can see there is a difference between 'Gebruik1' and 'Gebruik2''
My conclusion is therefor that de Sagem covers both L1 and L2 information in L1 Data?
FireWizard
As said, only 1 phase and 3 phase connections to the grid exist, and so dependant on your connection you have a 1 phase or 3 phase smart meter.
2 phase connections do not exist. As you said, you have a 1 phase connection and so a 1 phase smart meter.
You get only data for L(ine)1.
The figures you see are probably T1 and T2. These figures indicate the cost.
Usage1 is the low cost energy and Usage2 is the standard cost.
Usage1 you pay in night and weekend hours, while Usage2 are the hours during the day in the week. (As you are Dutch: Gebruik 1 is het nachttarief of weekend tarief)
Even if you don't use two tariffs they might be indicated, but showing a 0 value.
GerardRoefs
I got it. Thanks for your answers.
