configuration for MCOHome MH-P220 with xml file fixed
Posted: Tuesday 07 May 2019 14:47
by tonbor
Has anyone found the XML for MCOHome MH-P220. IT is certified but no XML could be found.
Well I have found one but I cannot get it working. This is what I get at nodes:
025 (0x19) Unknown McoHome Technology Co Ltd MH-P220 Mini Energy Dimmer+ McoHome Technology Co Ltd 0x5102 0x220a 2019-06-12 14:25:14 Nee.
This is what I put in the z-wave manufacturer file-> <Product name="MH-P220 Mini Energy Dimmer" id="5102" config="mcohome/mhp220.xml" type="220a"/>
this is the mhp220.xml file
mhp220.xml
(4.67 KiB) Downloaded 97 times
But there is no configuration for this node, what is going wrong?
no configuration for MCOHome MH-P220 with xml file
Posted: Wednesday 12 June 2019 15:18
by tonbor
Please look at configuration file, any help is more the welcome!
Re: no configuration for MCOHome MH-P220 with xml file
Posted: Wednesday 12 June 2019 19:01
by tonbor
Problem is the typos in the xml file from https://www.cd-jackson.com/index.php/zw ... =openzwave
Have to adjust them
Re: configuration for MCOHome MH-P220 with xml file fixed
Posted: Thursday 13 June 2019 11:25
by tonbor
I have adjust the xml file and it is working now
Posted: Sunday 16 June 2019 15:39
by gizmocuz
Could you submit it to openzwave else with the next update you will loose the changes
Posted: Tuesday 18 June 2019 16:17
by Fishwaldo
The CD Jackson site makes 1.4 version config files. Not compatible with 1.6
Posted: Friday 21 June 2019 14:10
by tonbor
Fishwaldo wrote: Tuesday 18 June 2019 16:17 The CD Jackson site makes 1.4 version config files. Not compatible with 1.6
Well with adjustments it worked with domoticz openzwave 1.4, with ozw 1.6 the xml will not work you think, what should I alter in the xml?
Posted: Thursday 11 July 2019 21:08
by tonbor
MCOhome MH-P220 has been added to openzwave version 1.6 today
