configuration for MCOHome MH-P220 with xml file fixed Topic is solved
tonbor
Post by tonbor »
Has anyone found the XML for MCOHome MH-P220. IT is certified but no XML could be found.
Well I have found one but I cannot get it working. This is what I get at nodes:
025 (0x19) Unknown McoHome Technology Co Ltd MH-P220 Mini Energy Dimmer+ McoHome Technology Co Ltd 0x5102 0x220a 2019-06-12 14:25:14 Nee.
This is what I put in the z-wave manufacturer file-> <Product name="MH-P220 Mini Energy Dimmer" id="5102" config="mcohome/mhp220.xml" type="220a"/>
this is the mhp220.xml file
mhp220.xml
(4.67 KiB) Downloaded 99 times
But there is no configuration for this node, what is going wrong?
tonbor
no configuration for MCOHome MH-P220 with xml file
Post by tonbor »
Please look at configuration file, any help is more the welcome!
tonbor
Re: no configuration for MCOHome MH-P220 with xml file
Post by tonbor »
Problem is the typos in the xml file from https://www.cd-jackson.com/index.php/zw ... =openzwave
Have to adjust them
tonbor
Re: configuration for MCOHome MH-P220 with xml file fixed
Post by tonbor »
I have adjust the xml file and it is working now
gizmocuz
Post by gizmocuz »
Could you submit it to openzwave else with the next update you will loose the changes
Fishwaldo
Post by Fishwaldo »
The CD Jackson site makes 1.4 version config files. Not compatible with 1.6
tonbor
Post by tonbor »
Fishwaldo wrote: Tuesday 18 June 2019 16:17 The CD Jackson site makes 1.4 version config files. Not compatible with 1.6
Well with adjustments it worked with domoticz openzwave 1.4, with ozw 1.6 the xml will not work you think, what should I alter in the xml?
tonbor
Post by tonbor »
MCOhome MH-P220 has been added to openzwave version 1.6 today
