Page 1 of 2
OZW 1.6 RELEASED !!
Posted: Monday 06 May 2019 20:32
by Ricard1
Yeehaa... better than Christmas, way better!
https://groups.google.com/forum/#!topic ... 26mAKMam58
The 1.6 version will improve Z-Wave functionality and stability a lot for all Domoticz Z-Wave users.
Big thanks Justin Hammond and all Contributors at OpenZWave!!
Kind regards,
Ricard
Re: OZW 1.6 RELEASED !!
Posted: Monday 06 May 2019 23:21
by pvm
Nice, but this is not yet integrated into Domoticz is it?
Posted: Tuesday 07 May 2019 6:16
by dressie
What does this mean for Domoticz? Is it necessary to install this or does the new stable has this already on board?
Verstuurd vanaf mijn SM-G950F met Tapatalk
Posted: Tuesday 07 May 2019 7:03
by waaren
[WARNING] make sure you backup your current libopenzwave.a before trying this. You will need this file in open-zwave-read-only directory to complete a successful creation of domoticz executable from source.
I just tried to compile /link domoticz from source on my RPI (Debian stretch) with the new OZW version (got it with git pull). Created the new libopenzwave.a with make and then did a make in the domoticz source directory.
During the link step I get
BasicWindowCovering.cpp:undefined reference to `OpenZWave::Node::CreateValueButton(OpenZWave::ValueID...
Group.cpp:undefined reference to `OpenZWave::Node::GetCommandClass(unsigned char) const'
OpenZWave.cpp:undefined reference to `OpenZWave::Manager::GetValueHelp[abi:cxx11](OpenZWave::ValueID const&)'
OpenZWave.cpp:undefined reference to `OpenZWave::Manager::GetValueLabel[abi:cxx11](OpenZWave::ValueID const&)'
ozwcp.cpp:undefined reference to `OpenZWave::Manager::GetValueHelp[abi:cxx11](OpenZWave::ValueID const&)'
ozwcp.cpp:undefined reference to `OpenZWave::Manager::GetValueLabel[abi:cxx11](OpenZWave::ValueID const&)'
After restoring the 'old' libopenzwave.a , the link process works without problems and domoticz is created.
Posted: Tuesday 07 May 2019 11:04
by gcoupe
Thanks, but I'll wait until this has been integrated into a stable version of Domoticz. The risk of destroying my production version of Domoticz is too high for me.
Posted: Tuesday 07 May 2019 19:18
by Ricard1
Hi all!
I could have pointed out that 1.6 has not yet been integrated with Domoticz. Regardless, it is probably a good idea to wait some weeks before switch over to 1.6 as all major code changes will include glitches not showing up prior real usage...
Cheers!
Posted: Wednesday 08 May 2019 13:31
by vinisz
Ok, so, can I run this with domoticz or not ? I saw it is not in the latest stable
OZW 1.6 RELEASED !!
Posted: Thursday 09 May 2019 11:16
by pvm
Now : you cannot unless you are a programmer and able to integrate it
Posted: Friday 10 May 2019 18:39
by Gravityz
why making a big fuzz out of this.
openzwave v1.5 was the previous version but domoticz is still on v1.4
this tells me things are going slow with domoticz(probably for a good reason)
Posted: Saturday 11 May 2019 13:13
by Ricard1
Gravityz wrote: Friday 10 May 2019 18:39
1.5 was a developer thing and never released, 1.4 is the previous version so Domoticz is doing very well I believe.
Posted: Saturday 11 May 2019 17:33
by febalci
waaren wrote: Tuesday 07 May 2019 7:03
@warren
Does that mean you are using libopenzwave.a from 1.4? So again, does that mean you are using the openzwave 1.4 after all, not 1.6?
Posted: Saturday 11 May 2019 17:45
by waaren
febalci wrote: Saturday 11 May 2019 17:33
@waaren
Yes. Compiling to OZW 1.6 was just a test. If it compiled with domoticz, I would have started to test it but for now I am completely happy with 1.4
Posted: Saturday 11 May 2019 19:24
by svde
I run domoticz on a Fedora server. Fedora moved to openzwave 1.5 in july 2017. I try to only run packaged software, so I ended up maintaining openzwave 1.4 packages in order to build domoticz, which has worked.
In the mean time Fedora managed to package the previous stable release against openzwave 1.5, but the patches stopped applying with the domoticz beta releases.
It seems that the openzwave project has been quite active recently, with both their github and
http://openzwave.com/downloads containing new releases.
Posted: Saturday 11 May 2019 20:25
by hestia
I have this version: 1.4-3335-g74e05982-dirty
do you have the same?
dirty doesn’t seem good to me...
Posted: Sunday 12 May 2019 2:29
by febalci
I have the 1.4-3254 that comes with the precompiled version on ubuntu.I never had a satisfactory setup with zwave, so i tried to use ozw 1.6 with compiling both ozw and domoticz. Nonetheless, domoticz compiles but gives a lot of undefined references after 100% compilation when on linking phase. So, domoticz is not ready for this, i keep on waiting...
Posted: Sunday 12 May 2019 9:26
by thelbekk
I am sure there are changes that need to be made to Domoticz before it can use Openzwave 1.6, but looking at the actual error messages generated during linking made me notice something strange:
There's a copy of the header files from Openzwave sitting in hardware/openzwave/, seemingly placed there as part of a modified copy of the Openzwave control panel, another project from them. These header files get used when Domoticz is built, instead of the ones installed with Openzwave, and I assume that any discrepancy between them and the installed version of Openzwave is a potential source of trouble. They are currently up-to-date copies of the header files from Openzwave 1.4.
In this case, all the error messages while linking Domoticz after installing Openzwave 1.6 are caused by a couple of changed declarations - and if these are adjusted in the copies in hardware/openzwave/, and Domoticz rebuilt, there are no complaints, and the resulting binary runs. I certainly wouldn't try to use it in production, as I'm sure there will be disagreements between Domoticz and Openzwave about actual data contents, and the semantics of using the Openzwave 1.6 API. I also haven't tried completely replacing the copies with ones from 1.6 - as I said, I expect there to be API changes that Domoticz will need to adapt to before things will work reliably.
Still, just having those copies in the main Domoticz source distribution feels somewhat wrong.
Posted: Sunday 12 May 2019 9:52
by waaren
thelbekk wrote: Sunday 12 May 2019 9:26
All the error messages while linking Domoticz after installing Openzwave 1.6 are caused by a couple of changed declarations - and if these are adjusted in the copies in hardware/openzwave/, and Domoticz rebuilt, there are no complaints, and the resulting binary runs.
Can you please share these adjustments ? I have a test-system and I am curious to see if I notice any changes in domoticz / Zwave behavior.
Thx !
Posted: Sunday 12 May 2019 10:14
by thelbekk
Ah, I don't have the changes any more - it was just a quick test. However, it's just differences in the declaration of the functions in question: during the compilation of Domoticz, the local declaration is used, and if its parameter list doesn't agree with the one in Openzwave, it'll fail during linking. So, just to pick one example:
domoticz/hardware/openzwave/Manager.h: string GetValueLabel( ValueID const& _id );
open-zwave/cpp/src/Manager.h: string GetValueLabel( ValueID const& _id, int32 _pos = -1 );
I just replaced the declaration in the copy of the file in Domoticz with the one from Openzwave 1.6. Same for the other errors.
Again, note that while these changes let Domoticz build and run with Openzwave 1.6, I certainly don't expect it to work correctly!
Posted: Sunday 12 May 2019 10:19
by waaren
thelbekk wrote: Sunday 12 May 2019 10:14
Thx. Will try and see where I get on my test-system.
Posted: Monday 13 May 2019 8:05
by thelbekk
...and now the industrious gizmocuz has updated Domoticz for Openzwave 1.6!
