https://groups.google.com/forum/#!topic ... 26mAKMam58
The 1.6 version will improve Z-Wave functionality and stability a lot for all Domoticz Z-Wave users.
Big thanks Justin Hammond and all Contributors at OpenZWave!!
Kind regards,
Ricard
BasicWindowCovering.cpp:undefined reference to `OpenZWave::Node::CreateValueButton(OpenZWave::ValueID...
Group.cpp:undefined reference to `OpenZWave::Node::GetCommandClass(unsigned char) const'
OpenZWave.cpp:undefined reference to `OpenZWave::Manager::GetValueHelp[abi:cxx11](OpenZWave::ValueID const&)'
OpenZWave.cpp:undefined reference to `OpenZWave::Manager::GetValueLabel[abi:cxx11](OpenZWave::ValueID const&)'
ozwcp.cpp:undefined reference to `OpenZWave::Manager::GetValueHelp[abi:cxx11](OpenZWave::ValueID const&)'
ozwcp.cpp:undefined reference to `OpenZWave::Manager::GetValueLabel[abi:cxx11](OpenZWave::ValueID const&)'1.5 was a developer thing and never released, 1.4 is the previous version so Domoticz is doing very well I believe.Gravityz wrote: Friday 10 May 2019 18:39 why making a big fuzz out of this.
openzwave v1.5 was the previous version but domoticz is still on v1.4
this tells me things are going slow with domoticz(probably for a good reason)
@warrenwaaren wrote: Tuesday 07 May 2019 7:03 [WARNING] make sure you backup your current libopenzwave.a before trying this. You will need this file in open-zwave-read-only directory to complete a successful creation of domoticz executable from source.
I just tried to compile /link domoticz from source on my RPI (Debian stretch) with the new OZW version (got it with git pull). Created the new libopenzwave.a with make and then did a make in the domoticz source directory.
After restoring the 'old' libopenzwave.a , the link process works without problems and domoticz is created.
Yes. Compiling to OZW 1.6 was just a test. If it compiled with domoticz, I would have started to test it but for now I am completely happy with 1.4febalci wrote: Saturday 11 May 2019 17:33 @waaren
Does that mean you are using libopenzwave.a from 1.4? So again, does that mean you are using the openzwave 1.4 after all, not 1.6?
Can you please share these adjustments ? I have a test-system and I am curious to see if I notice any changes in domoticz / Zwave behavior.thelbekk wrote: Sunday 12 May 2019 9:26 All the error messages while linking Domoticz after installing Openzwave 1.6 are caused by a couple of changed declarations - and if these are adjusted in the copies in hardware/openzwave/, and Domoticz rebuilt, there are no complaints, and the resulting binary runs.
Thx. Will try and see where I get on my test-system.thelbekk wrote: Sunday 12 May 2019 10:14 Again, note that while these changes let Domoticz build and run with Openzwave 1.6, I certainly don't expect it to work correctly!![]()
