Posting influxdb through dzvent
kratax
Post by kratax »
I have an issue with dzvent script for posting influx data:
domoticz.openURL({
url = 'http://127.0.0.1:8086/write?db=xxx&u=zz ... ecision=ms',
method = 'POST',
headers = 'application/x-www-form-urlencoded',
callback = 'mycallbackstring',
postData = 'TFA_sensor temp=' .. TEMP_CELS .. ',hum=' .. HUM
resulting in log (despite the fact that it's recorded in influxdb correctly...
2019-05-01 23:16:14.098 Error: Error opening url: http://127.0.0.1:8086/write?db=xxx&u=zz ... ecision=ms
An idea how to debug / solve that?
Re: Posting influxdb through dzvent
kratax wrote: Wednesday 01 May 2019 23:18 Hi,
Did you try to check the response ?
could look as something like
      timer = { 'every 5 minutes' },
      httpResponses = {'mycallbackstring'}
        if item.isTimer then
            TEMP_CELS = ??  -- Fill TEMP_CELS with the value you need
            HUM = ?? -- Fill HUM with the value you need
            domoticz.openURL({
                url = 'http://127.0.0.1:8086/write?db=xxx&u=zzzz&p=yyy&precision=ms',
                method = 'POST',
        elseif (item.isHTTPResponse) then
            domoticz.log("return from influxDB: " .. item.data,domoticz.LOG_FORCE)   -- [edit] changed to remove !
kratax
Post by kratax »
Thanks a lot, for this row
domoticz.log("return from influxDB: " .. item.data,domoticz.LOG_!FORCE)
I have an error:
z/scripts/dzVents/generated_scripts/Post_influx_data.lua:34: ')' expected near '!'
kratax wrote: Thursday 02 May 2019 0:07 Thanks a lot, for this row
I have an error:
My mistake. Line should be
kratax
Post by kratax »
Thanks a lot, I expected that... Unfortunatelly, there is nothing in the log (I have also attached full script as used below):
2019-05-02 09:31:00.405 Status: dzVents: Info: ------ Start internal script: Post_influx_data:, trigger: every 1 minutes
2019-05-02 09:31:00.427 Status: dzVents: Info: Zapisuji do influx teplota venek
2019-05-02 09:31:00.427 Status: dzVents: Info: Zapisuji do influxdb teploty konec
2019-05-02 09:31:00.427 Status: dzVents: Info: TEMP Cels
2019-05-02 09:31:00.428 Status: dzVents: Info: 17.2
2019-05-02 09:31:00.428 Status: dzVents: Info: HUM
2019-05-02 09:31:00.428 Status: dzVents: Info: 68
2019-05-02 09:31:00.428 Status: dzVents: Info: TFA_sensor temp=17.2,hum=68
2019-05-02 09:31:00.428 Status: dzVents: Info: Zapsano do influxdb
2019-05-02 09:31:00.429 Status: dzVents: Info: ------ Finished Post_influx_data
2019-05-02 09:31:00.429 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2019-05-02 09:31:00.465 Error: Error opening url: http://127.0.0.1:8086/write?db=testd&u= ... ecision=ms
2019-05-02 09:31:00.558 Status: dzVents: Info: Handling httpResponse-events for: "mycallbackstring
2019-05-02 09:31:00.558 Status: dzVents: Info: ------ Start internal script: Post_influx_data: HTTPResponse: "mycallbackstring"
2019-05-02 09:31:00.563 Status: dzVents: !Info: return from influxDB:
2019-05-02 09:31:00.564 Status: dzVents: Info: ------ Finished Post_influx_data
		timer = {'Every 1 minutes'},
		--devices = {'Teplota_venku_TFA'},
	data = {
	logger = {},
	    --basic url settings
	    --URL =
	    if item.isTimer and (domoticz.devices('Teplota_venku_TFA').temperature > -40 and domoticz.devices('Teplota_venku_TFA').temperature < 50 and domoticz.devices('Teplota_venku_TFA').humidity > 0 and domoticz.devices('Teplota_venku_TFA').humidity <= 100) then
	        domoticz.log('Zapisuji do influx teplota venek')
	        TEMP_CELS = domoticz.devices('Teplota_venku_TFA').temperature
	        TEMP_CELS = domoticz.utils.round (TEMP_CELS,3)
	        HUM = domoticz.devices('Teplota_venku_TFA').humidity
	        domoticz.log('Zapisuji do influxdb teploty konec')
	        domoticz.log('TEMP Cels ')
	        domoticz.log(TEMP_CELS)
	        domoticz.log('HUM ')
	        domoticz.log(HUM)
	        domoticz.openURL({
                url = 'http://127.0.0.1:8086/write?db=testd&u=tester&p=xxxx&precision=ms',
                method = 'POST',
            domoticz.log('TFA_sensor temp=' .. TEMP_CELS .. ',hum='.. HUM)
	        domoticz.log('Zapsano do influxdb')
kratax wrote: Thursday 02 May 2019 9:35 Unfortunatelly, there is nothing in the log (I have also attached full script as used below):
To show a bit more info on what's coming back, can you please change script to.
	data = {
	logger = {},
	    --URL =
	        domoticz.log(HUM)
	        domoticz.openURL({
                method = 'POST',
              domoticz.log("response from influxDB: " .. ( domoticz.utils.urlEncode(item.data) or " - none - "),domoticz.LOG_FORCE)
              domoticz.log("return code from influxDB: " .. item.statusCode,domoticz.LOG_FORCE)
              domoticz.log("response from influxDB: " .. item.data,domoticz.LOG_FORCE)
              for key, value in pairs (item.headers) do
                  domoticz.log("Header " .. key .. " ==>> " .. value,domoticz.LOG_FORCE)
kratax
Post by kratax »
Thanks, the outcome is as follows:
2019-05-02 10:20:00.529 Status: dzVents: Info: ------ Start internal script: Post_influx_data:, trigger: every 1 minutes
2019-05-02 10:20:00.552 Status: dzVents: Info: Zapisuji do influx teplota venek
2019-05-02 10:20:00.552 Status: dzVents: Info: Zapisuji do influxdb teploty konec
2019-05-02 10:20:00.552 Status: dzVents: Info: TEMP Cels
2019-05-02 10:20:00.552 Status: dzVents: Info: 20.4
2019-05-02 10:20:00.552 Status: dzVents: Info: HUM
2019-05-02 10:20:00.552 Status: dzVents: Info: 60
2019-05-02 10:20:00.552 Status: dzVents: Info: TFA_sensor temp=20.4,hum=60
2019-05-02 10:20:00.552 Status: dzVents: Info: Zapsano do influxdb
2019-05-02 10:20:00.553 Status: dzVents: Info: ------ Finished Post_influx_data
2019-05-02 10:20:00.554 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2019-05-02 10:20:00.709 Status: dzVents: Info: Handling httpResponse-events for: "mycallbackstring
2019-05-02 10:20:00.709 Status: dzVents: Info: ------ Start internal script: Post_influx_data: HTTPResponse: "mycallbackstring"
2019-05-02 10:20:00.717 Status: dzVents: !Info: response from influxDB:
2019-05-02 10:20:00.717 Status: dzVents: !Info: return code from influxDB: 12103200
2019-05-02 10:20:00.717 Status: dzVents: !Info: Header Request-Id ==>> 14399d7c-6cb3-11e9-b3b4-b827eb116147
2019-05-02 10:20:00.717 Status: dzVents: !Info: Header X-Request-Id ==>> 14399d7c-6cb3-11e9-b3b4-b827eb116147
2019-05-02 10:20:00.717 Status: dzVents: !Info: Header Content-Type ==>> application/json
2019-05-02 10:20:00.717 Status: dzVents: !Info: Header X-Influxdb-Build ==>> OSS
2019-05-02 10:20:00.717 Status: dzVents: !Info: Header X-Influxdb-Version ==>> 1.7.6
2019-05-02 10:20:00.717 Status: dzVents: !Info: Header Date ==>> Thu, 02 May 2019 08:20:00 GMT
2019-05-02 10:20:00.718 Status: dzVents: Info: ------ Finished Post_influx_data
2019-05-02 10:20:04.547 Status: Notification sent (Email)
kratax wrote: Thursday 02 May 2019 10:23 The outcome is as follows:
It looks like the handling by influx is OK but with an unexpected returnvalue. The error from domoticz points to a situation where no valid return is received. That's why I am interested to see what code is returned. Can you please try this one ?
    data = {
    logger = {},
        --URL =
            domoticz.log(HUM)
            domoticz.openURL({
                method = 'POST',
            local function getASCII(myData)
                str = ""
                for i=1,myData:len() do
                    str = str .. myData:byte(i) .. ", "
                return str:sub(1, -3)
            domoticz.log("ASCII values of response from influxDB: " .. getASCII(item.data or ""),domoticz.LOG_FORCE)
kratax
Post by kratax »
Please see below...
2019-05-02 13:16:00.542 Status: dzVents: Info: ------ Start internal script: Post_influx_data:, trigger: every 1 minutes
2019-05-02 13:16:00.565 Status: dzVents: Info: Zapisuji do influx teplota venek
2019-05-02 13:16:00.565 Status: dzVents: Info: Zapisuji do influxdb teploty konec
2019-05-02 13:16:00.565 Status: dzVents: Info: TEMP Cels
2019-05-02 13:16:00.565 Status: dzVents: Info: 21.3
2019-05-02 13:16:00.565 Status: dzVents: Info: HUM
2019-05-02 13:16:00.565 Status: dzVents: Info: 46
2019-05-02 13:16:00.565 Status: dzVents: Info: TFA_sensor temp=21.3,hum=46
2019-05-02 13:16:00.565 Status: dzVents: Info: Zapsano do influxdb
2019-05-02 13:16:00.566 Status: dzVents: Info: ------ Finished Post_influx_data
2019-05-02 13:16:00.567 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2019-05-02 13:16:00.709 Status: dzVents: Info: Handling httpResponse-events for: "mycallbackstring
2019-05-02 13:16:00.709 Status: dzVents: Info: ------ Start internal script: Post_influx_data: HTTPResponse: "mycallbackstring"
2019-05-02 13:16:00.715 Status: dzVents: !Info: response from influxDB:
2019-05-02 13:16:00.715 Status: dzVents: !Info: ASCII values of response from influxDB:
2019-05-02 13:16:00.715 Status: dzVents: !Info: return code from influxDB: 12103200
2019-05-02 13:16:00.715 Status: dzVents: !Info: Header Date ==>> Thu, 02 May 2019 11:16:00 GMT
2019-05-02 13:16:00.715 Status: dzVents: !Info: Header X-Request-Id ==>> aa7a98a9-6ccb-11e9-bef6-b827eb116147
2019-05-02 13:16:00.715 Status: dzVents: !Info: Header X-Influxdb-Version ==>> 1.7.6
2019-05-02 13:16:00.715 Status: dzVents: !Info: Header X-Influxdb-Build ==>> OSS
2019-05-02 13:16:00.715 Status: dzVents: !Info: Header Content-Type ==>> application/json
2019-05-02 13:16:00.715 Status: dzVents: !Info: Header Request-Id ==>> aa7a98a9-6ccb-11e9-bef6-b827eb116147
2019-05-02 13:16:00.716 Status: dzVents: Info: ------ Finished Post_influx_data
kratax wrote: Thursday 02 May 2019 13:17 Please see below...
OK Thanks. What I see is that influx returns an empty response and domoticz does consider this to be an error. Unfortunately Nothing dzVents can do about that.
kratax
Post by kratax »
Well, as per documentation,
https://docs.influxdata.com/influxdb/v1 ... ting_data/
2xx: If your write request received HTTP 204 No Content, it was a success!
Is then what is being seen by domoticz? If so then probably it's an domoticz issue with expecting this to be an error...
Thanks a lot.
kratax wrote: Thursday 02 May 2019 15:19 Well, as per documentation,
Thanks a lot.
What is the complete output of the script now ? (after the patch of @gizmocuz) ?
kratax
Post by kratax »
here you go:
 2019-05-04 23:37:00.341 Status: dzVents: Info: ------ Start internal script: Post_influx_data_testing:, trigger: every 1 minutes
2019-05-04 23:37:00.364 Status: dzVents: Info: Zapisuji do influx teplota venek
2019-05-04 23:37:00.364 Status: dzVents: Info: Zapisuji do influxdb teploty konec
2019-05-04 23:37:00.364 Status: dzVents: Info: TEMP Cels
2019-05-04 23:37:00.364 Status: dzVents: Info: 5
2019-05-04 23:37:00.364 Status: dzVents: Info: HUM
2019-05-04 23:37:00.364 Status: dzVents: Info: 79
2019-05-04 23:37:00.364 Status: dzVents: Info: TEST_sensor temp=5,hum=79
2019-05-04 23:37:00.365 Status: dzVents: Info: Zapsano do influxdb
2019-05-04 23:37:00.365 Status: dzVents: Info: ------ Finished Post_influx_data_testing
2019-05-04 23:37:00.367 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2019-05-04 23:37:00.770 Status: dzVents: Info: Handling httpResponse-events for: "mycallbackstring
2019-05-04 23:37:00.770 Status: dzVents: Info: ------ Start internal script: Post_influx_data_testing: HTTPResponse: "mycallbackstring"
2019-05-04 23:37:00.776 Status: dzVents: !Info: response from influxDB:
2019-05-04 23:37:00.776 Status: dzVents: !Info: ASCII values of response from influxDB:
2019-05-04 23:37:00.776 Status: dzVents: !Info: return code from influxDB: 200
2019-05-04 23:37:00.776 Status: dzVents: !Info: Header Content-Type ==>> application/json
2019-05-04 23:37:00.776 Status: dzVents: !Info: Header Request-Id ==>> bfe390d2-6eb4-11e9-a73c-b827eb116147
2019-05-04 23:37:00.776 Status: dzVents: !Info: Header Date ==>> Sat, 04 May 2019 21:37:00 GMT
2019-05-04 23:37:00.776 Status: dzVents: !Info: Header X-Influxdb-Build ==>> OSS
2019-05-04 23:37:00.776 Status: dzVents: !Info: Header X-Influxdb-Version ==>> 1.7.6
2019-05-04 23:37:00.776 Status: dzVents: !Info: Header X-Request-Id ==>> bfe390d2-6eb4-11e9-a73c-b827eb116147
2019-05-04 23:37:00.777 Status: dzVents: Info: ------ Finished Post_influx_data_testing
kratax wrote: Saturday 04 May 2019 23:41 Hi,
here you go:
Thanks !
After the patch of GizMocuz I also made some changes to the way dzVents handles an HTTP resultCode can you please check these as well ?
>= V4.10687
kratax
Post by kratax »
Tested, see outcome below...
 2019-05-05 14:07:52.327 Status: dzVents: Info: ------ Start internal script: Post_influx_data_testing: HTTPResponse: "mycallbackstring"
2019-05-05 14:07:52.344 Status: dzVents: !Info: response from influxDB:
2019-05-05 14:07:52.344 Status: dzVents: !Info: ASCII values of response from influxDB:
2019-05-05 14:07:52.344 Status: dzVents: !Info: return code from influxDB: 204
2019-05-05 14:07:52.344 Status: dzVents: !Info: Header Request-Id ==>> 68647fb9-6f2e-11e9-a201-b827eb116147
2019-05-05 14:07:52.344 Status: dzVents: !Info: Header status ==>> HTTP/1.1 204 No Content
2019-05-05 14:07:52.344 Status: dzVents: !Info: Header Content-Type ==>> application/json
2019-05-05 14:07:52.344 Status: dzVents: !Info: Header X-Request-Id ==>> 68647fb9-6f2e-11e9-a201-b827eb116147
2019-05-05 14:07:52.345 Status: dzVents: !Info: Header X-Influxdb-Build ==>> OSS
2019-05-05 14:07:52.345 Status: dzVents: !Info: Header Date ==>> Sun, 05 May 2019 12:07:52 GMT
2019-05-05 14:07:52.345 Status: dzVents: !Info: Header X-Influxdb-Version ==>> 1.7.6
2019-05-05 14:07:52.345 Status: dzVents: Info: ------ Finished Post_influx_data_testing
2019-05-05 14:08:00.354 Status: dzVents: Info: ------ Start internal script: Post_influx_data_testing:, trigger: every 1 minutes
2019-05-05 14:08:00.378 Status: dzVents: Info: Zapisuji do influx teplota venek
2019-05-05 14:08:00.378 Status: dzVents: Info: Zapisuji do influxdb teploty konec
2019-05-05 14:08:00.378 Status: dzVents: Info: TEMP Cels
2019-05-05 14:08:00.378 Status: dzVents: Info: 12.1
2019-05-05 14:08:00.378 Status: dzVents: Info: HUM
2019-05-05 14:08:00.378 Status: dzVents: Info: 57
2019-05-05 14:08:00.378 Status: dzVents: Info: TEST_sensor temp=12.1,hum=57
2019-05-05 14:08:00.378 Status: dzVents: Info: Zapsano do influxdb
2019-05-05 14:08:00.379 Status: dzVents: Info: ------ Finished Post_influx_data_testing
2019-05-05 14:08:00.380 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2019-05-05 14:08:00.523 Status: dzVents: Info: Handling httpResponse-events for: "mycallbackstring
2019-05-05 14:08:00.523 Status: dzVents: Info: ------ Start internal script: Post_influx_data_testing: HTTPResponse: "mycallbackstring"
2019-05-05 14:08:00.529 Status: dzVents: !Info: response from influxDB:
2019-05-05 14:08:00.529 Status: dzVents: !Info: ASCII values of response from influxDB:
2019-05-05 14:08:00.529 Status: dzVents: !Info: return code from influxDB: 204
2019-05-05 14:08:00.529 Status: dzVents: !Info: Header X-Request-Id ==>> 6d453385-6f2e-11e9-a203-b827eb116147
2019-05-05 14:08:00.529 Status: dzVents: !Info: Header Content-Type ==>> application/json
2019-05-05 14:08:00.529 Status: dzVents: !Info: Header Request-Id ==>> 6d453385-6f2e-11e9-a203-b827eb116147
2019-05-05 14:08:00.529 Status: dzVents: !Info: Header Date ==>> Sun, 05 May 2019 12:08:00 GMT
2019-05-05 14:08:00.529 Status: dzVents: !Info: Header status ==>> HTTP/1.1 204 No Content
2019-05-05 14:08:00.529 Status: dzVents: !Info: Header X-Influxdb-Build ==>> OSS
2019-05-05 14:08:00.529 Status: dzVents: !Info: Header X-Influxdb-Version ==>> 1.7.6
2019-05-05 14:08:00.530 Status: dzVents: Info: ------ Finished Post_influx_data_testing
kratax wrote: Sunday 05 May 2019 14:09 Tested, see outcome below...
:D
Thx !
kubrik
Post by kubrik »
i am having the same issue (status 204 treated as error by domoticz) but i am using stable version:
Version: 2020.2
Build Hash: b63341bc0
Compile Date: 2020-04-26 13:47:55
dzVents Version: 3.0.2
Python Version: 3.8.5 (default, Jul 28 2020, 12:59:40) [GCC 9.3.0]
It could be a regression?
Ubuntu 20.04 on ACEPC AK1 (previously RPi3b+)
Z-Stick Gen5, RFXtrx433E, Philips HUE Bridge, Yeelight, ESP8266 NodeMCU, Broadlink RM
dZvents, bash, php, Node-RED
kubrik wrote: Tuesday 29 December 2020 18:12 It could be a regression?
If you mean to ask if a hotfix is going to be applied for this, the answer is no. If you are lucky a new stable will be released soon.
kubrik
Post by kubrik »
waaren wrote: Tuesday 29 December 2020 20:04
Sigh :roll:
Domoticz version: 2024.7
kubrik wrote: Tuesday 29 December 2020 22:27
Sigh :roll:
The original topic and issue is from may 2019 with beta in V4.10687, So should be solved in V2020.1
Now appearrantly the issue has returned in 2020.2. @Kubrik did you test with the same test scripts @waaren made to be sure you have exactly that issue?
