MQTT ESP8266 DHT11 invalid data received (SOLVED)
Tukker
Domoticz version: 2023.2
Post by Tukker »
I found a nice description of publishing temperature and humidity to Domoticz using MQTT on The Free Physicist and later on an even nicer one from Paulus Schoutsen on Github to set up MQTT temp/hum readings.
In the script I added this line for testing purposes.
client.publish( "domoticz/in", "{'idx' : 56, 'nvalue' : 0, 'svalue' : '22;66;3' }");
This resulted in an error code inside Domoticz
 MQTT: Topic: domoticz/in, Message: {'idx' : 56, 'nvalue' : 0, 'svalue' : '22;66;3' }
Error: MQTT: Invalid data received!
So I tried
client.publish( 'domoticz/in', '{"idx" : 57, "nvalue" : 0, "svalue" : "22;66;2" }');
which is not accepted by the Arduino compiler as a correct code.
The problem is that Arduino doesn't accept single quotation marks and Domoticz doesn't accept single quotation marks.
Mixing single and double quotation marks in one line offers a solution for most compilers, but not in this case.
Can you give me an alternative on how to publish to Domoticz in a way that is accepted by both parties?
Bugs bug me.
Tukker
Re: MQTT ESP8266 DHT11 invalid data received
Post by Tukker »
I did another step and used Escape character to force a double quote using \"
Found it on StackExchange
This was my publish line
client.publish( "domoticz/in", "{\" idx \" : 56, \" nvalue \" : 0,  \" svalue \" : \" 22;66;3 \" }");
Here is the result in the Domoticz logs
2019-05-01 23:20:02.086 MQTT: Topic: domoticz/in, Message: {"idx" : 57, " nvalue " : 0, " svalue " : " 22;66;3 " }
2019-05-01 23:20:02.087 Error: MQTT: Invalid data received!
Failure!
Then I changed spacing around idx, nvalue and svalue
client.publish( "domoticz/in", "{\"idx\" : 56, \"nvalue\" : 0,  \"svalue\" : \"22;66;3\" }");
Result: SUCCESS!
2019-05-01 23:27:29.723 MQTT: Topic: domoticz/in, Message: {"idx" : 57, "nvalue" : 0, "svalue" : "22;66;3" }
Bugs bug me.
Doudy
Re: MQTT ESP8266 DHT11 invalid data received (SOLVED)
Post by Doudy »
Thank you for the code
That save me ;)
