json result and lodash function _.at
papoo
Domoticz version: 4.10
Post by papoo »
hello
i have a json result table1 like
{["name"]="aaaa", ["level"]=0},
{["name"]="bbbb", ["level"]=3},
{["name"]="cccc", ["level"]=0},
{["name"]="dddd", ["level"]=1},
{["name"]="eeee", ["level"]=3},
{["name"]="ffff", ["level"]=0}
i want to compare it with an array table2 like
table2 = {"bbbb", dddd","eeee"}
for result
but
 _.print(_.at(table1, table2))
don't works. how can i do that?
eventually it is possible to return only high same level?
papoo
Re: json result and lodash function _.at
Post by papoo »
just 2 for loop and it works
papoo wrote: Monday 29 April 2019 11:10
I have a json result table1 ; I want to compare it with an array table2 and store result in table3
Please find an approach to this. Might very well be there are better ways to work this but at least this works :)
        devices = { 'XButton-1'}
    execute = function(dz)
        local _ = require('lodash');
        local table1 = {
        local table2 =  { "bbbb", "dddd", "eeee" }
        local table3 = {}
        local function myLines(str)
            print("");print("--------------------------------");print(str);print("--------------------------------")
        myLines("Using lodash")
        _.forEach(table2, function(key)       -- looping though table2 values
            print(key .. " ==>> " .. table1[_.findIndex(table1, function(record)
                return record.name == key
            end)].level)
        end)
        myLines("Using standard Lua")
        for _, key in ipairs(table2) do
            for idx, record in ipairs(table1) do
                if key == record.name then
                    print(key .. " ==>> " .. record.level)
        -- print("Insert in table3 using lodash")
            table.insert(table3,{name = key, level = table1[_.findIndex(table1, function(record)
                                    end)].level})
          end)
        myLines("Inserted in table3 and print using lodash")
        _.print(table3)
        myLines("Inserted in table3 and print using dzVents dumpTable")
        dz.utils.dumpTable(table3, "> ")
output
Using lodash
bbbb ==>> 3
dddd ==>> 1
eeee ==>> 3
Using standard Lua
bbbb ==>> 3
dddd ==>> 1
eeee ==>> 3
{{["name"]="bbbb", ["level"]=3}, {["name"]="dddd", ["level"]=1}, {["name"]="eeee", ["level"]=3}}
> 1:
> level: 3
> 2:
> level: 1
> 3:
> level: 3
papoo
Post by papoo »
thanks for this
