After days I finally succeeded to have Domoticz running on Ubuntu 18.04 Desktop 64bit on Hyper-V in windows server 2016. Next step is to install Phyton plugins. I have installed the Chromecast / google home plugin but I get the following error in the log.
2019-04-27 18:51:50.463 Error: (GoogleDevs) failed to load 'plugin.py', Python Path used was '/home/coen/domoticz/plugins/Domoticz-Google-Plugin/:/usr/lib/python36.zip:/usr/lib/python3.6:/usr/lib/python3.6:/usr/lib/python3.6/lib-dynload'.
2019-04-27 18:51:50.463 Error: (Google Chromecast and Home) Module Import failed, exception: 'ModuleNotFoundError'
2019-04-27 18:51:50.463 Error: (Google Chromecast and Home) Module Import failed: ' Name: pychromecast'
2019-04-27 18:51:50.463 Error: (Google Chromecast and Home) Error Line details not available.
2019-04-27 18:53:00.794 Error: Google Chromecast and Home hardware (3) thread seems to have ended unexpectedlywhen i navigate to "/usr/lib/" there is no python3.6 folder.
In the log you can see that Domoticz Started, Python version '3.6.7'
Does anybody knows how to fix this or know what the problem is?
The full log here:
2019-04-27 18:51:46.214 Status: Domoticz V4.9701 (c)2012-2018 GizMoCuz
2019-04-27 18:51:46.216 Status: Build Hash: b47a877f, Date: 2018-06-23 16:27:56
2019-04-27 18:51:46.217 Status: Startup Path: /home/coen/domoticz/
2019-04-27 18:51:47.350 Active notification Subsystems: gcm, http (2/13)
2019-04-27 18:51:47.408 Starting shared server on: :::6144
2019-04-27 18:51:47.239 Status: PluginSystem: Started, Python version '3.6.7'.
2019-04-27 18:51:47.382 Status: WebServer(HTTP) started on address: :: with port 8082
2019-04-27 18:51:47.396 Status: WebServer(SSL) started on address: :: with port 445
2019-04-27 18:51:47.407 Status: Proxymanager started.
2019-04-27 18:51:47.411 Status: RxQueue: queue worker started...
2019-04-27 18:51:47.411 Status: TCPServer: shared server started...
2019-04-27 18:51:49.412 Status: Hardware Monitor: Started
2019-04-27 18:51:49.504 Status: (Google Chromecast and Home) Started.
2019-04-27 18:51:49.505 Status: EventSystem: reset all events...
2019-04-27 18:51:49.594 Status: EventSystem: reset all device statuses...
2019-04-27 18:51:49.748 Status: Python EventSystem: Initalizing event module.
2019-04-27 18:51:49.748 Status: EventSystem: Queue thread started...
2019-04-27 18:51:49.749 Status: EventSystem: Started
2019-04-27 18:51:49.924 Status: PluginSystem: Entering work loop.
