WAN login problem
Posted: Thursday 18 April 2019 20:40
by MasMat
Can anyone help with this problem?
When I open the dashboard (192.168.0.200:8080) locally there are no problems. When I try to access it remotely the login(?) seems to hang at a screen like in the attachment. I have login set to BasicAuth.
I just did a reinstall to newest Domoticz on Ubuntu running on and older laptop (2010). This is not a port fwd problem clearly. Looking at the log on the machine there's nothing special when I attempt outside access with another device.
Once I get http working https is next.
Ideas? Couldnt find similar on the forum.
Re: WAN login problem
Posted: Friday 19 April 2019 9:57
by mpx2
Does the same problem occur with Firefox, Chrome and Edge?
I have had routers which have problems with portforwarding if port is 80 or 8080. There's some kind of conflict because those ports are used for accessing router settings. Connection was established but after few bytes connection halts. Browser showed empty page. To be sure try eg port 4040.
Posted: Saturday 20 April 2019 13:00
by MasMat
Chrome yes, tried Safari but it worked only once AND didnt prompt for password. Next time I connected it said Domoticz offline.
Again this is NOT a router problem because the system has worked fine but after updating Domoticz it does this.
Is there a fix for the Chrome problem which I read causes problems? On my Android Chrome is default and I would prefer to use it.
Posted: Saturday 20 April 2019 19:57
by gerardsoraya
I had the same problems Butt after clearing cache of Chrome it is working Again, my idea about it was a Chrome update. You also putt a shortcut on your home screen? Remote it and replace it after clearing cache
Verstuurd vanaf mijn SM-G965F met Tapatalk
Posted: Monday 22 April 2019 9:34
by MasMat
OK, so most likely it's a browser problem: cache clearing works only once and even then not every time. Plus it is SLOW on android.
Easiest solution: I use incognito window on Chrome. Works every time and is fast as normal browsing.
Now I have to figure out how to make a shortcut on my phone desktop that opens an incognito window..
Posted: Monday 22 April 2019 10:55
by emme
are you behind a firewall?
Posted: Monday 22 April 2019 21:17
by MasMat
Just what is on the router.
So http working, gotta improve security next, if that's what you're implying :)
