Somewhere in your dzVents code you use a command that needs access to the domoticz API. dzVents uses IP 127.0.0.1 to do so.Mayki wrote: Sunday 31 March 2019 0:03 After some Domoticz update, I got this error:I have a domoticz on Rpi3 v 4.10579. Can you explain what this error means and how can I remove it?Code: Select all
Error: dzVents: local netWork not open for dzVents openURL call !
Please read this
