News feed not working with symbolic link url
Posted: Thursday 28 March 2019 15:58
by infiltrator88
Recently I reinstalled dashticz according to this procedure:
https://www.domoticz.com/wiki/Dashticz_ ... stallation
Everything is working fine except the news feed. The news feed is not working when I use the symbolic link URL. (
http://IP/dashticz_v2/index.html)
The garbage collector and the google calendar is working with this URL.
When I use the "old" URL(http://IP:portnumber/dashticz_v2/index.html) then the calendar isn't working because of PHP is not active but the newsfeed DOES work.
I checked with my google browser(F12) but saw no errors.
Can someone help me with this problem because I don't know why it isn't working.
Re: News feed not working with symbolic link url
Posted: Thursday 28 March 2019 16:22
by Lokonli
infiltrator88 wrote: Thursday 28 March 2019 15:58
The news feed is loaded via a CORS proxy, to prevent cross origin issues. If PHP is installed then a PHP based local CORS proxy will be used.
Can you try the "new" url with the following additional setting in CONFIG.js:
config['default_cors_url'] = 'https://cors-anywhere.herokuapp.com/'
This will force Dashticz to use cors-anywhere (external CORS proxy) instead of the local CORS proxy.
(with the 'old' url PHP is not installed. In that case Dashticz will automatically fall back to
https://cors-anywhere.herokuapp.com/)
Posted: Sunday 07 April 2019 13:36
by infiltrator88
Lokonli wrote: Thursday 28 March 2019 16:22
Thanks a lot. that did the trick
Posted: Sunday 07 April 2019 21:36
by Lokonli
infiltrator88 wrote: Sunday 07 April 2019 13:36
Good that it works, although I don't understand why. The internal proxy should work as well.
Which news url are you using? I'll test it on my system as well.
Posted: Tuesday 16 April 2019 14:00
by infiltrator88
sorry for the late reply. I was away for a couple of days and forgot to check the site.
The URL is:
https://cors-anywhere.herokuapp.com/htt ... /rss/sport
Posted: Tuesday 16 April 2019 20:21
by Lokonli
infiltrator88 wrote: Tuesday 16 April 2019 14:00
The URL is:
If you've setup your system correctly then the news feed will work with the default settings.
You can define the feed as follows:
blocks['news_sport'] = {
feed: 'http://www.nu.nl/rss/sport'
No need to add herokuapp.
From your config.js remove config['default_cors_url']
If it's not working then probably you did not install php correctly.
Posted: Friday 19 April 2019 13:41
by infiltrator88
yes That works. Before PHP installation function did not work withou herokuapp.
Now everything works fine. Thanks for all the help!
