News feed not working with symbolic link url Topic is solved
infiltrator88
Post by infiltrator88 »
Recently I reinstalled dashticz according to this procedure: https://www.domoticz.com/wiki/Dashticz_ ... stallation
Everything is working fine except the news feed. The news feed is not working when I use the symbolic link URL. (http://IP/dashticz_v2/index.html)
The garbage collector and the google calendar is working with this URL.
When I use the "old" URL(http://IP:portnumber/dashticz_v2/index.html) then the calendar isn't working because of PHP is not active but the newsfeed DOES work.
I checked with my google browser(F12) but saw no errors.
Can someone help me with this problem because I don't know why it isn't working.
Lokonli
Re: News feed not working with symbolic link url
Post by Lokonli »
infiltrator88 wrote: Thursday 28 March 2019 15:58 Recently I reinstalled dashticz according to this procedure: https://www.domoticz.com/wiki/Dashticz_ ... stallation
The news feed is loaded via a CORS proxy, to prevent cross origin issues. If PHP is installed then a PHP based local CORS proxy will be used.
Can you try the "new" url with the following additional setting in CONFIG.js:
config['default_cors_url'] = 'https://cors-anywhere.herokuapp.com/'
This will force Dashticz to use cors-anywhere (external CORS proxy) instead of the local CORS proxy.
(with the 'old' url PHP is not installed. In that case Dashticz will automatically fall back to https://cors-anywhere.herokuapp.com/)
infiltrator88
Lokonli wrote: Thursday 28 March 2019 16:22 The news feed is loaded via a CORS proxy, to prevent cross origin issues. If PHP is installed then a PHP based local CORS proxy will be used.
Thanks a lot. that did the trick
Lokonli
Post by Lokonli »
infiltrator88 wrote: Sunday 07 April 2019 13:36
Good that it works, although I don't understand why. The internal proxy should work as well.
Which news url are you using? I'll test it on my system as well.
infiltrator88
sorry for the late reply. I was away for a couple of days and forgot to check the site.
The URL is: https://cors-anywhere.herokuapp.com/htt ... /rss/sport
Lokonli
Post by Lokonli »
infiltrator88 wrote: Tuesday 16 April 2019 14:00
If you've setup your system correctly then the news feed will work with the default settings.
You can define the feed as follows:
blocks['news_sport'] = {
    feed: 'http://www.nu.nl/rss/sport'
No need to add herokuapp.
From your config.js remove config['default_cors_url']
If it's not working then probably you did not install php correctly.
infiltrator88
yes That works. Before PHP installation function did not work withou herokuapp.
Now everything works fine. Thanks for all the help!
