RFXCOM alarm with kerui device it works! what about K16 keyboard?
Posted: Thursday 28 March 2019 11:35
by Zener
Hey!
I just made my alarm system with Kerui devices. Tey are small and cheap:
I used these door sensor, which are easily recognise sending messages for Open/Close and panic mode:
https://fr.aliexpress.com/item/6pcs-lot ... 26744.html
For PIR i used those, very small, giving information about "Motion" :
https://fr.aliexpress.com/item/KERUI-P8 ... 34070.html
Now in order to control the alarm , I try to find information about K16 Kerui Keyboard? Does anyone test it? do you think it can send a message to RFXCOMM when RFIDTag ou password is Ok?
K16 Keybaord:
https://fr.aliexpress.com/item/New-Hot- ... 21244.html
Thx you your help!
Re: RFXCOM alarm with kerui device it works! what about K16 keyboard?
Posted: Monday 01 April 2019 10:24
by Zener
Nobody tested it?
Posted: Monday 01 April 2019 16:04
by Gerwin
should be great if that's working
Posted: Monday 08 April 2019 10:21
by Zener
I think I will have to do it on my own
Nobody seems to have already tested it!
Posted: Saturday 27 April 2019 12:25
by johansson
I ordered one for testing last year; does not work with RFXcom 433e, but AFAIK should be compatible with RFlink.
Posted: Saturday 27 April 2019 13:21
by b_weijenberg
Did you check with RFXmngr and the latest Pro1 firmware?
If not received sent the RAW data received in RFXmngr (enable only undec on) to support rfxcom.com
Posted: Sunday 28 April 2019 20:17
by johansson
Actually if I recall right, I was able to connect the keypad, but the chosen protocol interfered with the ones I was using so had to skip it for time being. Haven't tested with the latest software, but could try and send raw data over if needed.
Posted: Sunday 28 April 2019 20:43
by b_weijenberg
Protocols do not interfere in Pro1 firmware as in the previous Ext firmwares.
Posted: Tuesday 30 April 2019 16:27
by Zener
Seems to havesome testers! great!
Posted: Saturday 04 May 2019 21:04
by johansson
Dug out the keyboard after a while: indeed, it is now compatible with the Pro1 firmware. It shows up in devices list as three similar on/off -switches (arm away, arm home, disarm) that all remain On all the time. Did some testing with dzvents to utilize those for changing the security panel status, but with my non-existing skills had no luck so far. The problem is that as the switches are always on, don't know how to handle that in dzvents when the device state does not change.
Bottom line: Kerui K16 keyboard is found in Domoticz/RFXcom setup, but will require scripting to be usefull.
Posted: Sunday 05 May 2019 12:23
by johansson
A fast update - I sent the RFXmngr data to RFXcom support this morning and within hours an updated firmware including proper decoding of the Kerui panel was received. Seems to be working - great job, once again!
- Screen Shot 2019-05-05 at 13.20.03.png (24.08 KiB) Viewed 5944 times
Posted: Thursday 13 June 2019 12:16
by Zener
Nice! thank you. do you have a dedicated Firmware from RFXCOM?
Posted: Monday 24 June 2019 16:48
by johansson
Sorry, missed this one. No, it's not dedicated, i.e. support for the Kerui panel is included in the latest available fw (see blog:
http://blog.rfxcom.com/?p=232), downloadable
here.
Posted: Thursday 25 July 2019 11:28
by Zener
I tested it.It works well when you press the keyboard to send RFX orders.
I can't find how to send commande from RFX to Keyboard, for beeping for exemple or sending alarm.
One way com only.
Posted: Thursday 25 July 2019 19:15
by renerene
Bought the doordooswitches about 2 years ago. Bad battery life, ca 6 months. Led flash drains battery?
Use it with rfxcom and an extra on/off script.
Open close/state is not 100% reliable
Would not recomand them.
Posted: Wednesday 18 September 2019 13:38
by wvries
I am using this one:
https://www.aliexpress.com/item/3247019 ... 4c4dPtTGnM
Works perfectly with RFXCOM.
can use both registered (on the device itself) pin and RFID's (125Khz).
Posted: Monday 04 November 2019 15:13
by Golleman
How can the tags be programmed? Any best/good tags for recommendation?
Posted: Thursday 30 January 2020 16:56
by pvklink
Does anybody made some progress with a keyboard?
I recently bought kerui pirs, doorsensors, remotes and a zwave alarm. It all works fine!.
Last thing i want is a panel on the wall so i can:
1) arm/disarm the domoticz secpanel (and the other way around, it has to sync with the secpanel off domoticz)
2) like to use the same securitynumber for the panel as defined in domoticz
3) use off tags
Does somebody has this working?
Posted: Friday 28 February 2025 18:43
by ddave
hello, I try to link my Kerui w20 alarm to domoticz.
It is ok when I use the Kerui remote control or keypad to control (arm/disarm) the alarm.
I mean that the information and the state of the alarm are correctly sent, received and updated in domoticz. I can see it in the logs of the switches linked to the alarm.
But when I use the rfid on the Kerui panel to disarm the alarm, it is successfull but I get no changes in domoticz. And nothing in the logs.
How come that it is ok with remote control, and keypad and not ok with rfid ?
Anyone succeed with the rfid ?
