Page 1 of 2
PiZiGate and Aqara wireless switch
Posted: Thursday 28 March 2019 0:58
by ronaldbro
Got my PiZiGate today and was successfully able to add an Aqara door sensor, power plug and climate sensor.
But when I try to add the wireless switch (the little square one with one round button) I get the following error in the log: Not able to get all needed attributes on time
Any suggestions would be very welcome
Thanks,
Ronald
Re: PiZiGate and Aqara wireless switch
Posted: Thursday 28 March 2019 21:22
by fredo
DId you tried several time ? Was the zigate still in pairing mode ?
Posted: Thursday 28 March 2019 23:52
by ronaldbro
Yep, I tried about 20 times and stil in pairing mode. Log is the same every time:
2019-03-28 23:49:34.367 Status: (Zigate) Leave indication from IEEE: 00158d00021311e6 , Status: 00
2019-03-28 23:49:35.837 Status: (Zigate) Device Annoucement ShortAddr: 6c2c, IEEE: 00158d00021311e6
2019-03-28 23:49:36.866 Status: (Zigate) [-] NEW OBJECT: 6c2c Request Simple Descriptor for Ep: 01
2019-03-28 23:49:38.529 Status: (Zigate) [0] NEW OBJECT: 6c2c Model Name: lumi.remote.b1acn01
2019-03-28 23:49:41.282 Status: (Zigate) [-] NEW OBJECT: 6c2c Simple Descriptor EP 01
2019-03-28 23:49:41.283 Status: (Zigate) [-] NEW OBJECT: 6c2c ProfileID 0104
2019-03-28 23:49:41.283 Status: (Zigate) [-] NEW OBJECT: 6c2c ZDeviceID 0103
2019-03-28 23:49:41.283 Status: (Zigate) [-] NEW OBJECT: 6c2c Cluster IN Count: 03
2019-03-28 23:49:41.283 Status: (Zigate) [-] NEW OBJECT: 6c2c Cluster In 1: 0000
2019-03-28 23:49:41.283 Status: (Zigate) [-] NEW OBJECT: 6c2c Cluster In 2: 0012
2019-03-28 23:49:41.283 Status: (Zigate) [-] NEW OBJECT: 6c2c Cluster In 3: 0003
2019-03-28 23:49:41.283 Status: (Zigate) [-] NEW OBJECT: 6c2c Cluster OUT Count: 01
2019-03-28 23:49:41.283 Status: (Zigate) [-] NEW OBJECT: 6c2c Cluster Out 1: 0000
2019-03-28 23:49:43.550 Status: (Zigate) [0] NEW OBJECT: 6c2c Model Name: lumi.remote.b1acn01
2019-03-28 23:49:48.541 Status: (Zigate) [1] NEW OBJECT: 6c2c Model Name: lumi.remote.b1acn01
2019-03-28 23:49:53.558 Status: (Zigate) [2] NEW OBJECT: 6c2c Model Name: lumi.remote.b1acn01
2019-03-28 23:49:53.559 Status: (Zigate) [2] NEW OBJECT: 6c2c Model Name: lumi.remote.b1acn01
2019-03-28 23:49:53.563 Status: (Zigate) [2] NEW OBJECT: 6c2c Model Name: lumi.remote.b1acn01
2019-03-28 23:49:58.550 Status: (Zigate) [3] NEW OBJECT: 6c2c Model Name: lumi.remote.b1acn01
2019-03-28 23:49:58.553 Status: (Zigate) [3] NEW OBJECT: 6c2c Model Name: lumi.remote.b1acn01
2019-03-28 23:50:03.540 Status: (Zigate) [4] NEW OBJECT: 6c2c Model Name: lumi.remote.b1acn01
2019-03-28 23:50:03.540 Status: (Zigate) [4] NEW OBJECT: 6c2c Not able to get all needed attributes on time
Posted: Thursday 28 March 2019 23:56
by ronaldbro
No problem with all other devices. I have successfully connected:
6 Aqara TempHumBaro sensors
11 Aqara door sensors
2 Aqara motion detectors
3 Aqara water detectors
2 Tradfri bulbs
1 Hue bulb
Posted: Friday 29 March 2019 9:18
by fredo
ronaldbro wrote: Thursday 28 March 2019 23:52
I suspect this is a new Xiaomi model and seems not recognized by the plugin. You can check in the file DeviceConf.txt if you find an entry 'lumi.remote.b1acn01'
Posted: Friday 29 March 2019 9:25
by fredo
Posted: Friday 29 March 2019 18:09
by ronaldbro
Thanks,
Can I just add the line to DeviceConf or should I wait for the next release?
Posted: Saturday 30 March 2019 8:52
by fredo
I believe you can add the line.
Or may be better is to replace your existing one, by the recommended patch .
https://raw.githubusercontent.com/sasu- ... ceConf.txt
It might be good to do some backup before in case it breaks something
Posted: Saturday 30 March 2019 15:10
by ronaldbro
Thanks, this worked. I was able to add the button.
Unfortunatly the button only works partly with Zigate. Only single click and double click work. According to the zigate docs there should also be a tripple click and 4 click, but that doesn't work. I think the device doesn't support this.
The button also supports long press and long press release, but I guess this is not supported by Zigate.
Posted: Saturday 30 March 2019 15:13
by ronaldbro
Is there any place where I can make a change request?
Posted: Saturday 30 March 2019 18:27
by fredo
Is the device on Domoticz correctly created ? Means you have a Switch selector with Click 1, 2, 3 and 4 ?
==> If that is the case, the creation is correctly done, and the patch you did work.
==> If that is not the case, this mean , something is wrong in the device creation and so the patch is not good.
You might want to put some Logs to see exactly what is happening.
Posted: Saturday 30 March 2019 22:47
by ronaldbro
Yes, this is the case. Thats the good part
But when I do a single click on the button I get an event, same with double click. But with a tripple click or 4 click nothing happens.
And I really miss the long press...
Posted: Sunday 31 March 2019 10:12
by fredo
As said, if you could post the log when you are pressing once, twice, long press ...., this would be more helpfull.
Posted: Sunday 31 March 2019 12:52
by ronaldbro
Ah sorry, here it is.
Hope this helps.
Button Id = 00158d00021311e6, idx=261, name=Knop, unit=62
Single click:
- Spoiler: show
- 2019-03-31 12:41:44.797 (Zigate) 02 10 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. ..
2019-03-31 12:41:44.797 (Zigate) Pushing 'onMessageCallback' on to queue
2019-03-31 12:41:44.797 (Zigate) Processing 'ReadEvent' message
2019-03-31 12:41:44.797 (Zigate) Received 2 bytes of data
2019-03-31 12:41:44.797 (Zigate) 21 02 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. !.
2019-03-31 12:41:44.797 (Zigate) Received 1 bytes of data
2019-03-31 12:41:44.797 (Zigate) 10 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .
2019-03-31 12:41:44.798 (Zigate) Received 2 bytes of data
2019-03-31 12:41:44.798 (Zigate) 02 12 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. ..
2019-03-31 12:41:44.798 (Zigate) Pushing 'onMessageCallback' on to queue
2019-03-31 12:41:44.798 (Zigate) Processing 'ReadEvent' message
2019-03-31 12:41:44.798 (Zigate) Received 1 bytes of data
2019-03-31 12:41:44.798 (Zigate) 02 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .
2019-03-31 12:41:44.798 (Zigate) 10 02 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. ..
2019-03-31 12:41:44.799 (Zigate) 11 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .
2019-03-31 12:41:44.799 (Zigate) Pushing 'onMessageCallback' on to queue
2019-03-31 12:41:44.799 (Zigate) Processing 'ReadEvent' message
2019-03-31 12:41:44.799 (Zigate) Received 2 bytes of data
2019-03-31 12:41:44.799 (Zigate) a2 03 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. �.
2019-03-31 12:41:44.799 (Zigate) Processing 'onMessageCallback' message
2019-03-31 12:41:44.799 (Zigate) Calling message handler 'onMessage'.
2019-03-31 12:41:44.800 (Zigate) Calling message handler 'onMessage'.
2019-03-31 12:41:44.800 (Zigate) Processing 'onMessageCallback' message
2019-03-31 12:41:44.801 (Zigate) Processing 'onMessageCallback' message
2019-03-31 12:41:44.801 (Zigate) Calling message handler 'onMessage'.
2019-03-31 12:41:44.802 (Zigate) Calling message handler 'onMessage'.
2019-03-31 12:41:44.802 (Zigate) Processing 'onMessageCallback' message
2019-03-31 12:41:44.803 (Zigate) Processing 'onMessageCallback' message
2019-03-31 12:41:44.803 (Zigate) Calling message handler 'onMessage'.
2019-03-31 12:41:44.804 (Zigate) Processing 'onMessageCallback' message
2019-03-31 12:41:44.804 (Zigate) Calling message handler 'onMessage'.
2019-03-31 12:41:44.805 (Zigate) ZigateRead - decoded data : 018102000f881bcc150100120055002100020001a203 lenght : 44
2019-03-31 12:41:44.805 (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: 88, Data: 1bcc150100120055002100020001; RSSI: a2
2019-03-31 12:41:44.805 (Zigate) ZigateRead - MsgType 8102 - Report Individual Attribute response : 018102000f881bcc150100120055002100020001a203
2019-03-31 12:41:44.806 (Zigate) Decode8102 - Individual Attribute response : [cc15:01] ClusterID: 0012 AttributeID: 0055 Status: 00 Type: 21 Size: 0002 ClusterData: >0001<
2019-03-31 12:41:44.806 (Zigate) DeviceExist - Found in ListOfDevices with status = inDB
2019-03-31 12:41:44.806 (Zigate) Decode8102 : Attribute Report from cc15 SQN = 1b ClusterID = 0012 AttrID = 0055 Attribute Data = 0001
2019-03-31 12:41:44.806 (Zigate) Too early for a new update of LastSeen cc15
2019-03-31 12:41:44.806 (Zigate) Device : cc15 MacCapa : 80 updating SQN to 1b
2019-03-31 12:41:44.807 (Zigate) updSQN - Device : cc15 updating SQN to 1b
2019-03-31 12:41:44.807 (Zigate) ReadCluster - MsgData lenght is: 28 out of 24+
2019-03-31 12:41:44.807 (Zigate) DeviceExist - Found in ListOfDevices with status = inDB
2019-03-31 12:41:44.807 (Zigate) ReadCluster - 0012 NwkId: cc15 Ep: 01 AttrId: 0055 AttyType: 21 Attsize: 0002 Status: 00 AttrValue: 0001
2019-03-31 12:41:44.807 (Zigate) decodeAttribute( 21, 0001)
2019-03-31 12:41:44.807 (Zigate) ReadCluster - ClusterId=0012 - Switch Aqara: EP: 01 Value: 1
2019-03-31 12:41:44.807 (Zigate) MajDomoDevice - Device ID : 00158d00021311e6 - Device EP : 01 - Type : 0006 - Value : 1 - Hue : - Attribute_ :
2019-03-31 12:41:44.808 (Zigate) ClusterSearch - Cluster: 0006, ProfileID: , ZDeviceID: , create: False
2019-03-31 12:41:44.808 (Zigate) MajDomoDevice - Type = Switch
2019-03-31 12:41:44.808 (Zigate) MajDomoDevice - NWKID = cc15 IEEE = 00158d00021311e6 Unit = 261
2019-03-31 12:41:44.808 (Zigate) MajDomoDevice - {'0012': {}, '0006': {}, '0000': {}, 'ClusterType': {'261': 'SwitchAQ2'}}
2019-03-31 12:41:44.808 (Zigate) MajDomoDevice - We have 1 EPs with ClusterType
2019-03-31 12:41:44.808 (Zigate) MajDomoDevice - NWKID: cc15 SwitchType: 18, DeviceType: SwitchAQ2, ClusterType: Switch, old_nVal: 2 , old_sVal: 10
2019-03-31 12:41:44.809 (Zigate) UpdateDevice_v2 for : 62 Battery Level = 91 Signal Level = 162
2019-03-31 12:41:44.809 (Zigate) UpdateDevice_v2 for : 62 RSSI = 8
2019-03-31 12:41:44.809 (Zigate) UpdateDevice - ( Knop) 1:00
2019-03-31 12:41:44.809 (Zigate) Update Values 1:'00:' (Knop)
2019-03-31 12:41:44.809 (Knop) Updating device from 2:'10' to have values 1:'00'.
2019-03-31 12:41:45.867 (Zigate) Pushing 'onHeartbeatCallback' on to queue
2019-03-31 12:41:45.877 (Zigate) Processing 'onHeartbeatCallback' message
2019-03-31 12:41:45.877 (Zigate) Calling message handler 'onHeartbeat'.
2019-03-31 12:41:45.877 (Zigate) onHeartbeat - busy = False
2019-03-31 12:41:45.006 Status: dzVents: Info: Test: ------ Start internal script: Test: Device: "Knop (Zigate)", Index: 261
2019-03-31 12:41:45.006 Status: dzVents: Info: Test: 0
2019-03-31 12:41:45.006 Status: dzVents: Info: Test: ------ Finished Test
2019-03-31 12:41:50.871 (Zigate) Pushing 'onHeartbeatCallback' on to queue
2019-03-31 12:41:50.920 (Zigate) Processing 'onHeartbeatCallback' message
2019-03-31 12:41:50.920 (Zigate) Calling message handler 'onHeartbeat'.
2019-03-31 12:41:50.920 (Zigate) onHeartbeat - busy = False
double click:
- Spoiler: show
- 2019-03-31 12:43:26.577 (Zigate) 21 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. !
2019-03-31 12:43:26.578 (Zigate) Pushing 'onMessageCallback' on to queue
2019-03-31 12:43:26.578 (Zigate) Processing 'ReadEvent' message
2019-03-31 12:43:26.578 (Zigate) Received 2 bytes of data
2019-03-31 12:43:26.578 (Zigate) 02 10 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. ..
2019-03-31 12:43:26.578 (Zigate) Received 1 bytes of data
2019-03-31 12:43:26.578 (Zigate) 02 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .
2019-03-31 12:43:26.578 (Zigate) 12 02 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. ..
2019-03-31 12:43:26.579 (Zigate) Processing 'ReadEvent' message
2019-03-31 12:43:26.579 (Zigate) Received 1 bytes of data
2019-03-31 12:43:26.579 (Zigate) 10 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .
2019-03-31 12:43:26.579 (Zigate) Pushing 'onMessageCallback' on to queue
2019-03-31 12:43:26.579 (Zigate) Received 2 bytes of data
2019-03-31 12:43:26.579 (Zigate) 02 12 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. ..
2019-03-31 12:43:26.579 (Zigate) a2 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. �
2019-03-31 12:43:26.580 (Zigate) Received 1 bytes of data
2019-03-31 12:43:26.580 (Zigate) 03 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .
2019-03-31 12:43:26.580 (Zigate) Pushing 'onMessageCallback' on to queue
2019-03-31 12:43:26.580 (Zigate) Processing 'onMessageCallback' message
2019-03-31 12:43:26.580 (Zigate) Calling message handler 'onMessage'.
2019-03-31 12:43:26.581 (Zigate) Processing 'onMessageCallback' message
2019-03-31 12:43:26.581 (Zigate) Calling message handler 'onMessage'.
2019-03-31 12:43:26.582 (Zigate) Processing 'onMessageCallback' message
2019-03-31 12:43:26.582 (Zigate) Calling message handler 'onMessage'.
2019-03-31 12:43:26.583 (Zigate) Processing 'onMessageCallback' message
2019-03-31 12:43:26.583 (Zigate) Calling message handler 'onMessage'.
2019-03-31 12:43:26.584 (Zigate) Processing 'onMessageCallback' message
2019-03-31 12:43:26.584 (Zigate) Calling message handler 'onMessage'.
2019-03-31 12:43:26.585 (Zigate) Processing 'onMessageCallback' message
2019-03-31 12:43:26.585 (Zigate) Calling message handler 'onMessage'.
2019-03-31 12:43:26.586 (Zigate) Calling message handler 'onMessage'.
2019-03-31 12:43:26.586 (Zigate) Processing 'onMessageCallback' message
2019-03-31 12:43:26.586 (Zigate) ZigateRead - decoded data : 018102000f8c1ccc150100120055002100020002a203 lenght : 44
2019-03-31 12:43:26.587 (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: 8c, Data: 1ccc150100120055002100020002; RSSI: a2
2019-03-31 12:43:26.587 (Zigate) ZigateRead - MsgType 8102 - Report Individual Attribute response : 018102000f8c1ccc150100120055002100020002a203
2019-03-31 12:43:26.587 (Zigate) Decode8102 - Individual Attribute response : [cc15:01] ClusterID: 0012 AttributeID: 0055 Status: 00 Type: 21 Size: 0002 ClusterData: >0002<
2019-03-31 12:43:26.587 (Zigate) DeviceExist - Found in ListOfDevices with status = inDB
2019-03-31 12:43:26.587 (Zigate) Decode8102 : Attribute Report from cc15 SQN = 1c ClusterID = 0012 AttrID = 0055 Attribute Data = 0002
2019-03-31 12:43:26.588 (Zigate) Touch unit Knop nwkid: cc15
2019-03-31 12:43:26.590 (Zigate) Device : cc15 MacCapa : 80 updating SQN to 1c
2019-03-31 12:43:26.590 (Zigate) updSQN - Device : cc15 updating SQN to 1c
2019-03-31 12:43:26.590 (Zigate) ReadCluster - MsgData lenght is: 28 out of 24+
2019-03-31 12:43:26.591 (Zigate) DeviceExist - Found in ListOfDevices with status = inDB
2019-03-31 12:43:26.591 (Zigate) ReadCluster - 0012 NwkId: cc15 Ep: 01 AttrId: 0055 AttyType: 21 Attsize: 0002 Status: 00 AttrValue: 0002
2019-03-31 12:43:26.591 (Zigate) decodeAttribute( 21, 0002)
2019-03-31 12:43:26.591 (Zigate) ReadCluster - ClusterId=0012 - Switch Aqara: EP: 01 Value: 2
2019-03-31 12:43:26.591 (Zigate) MajDomoDevice - Device ID : 00158d00021311e6 - Device EP : 01 - Type : 0006 - Value : 2 - Hue : - Attribute_ :
2019-03-31 12:43:26.591 (Zigate) ClusterSearch - Cluster: 0006, ProfileID: , ZDeviceID: , create: False
2019-03-31 12:43:26.592 (Zigate) MajDomoDevice - Type = Switch
2019-03-31 12:43:26.592 (Zigate) MajDomoDevice - NWKID = cc15 IEEE = 00158d00021311e6 Unit = 261
2019-03-31 12:43:26.592 (Zigate) MajDomoDevice - {'0012': {}, '0006': {}, '0000': {}, 'ClusterType': {'261': 'SwitchAQ2'}}
2019-03-31 12:43:26.592 (Zigate) MajDomoDevice - We have 1 EPs with ClusterType
2019-03-31 12:43:26.592 (Zigate) MajDomoDevice - NWKID: cc15 SwitchType: 18, DeviceType: SwitchAQ2, ClusterType: Switch, old_nVal: 1 , old_sVal: 00
2019-03-31 12:43:26.592 (Zigate) UpdateDevice_v2 for : 62 Battery Level = 91 Signal Level = 162
2019-03-31 12:43:26.593 (Zigate) UpdateDevice_v2 for : 62 RSSI = 8
2019-03-31 12:43:26.593 (Zigate) UpdateDevice - ( Knop) 2:10
2019-03-31 12:43:26.593 (Zigate) Update Values 2:'10:' (Knop)
2019-03-31 12:43:26.593 (Knop) Updating device from 1:'00' to have values 2:'10'.
2019-03-31 12:43:26.809 Status: dzVents: Info: Test: ------ Start internal script: Test: Device: "Knop (Zigate)", Index: 261
2019-03-31 12:43:26.809 Status: dzVents: Info: Test: 10
2019-03-31 12:43:26.809 Status: dzVents: Info: Test: ------ Finished Test
2019-03-31 12:43:30.895 (Zigate) Pushing 'onHeartbeatCallback' on to queue
2019-03-31 12:43:30.917 (Zigate) Processing 'onHeartbeatCallback' message
2019-03-31 12:43:30.917 (Zigate) Calling message handler 'onHeartbeat'.
tripple click:
- Spoiler: show
- 2019-03-31 12:45:06.578 (Zigate) Processing 'onMessageCallback' message
2019-03-31 12:45:06.578 (Zigate) Calling message handler 'onMessage'.
2019-03-31 12:45:06.579 (Zigate) Calling message handler 'onMessage'.
2019-03-31 12:45:06.579 (Zigate) Processing 'onMessageCallback' message
2019-03-31 12:45:06.580 (Zigate) Processing 'onMessageCallback' message
2019-03-31 12:45:06.580 (Zigate) Calling message handler 'onMessage'.
2019-03-31 12:45:06.580 (Zigate) ZigateRead - decoded data : 018102000edb18c9f2010000000000200001015403 lenght : 42
2019-03-31 12:45:06.580 (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000e, MsgCRC: db, Data: 18c9f201000000000020000101; RSSI: 54
2019-03-31 12:45:06.581 (Zigate) ZigateRead - MsgType 8102 - Report Individual Attribute response : 018102000edb18c9f2010000000000200001015403
2019-03-31 12:45:06.581 (Zigate) Decode8102 - Individual Attribute response : [c9f2:01] ClusterID: 0000 AttributeID: 0000 Status: 00 Type: 20 Size: 0001 ClusterData: >01<
2019-03-31 12:45:06.581 (Zigate) DeviceExist - Found in ListOfDevices with status = inDB
2019-03-31 12:45:06.581 (Zigate) Decode8102 : Attribute Report from c9f2 SQN = 18 ClusterID = 0000 AttrID = 0000 Attribute Data = 01
2019-03-31 12:45:06.581 (Zigate) Too early for a new update of LastSeen c9f2
2019-03-31 12:45:06.582 (Zigate) Device : c9f2 MacCapa : 80 updating SQN to 18
2019-03-31 12:45:06.582 (Zigate) updSQN - Device : c9f2 updating SQN to 18
2019-03-31 12:45:06.582 (Zigate) Out of sequence for Device: c9f2 SQN move from 2c to 18 gap of : -20
2019-03-31 12:45:06.582 (Zigate) ReadCluster - MsgData lenght is: 26 out of 24+
2019-03-31 12:45:06.582 (Zigate) DeviceExist - Found in ListOfDevices with status = inDB
2019-03-31 12:45:06.582 (Zigate) ReadCluster - 0000 NwkId: c9f2 Ep: 01 AttrId: 0000 AttyType: 20 Attsize: 0001 Status: 00 AttrValue: 01
2019-03-31 12:45:06.582 (Zigate) decodeAttribute( 20, 01)
2019-03-31 12:45:06.582 (Zigate) ReadCluster - 0x0000 - ZCL Version: 1
2019-03-31 12:45:06.583 (Zigate) Processing 'onMessageCallback' message
2019-03-31 12:45:06.583 (Zigate) Calling message handler 'onMessage'.
2019-03-31 12:45:06.584 (Zigate) Calling message handler 'onMessage'.
2019-03-31 12:45:06.584 (Zigate) Processing 'onMessageCallback' message
2019-03-31 12:45:06.585 (Zigate) Calling message handler 'onMessage'.
2019-03-31 12:45:06.585 (Zigate) Processing 'onMessageCallback' message
2019-03-31 12:45:06.586 (Zigate) Processing 'onMessageCallback' message
2019-03-31 12:45:06.586 (Zigate) Calling message handler 'onMessage'.
2019-03-31 12:45:06.586 (Zigate) ZigateRead - decoded data : 018102000d7f18c9f2010000ff0186ff00005403 lenght : 40
2019-03-31 12:45:06.586 (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000d, MsgCRC: 7f, Data: 18c9f2010000ff0186ff0000; RSSI: 54
2019-03-31 12:45:06.586 (Zigate) ZigateRead - MsgType 8102 - Report Individual Attribute response : 018102000d7f18c9f2010000ff0186ff00005403
2019-03-31 12:45:06.587 (Zigate) Decode8102 - Individual Attribute response : [c9f2:01] ClusterID: 0000 AttributeID: ff01 Status: 86 Type: ff Size: 0000 ClusterData: ><
2019-03-31 12:45:06.587 (Zigate) DeviceExist - Found in ListOfDevices with status = inDB
2019-03-31 12:45:06.587 (Zigate) Decode8102 : Attribute Report from c9f2 SQN = 18 ClusterID = 0000 AttrID = ff01 Attribute Data =
2019-03-31 12:45:06.587 (Zigate) Too early for a new update of LastSeen c9f2
2019-03-31 12:45:06.587 (Zigate) Device : c9f2 MacCapa : 80 updating SQN to 18
2019-03-31 12:45:06.587 (Zigate) ReadCluster - MsgData lenght is: 24 out of 24+
2019-03-31 12:45:06.587 (Zigate) ReadCluster - Status 86 for addr: c9f2/01 on cluster/attribute 0000/ff01
2019-03-31 12:45:10.991 (Zigate) Pushing 'onHeartbeatCallback' on to queue
2019-03-31 12:45:10.995 (Zigate) Processing 'onHeartbeatCallback' message
2019-03-31 12:45:10.996 (Zigate) Calling message handler 'onHeartbeat'.
2019-03-31 12:45:10.996 (Zigate) onHeartbeat - busy = False
4 click:
- Spoiler: show
- 2019-03-31 12:47:01.595 (Zigate) Pushing 'onHeartbeatCallback' on to queue
2019-03-31 12:47:01.645 (Zigate) Processing 'onHeartbeatCallback' message
2019-03-31 12:47:01.645 (Zigate) Calling message handler 'onHeartbeat'.
2019-03-31 12:47:01.646 (Zigate) onHeartbeat - busy = False
long press and long press release:
- Spoiler: show
- 2019-03-31 12:48:09.617 (Zigate) Processing 'ReadEvent' message
2019-03-31 12:48:09.617 (Zigate) Received 1 bytes of data
2019-03-31 12:48:09.617 (Zigate) 10 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .
2019-03-31 12:48:09.618 (Zigate) Pushing 'onMessageCallback' on to queue
2019-03-31 12:48:09.618 (Zigate) Processing 'ReadEvent' message
2019-03-31 12:48:09.618 (Zigate) Received 1 bytes of data
2019-03-31 12:48:09.618 (Zigate) 02 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .
2019-03-31 12:48:09.618 (Zigate) Received 2 bytes of data
2019-03-31 12:48:09.618 (Zigate) 10 99 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .�
2019-03-31 12:48:09.618 (Zigate) 03 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .
2019-03-31 12:48:09.619 (Zigate) Pushing 'onMessageCallback' on to queue
2019-03-31 12:48:09.619 (Zigate) Processing 'onMessageCallback' message
2019-03-31 12:48:09.619 (Zigate) Calling message handler 'onMessage'.
2019-03-31 12:48:09.620 (Zigate) Calling message handler 'onMessage'.
2019-03-31 12:48:09.620 (Zigate) Processing 'onMessageCallback' message
2019-03-31 12:48:09.621 (Zigate) Calling message handler 'onMessage'.
2019-03-31 12:48:09.621 (Zigate) Processing 'onMessageCallback' message
2019-03-31 12:48:09.622 (Zigate) Calling message handler 'onMessage'.
2019-03-31 12:48:09.622 (Zigate) Processing 'onMessageCallback' message
2019-03-31 12:48:09.623 (Zigate) Processing 'onMessageCallback' message
2019-03-31 12:48:09.623 (Zigate) Calling message handler 'onMessage'.
2019-03-31 12:48:09.624 (Zigate) Calling message handler 'onMessage'.
2019-03-31 12:48:09.624 (Zigate) Processing 'onMessageCallback' message
2019-03-31 12:48:09.625 (Zigate) Processing 'onMessageCallback' message
2019-03-31 12:48:09.625 (Zigate) Calling message handler 'onMessage'.
2019-03-31 12:48:09.626 (Zigate) Processing 'onMessageCallback' message
2019-03-31 12:48:09.626 (Zigate) Calling message handler 'onMessage'.
2019-03-31 12:48:09.627 (Zigate) Calling message handler 'onMessage'.
2019-03-31 12:48:09.627 (Zigate) ZigateRead - decoded data : 018102000fa900cc1501001200550021000200009903 lenght : 44
2019-03-31 12:48:09.627 (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: a9, Data: 00cc150100120055002100020000; RSSI: 99
2019-03-31 12:48:09.628 (Zigate) ZigateRead - MsgType 8102 - Report Individual Attribute response : 018102000fa900cc1501001200550021000200009903
2019-03-31 12:48:09.628 (Zigate) Decode8102 - Individual Attribute response : [cc15:01] ClusterID: 0012 AttributeID: 0055 Status: 00 Type: 21 Size: 0002 ClusterData: >0000<
2019-03-31 12:48:09.628 (Zigate) DeviceExist - Found in ListOfDevices with status = inDB
2019-03-31 12:48:09.628 (Zigate) Decode8102 : Attribute Report from cc15 SQN = 00 ClusterID = 0012 AttrID = 0055 Attribute Data = 0000
2019-03-31 12:48:09.628 (Zigate) Too early for a new update of LastSeen cc15
2019-03-31 12:48:09.629 (Zigate) Device : cc15 MacCapa : 80 updating SQN to 00
2019-03-31 12:48:09.629 (Zigate) updSQN - Device : cc15 updating SQN to 00
2019-03-31 12:48:09.629 (Zigate) ReadCluster - MsgData lenght is: 28 out of 24+
2019-03-31 12:48:09.629 (Zigate) DeviceExist - Found in ListOfDevices with status = inDB
2019-03-31 12:48:09.629 (Zigate) ReadCluster - 0012 NwkId: cc15 Ep: 01 AttrId: 0055 AttyType: 21 Attsize: 0002 Status: 00 AttrValue: 0000
2019-03-31 12:48:09.629 (Zigate) decodeAttribute( 21, 0000)
2019-03-31 12:48:09.629 (Zigate) ReadCluster - ClusterId=0012 - Switch Aqara: EP: 01 Value: 0
2019-03-31 12:48:09.630 (Zigate) MajDomoDevice - Device ID : 00158d00021311e6 - Device EP : 01 - Type : 0006 - Value : 3 - Hue : - Attribute_ :
2019-03-31 12:48:09.630 (Zigate) ClusterSearch - Cluster: 0006, ProfileID: , ZDeviceID: , create: False
2019-03-31 12:48:09.630 (Zigate) MajDomoDevice - Type = Switch
2019-03-31 12:48:09.630 (Zigate) MajDomoDevice - NWKID = cc15 IEEE = 00158d00021311e6 Unit = 261
2019-03-31 12:48:09.630 (Zigate) MajDomoDevice - {'0012': {}, '0006': {}, '0000': {}, 'ClusterType': {'261': 'SwitchAQ2'}}
2019-03-31 12:48:09.630 (Zigate) MajDomoDevice - We have 1 EPs with ClusterType
2019-03-31 12:48:09.631 (Zigate) MajDomoDevice - NWKID: cc15 SwitchType: 18, DeviceType: SwitchAQ2, ClusterType: Switch, old_nVal: 2 , old_sVal: 10
2019-03-31 12:48:09.631 (Zigate) UpdateDevice_v2 for : 62 Battery Level = 91 Signal Level = 153
2019-03-31 12:48:09.631 (Zigate) UpdateDevice_v2 for : 62 RSSI = 7
2019-03-31 12:48:09.631 (Zigate) UpdateDevice - ( Knop) 3:20
2019-03-31 12:48:09.631 (Zigate) Update Values 3:'20:' (Knop)
2019-03-31 12:48:09.809 Status: dzVents: Info: Test: ------ Start internal script: Test: Device: "Knop (Zigate)", Index: 261
2019-03-31 12:48:12.155 (Zigate) Processing 'onMessageCallback' message
2019-03-31 12:48:12.155 (Zigate) Calling message handler 'onMessage'.
2019-03-31 12:48:12.156 (Zigate) ZigateRead - decoded data : 018102000e801f422c010000000000200001015d03 lenght : 42
2019-03-31 12:48:12.156 (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000e, MsgCRC: 80, Data: 1f422c01000000000020000101; RSSI: 5d
2019-03-31 12:48:12.156 (Zigate) ZigateRead - MsgType 8102 - Report Individual Attribute response : 018102000e801f422c010000000000200001015d03
2019-03-31 12:48:12.156 (Zigate) Decode8102 - Individual Attribute response : [422c:01] ClusterID: 0000 AttributeID: 0000 Status: 00 Type: 20 Size: 0001 ClusterData: >01<
2019-03-31 12:48:12.156 (Zigate) DeviceExist - Found in ListOfDevices with status = inDB
2019-03-31 12:48:12.156 (Zigate) Decode8102 : Attribute Report from 422c SQN = 1f ClusterID = 0000 AttrID = 0000 Attribute Data = 01
2019-03-31 12:48:12.156 (Zigate) Too early for a new update of LastSeen 422c
2019-03-31 12:48:12.157 (Zigate) Device : 422c MacCapa : 80 updating SQN to 1f
2019-03-31 12:48:12.157 (Zigate) updSQN - Device : 422c updating SQN to 1f
2019-03-31 12:48:12.157 (Zigate) Out of sequence for Device: 422c SQN move from 5a to 1f gap of : -59
2019-03-31 12:48:12.157 (Zigate) ReadCluster - MsgData lenght is: 26 out of 24+
2019-03-31 12:48:12.157 (Zigate) DeviceExist - Found in ListOfDevices with status = inDB
2019-03-31 12:48:12.157 (Zigate) ReadCluster - 0000 NwkId: 422c Ep: 01 AttrId: 0000 AttyType: 20 Attsize: 0001 Status: 00 AttrValue: 01
2019-03-31 12:48:12.157 (Zigate) decodeAttribute( 20, 01)
2019-03-31 12:48:12.157 (Zigate) ReadCluster - 0x0000 - ZCL Version: 1
2019-03-31 12:48:12.157 (Zigate) Processing 'onMessageCallback' message
2019-03-31 12:48:12.157 (Zigate) Calling message handler 'onMessage'.
2019-03-31 12:48:12.158 (Zigate) Calling message handler 'onMessage'.
2019-03-31 12:48:12.158 (Zigate) Processing 'onMessageCallback' message
2019-03-31 12:48:12.159 (Zigate) Processing 'onMessageCallback' message
2019-03-31 12:48:12.159 (Zigate) Calling message handler 'onMessage'.
2019-03-31 12:48:12.160 (Zigate) Processing 'onMessageCallback' message
2019-03-31 12:48:12.160 (Zigate) Calling message handler 'onMessage'.
2019-03-31 12:48:12.161 (Zigate) Processing 'onMessageCallback' message
2019-03-31 12:48:12.161 (Zigate) Calling message handler 'onMessage'.
2019-03-31 12:48:12.161 (Zigate) ZigateRead - decoded data : 018102000d241f422c010000ff0186ff00005d03 lenght : 40
2019-03-31 12:48:12.161 (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000d, MsgCRC: 24, Data: 1f422c010000ff0186ff0000; RSSI: 5d
2019-03-31 12:48:12.161 (Zigate) ZigateRead - MsgType 8102 - Report Individual Attribute response : 018102000d241f422c010000ff0186ff00005d03
2019-03-31 12:48:12.161 (Zigate) Decode8102 - Individual Attribute response : [422c:01] ClusterID: 0000 AttributeID: ff01 Status: 86 Type: ff Size: 0000 ClusterData: ><
2019-03-31 12:48:12.161 (Zigate) DeviceExist - Found in ListOfDevices with status = inDB
2019-03-31 12:48:12.161 (Zigate) Decode8102 : Attribute Report from 422c SQN = 1f ClusterID = 0000 AttrID = ff01 Attribute Data =
2019-03-31 12:48:12.161 (Zigate) Too early for a new update of LastSeen 422c
2019-03-31 12:48:12.162 (Zigate) Device : 422c MacCapa : 80 updating SQN to 1f
2019-03-31 12:48:12.162 (Zigate) ReadCluster - MsgData lenght is: 24 out of 24+
2019-03-31 12:48:12.162 (Zigate) ReadCluster - Status 86 for addr: 422c/01 on cluster/attribute 0000/ff01
2019-03-31 12:48:16.782 (Zigate) Pushing 'onHeartbeatCallback' on to queue
2019-03-31 12:48:16.835 (Zigate) Processing 'onHeartbeatCallback' message
Posted: Sunday 31 March 2019 17:28
by fredo
Thanks for such detailed Logs.
Here after is what I have been able to identify.
In short:
4 clicks and 3 clicks do not report anything. At least the Hardware Zigate doesn't send anything to the plugin.
Long press - is reported to domoticz with Level 20 (should be 3 Click)
2 Click - is reported to domoticz with Level 10 (should be 2 click)
1 click - is reported to domoticz with Level 00 (should be 1 click)
At least this is my interpretation as I do not have such device. May be someone with that device should comment it ?
Long press
Update Device 3:20
4 Clicks
=> Nothing coming from device
3 Clicks
==> Nothing coming from device
2 Clicks
Update Device 2:10
1 Click
Update Device 1:00
Posted: Sunday 31 March 2019 17:33
by fredo
What do you mean According to the Zigate docs ?
Posted: Sunday 31 March 2019 18:07
by ronaldbro
fredo wrote: Sunday 31 March 2019 17:33
I mean this:
https://github.com/pipiche38/Domoticz-Z ... Devices.md
I will check the long press again, maybe it’s just a textual mistake
Posted: Sunday 31 March 2019 19:42
by ronaldbro
I did some tests and I can confirm that a long press sets level 20 and when pressing the event is send every few seconds repeatively.
So the only events that I get from the device is single click, double click and long press.
enough for me, so I'm happy
Thanks for your help.
If you want me to test something please let me know. I would be happy to.
Posted: Sunday 31 March 2019 20:58
by ronaldbro
I did some more testing and I noticed that after a long press (level 20) I get a single click on the release of the button. This should have been a long press release.
- Spoiler: show
- 2019-03-31 20:50:13.605 (Zigate) Received 1 bytes of data
2019-03-31 20:50:13.606 (Zigate) Received 1 bytes of data
2019-03-31 20:50:13.607 (Zigate) Received 1 bytes of data
2019-03-31 20:50:13.611 (Zigate) ZigateRead - decoded data : 018102000f4002cc1501001200550021000200007203 lenght : 44
2019-03-31 20:50:13.611 (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: 40, Data: 02cc150100120055002100020000; RSSI: 72
2019-03-31 20:50:13.612 (Zigate) ZigateRead - MsgType 8102 - Report Individual Attribute response : 018102000f4002cc1501001200550021000200007203
2019-03-31 20:50:13.612 (Zigate) Decode8102 - Individual Attribute response : [cc15:01] ClusterID: 0012 AttributeID: 0055 Status: 00 Type: 21 Size: 0002 ClusterData: >0000<
2019-03-31 20:50:13.612 (Zigate) DeviceExist - Found in ListOfDevices with status = inDB
2019-03-31 20:50:13.612 (Zigate) Decode8102 : Attribute Report from cc15 SQN = 02 ClusterID = 0012 AttrID = 0055 Attribute Data = 0000
2019-03-31 20:50:13.612 (Zigate) Too early for a new update of LastSeen cc15
2019-03-31 20:50:13.613 (Zigate) Device : cc15 MacCapa : 80 updating SQN to 02
2019-03-31 20:50:13.613 (Zigate) updSQN - Device : cc15 updating SQN to 02
2019-03-31 20:50:13.613 (Zigate) ReadCluster - MsgData lenght is: 28 out of 24+
2019-03-31 20:50:13.613 (Zigate) DeviceExist - Found in ListOfDevices with status = inDB
2019-03-31 20:50:13.613 (Zigate) ReadCluster - 0012 NwkId: cc15 Ep: 01 AttrId: 0055 AttyType: 21 Attsize: 0002 Status: 00 AttrValue: 0000
2019-03-31 20:50:13.614 (Zigate) decodeAttribute( 21, 0000)
2019-03-31 20:50:13.614 (Zigate) ReadCluster - ClusterId=0012 - Switch Aqara: EP: 01 Value: 0
2019-03-31 20:50:13.614 (Zigate) MajDomoDevice - Device ID : 00158d00021311e6 - Device EP : 01 - Type : 0006 - Value : 3 - Hue : - Attribute_ :
2019-03-31 20:50:13.614 (Zigate) ClusterSearch - Cluster: 0006, ProfileID: , ZDeviceID: , create: False
2019-03-31 20:50:13.614 (Zigate) MajDomoDevice - Type = Switch
2019-03-31 20:50:13.614 (Zigate) MajDomoDevice - NWKID = cc15 IEEE = 00158d00021311e6 Unit = 261
2019-03-31 20:50:13.615 (Zigate) MajDomoDevice - {'0012': {}, '0006': {}, '0000': {}, 'ClusterType': {'261': 'SwitchAQ2'}}
2019-03-31 20:50:13.615 (Zigate) MajDomoDevice - We have 1 EPs with ClusterType
2019-03-31 20:50:13.615 (Zigate) MajDomoDevice - NWKID: cc15 SwitchType: 18, DeviceType: SwitchAQ2, ClusterType: Switch, old_nVal: 1 , old_sVal: 00
2019-03-31 20:50:13.615 (Zigate) UpdateDevice_v2 for : 62 Battery Level = 91 Signal Level = 114
2019-03-31 20:50:13.615 (Zigate) UpdateDevice_v2 for : 62 RSSI = 5
2019-03-31 20:50:13.615 (Zigate) UpdateDevice - ( Knop) 3:20
2019-03-31 20:50:13.616 (Zigate) Update Values 3:'20:' (Knop)
2019-03-31 20:50:13.616 (Knop) Updating device from 1:'00' to have values 3:'20'.
2019-03-31 20:50:13.634 (Zigate) waitForData - Timeout 4 on 8120 Command waiting for 0120
2019-03-31 20:50:13.792 Status: dzVents: Info: Test: ------ Start internal script: Test: Device: "Knop (Zigate)", Index: 261
2019-03-31 20:50:13.792 Status: dzVents: Info: Test: 20
2019-03-31 20:50:13.792 Status: dzVents: Info: Test: ------ Finished Test
2019-03-31 20:50:14.088 (Zigate) onHeartbeat - busy = False
2019-03-31 20:50:19.116 (Zigate) onHeartbeat - busy = False
2019-03-31 20:50:19.448 (Zigate) Received 2 bytes of data
2019-03-31 20:50:19.448 (Zigate) Received 1 bytes of data
2019-03-31 20:50:19.448 (Zigate) Received 31 bytes of data
2019-03-31 20:50:19.449 (Zigate) ZigateRead - decoded data : 018102000f4900cc1501001200550021000200017803 lenght : 44
2019-03-31 20:50:19.450 (Zigate) ZigateRead - MsgType: 8102, MsgLength: 000f, MsgCRC: 49, Data: 00cc150100120055002100020001; RSSI: 78
2019-03-31 20:50:19.450 (Zigate) ZigateRead - MsgType 8102 - Report Individual Attribute response : 018102000f4900cc1501001200550021000200017803
2019-03-31 20:50:19.450 (Zigate) Decode8102 - Individual Attribute response : [cc15:01] ClusterID: 0012 AttributeID: 0055 Status: 00 Type: 21 Size: 0002 ClusterData: >0001<
2019-03-31 20:50:19.450 (Zigate) DeviceExist - Found in ListOfDevices with status = inDB
2019-03-31 20:50:19.450 (Zigate) Decode8102 : Attribute Report from cc15 SQN = 00 ClusterID = 0012 AttrID = 0055 Attribute Data = 0001
2019-03-31 20:50:19.450 (Zigate) Too early for a new update of LastSeen cc15
2019-03-31 20:50:19.451 (Zigate) Device : cc15 MacCapa : 80 updating SQN to 00
2019-03-31 20:50:19.451 (Zigate) updSQN - Device : cc15 updating SQN to 00
2019-03-31 20:50:19.451 (Zigate) ReadCluster - MsgData lenght is: 28 out of 24+
2019-03-31 20:50:19.451 (Zigate) DeviceExist - Found in ListOfDevices with status = inDB
2019-03-31 20:50:19.451 (Zigate) ReadCluster - 0012 NwkId: cc15 Ep: 01 AttrId: 0055 AttyType: 21 Attsize: 0002 Status: 00 AttrValue: 0001
2019-03-31 20:50:19.452 (Zigate) decodeAttribute( 21, 0001)
2019-03-31 20:50:19.452 (Zigate) ReadCluster - ClusterId=0012 - Switch Aqara: EP: 01 Value: 1
2019-03-31 20:50:19.452 (Zigate) MajDomoDevice - Device ID : 00158d00021311e6 - Device EP : 01 - Type : 0006 - Value : 1 - Hue : - Attribute_ :
2019-03-31 20:50:19.452 (Zigate) ClusterSearch - Cluster: 0006, ProfileID: , ZDeviceID: , create: False
2019-03-31 20:50:19.452 (Zigate) MajDomoDevice - Type = Switch
2019-03-31 20:50:19.452 (Zigate) MajDomoDevice - NWKID = cc15 IEEE = 00158d00021311e6 Unit = 261
2019-03-31 20:50:19.453 (Zigate) MajDomoDevice - {'0012': {}, '0006': {}, '0000': {}, 'ClusterType': {'261': 'SwitchAQ2'}}
2019-03-31 20:50:19.453 (Zigate) MajDomoDevice - We have 1 EPs with ClusterType
2019-03-31 20:50:19.453 (Zigate) MajDomoDevice - NWKID: cc15 SwitchType: 18, DeviceType: SwitchAQ2, ClusterType: Switch, old_nVal: 3 , old_sVal: 20
2019-03-31 20:50:19.453 (Zigate) UpdateDevice_v2 for : 62 Battery Level = 91 Signal Level = 120
2019-03-31 20:50:19.453 (Zigate) UpdateDevice_v2 for : 62 RSSI = 6
2019-03-31 20:50:19.453 (Zigate) UpdateDevice - ( Knop) 1:00
2019-03-31 20:50:19.453 (Zigate) Update Values 1:'00:' (Knop)
2019-03-31 20:50:19.453 (Knop) Updating device from 3:'20' to have values 1:'00'.
2019-03-31 20:50:19.619 (Zigate) Received 2 bytes of data
2019-03-31 20:50:19.619 (Zigate) Received 1 bytes of data
2019-03-31 20:50:19.620 (Zigate) Received 1 bytes of data
2019-03-31 20:50:19.621 (Zigate) ZigateRead - decoded data : 018701000355d0000003 lenght : 20
2019-03-31 20:50:19.621 (Zigate) ZigateRead - MsgType: 8701, MsgLength: 0003, MsgCRC: 55, Data: d000; RSSI: 00
2019-03-31 20:50:19.621 (Zigate) ZigateRead - MsgType 8701 - Reception Router discovery confirm : 018701000355d0000003
2019-03-31 20:50:19.621 (Zigate) Decode8701 - MsgLen = 4
2019-03-31 20:50:19.621 (Zigate) Decode8701 - Route discovery has been performed, status: 00 Nwk Status: d0
2019-03-31 20:50:19.622 (Zigate) Decode8701 - Route discovery has been performed, status: 00 - Success Nwk Status: d0 - Attempt at route discovery has failed due to any reason except lack of table space
2019-03-31 20:50:19.641 Status: dzVents: Info: Test: ------ Start internal script: Test: Device: "Knop (Zigate)", Index: 261
2019-03-31 20:50:19.641 Status: dzVents: Info: Test: 0
2019-03-31 20:50:19.641 Status: dzVents: Info: Test: ------ Finished Test
2019-03-31 20:50:24.079 (Zigate) onHeartbeat - busy = False
Posted: Sunday 31 March 2019 23:04
by ronaldbro
just a small update, the single click message after a long press does not happen always. looks like a timing issue. when I press the button for 3 seconds I get a level 20 update without a level 0 after. When I press it for 5 seconds I get a level 20 and a level 0 after.
