I have seen this question adressed before, and they say there is a solution but as far as I can see, it does not work. I have a virtual switch and I want to change the status from ESP Easy. I am using the commands
SendToHTTP x.x.x.x,8080,/json.htm?type=command¶m=udevice&idx=10&nvalue=1
and
SendToHTTP x.x.x.x,8080,/json.htm?type=command¶m=udevice&idx=10&nvalue=0
Both commands turns the switch off, so how can I turn it on?
Have tried with svalue On / Off - same problem
Best regards
Ulf
Change status on switch from ESPEasy
kimot
- Domoticz version: v3.8153
Re: Change status on switch from ESPEasy
And where did you find this command format again?
It should be:
SendToHTTP x.x.x.x,8080,/json.htm?type=command¶m=switchlight&idx=26&switchcmd=On
It 100% works.
Always read Domoticz JSON/API documentation :
https://www.domoticz.com/wiki/Domoticz_ ... Fswitch_on
It should be:
It 100% works.
RPi2 Domoticz v 4.10717
10 x Sonoff Basic - ESPeasy
1 x Wemos D1 - ESPeasy
1 x Shelly Plus Plug S
1 x Sonoff S26 - ESPeasy
1 x Shelly 1
1 x MySensors HC-SR04
1 x MySenosrs wifi gateway
1 x RFLink
4x Cam IPC-T240H
1 x Shelly 1
1 x RFLink
4x Cam IPC-T240H
ulfh2018
Thank you. Tried this before, and it did not work, but I have tested again manually, and it works, so there must be something wrong with the logic in my rules. I'll check it out tomorrow.
BTW the other syntax I found using google.
wvries
- Domoticz version: latest B
Curious: why do you not use the Device tab in the web interface of ESPEASY and enter the IDX etc in there ?
I am working with about 15 different ESP's with different setups and all running ESPEasy.... using tis method to update switches.
kimot
Curious too:
How you change switch status in Domoticz from rules using device tab?
For example indicating that temperature is below certain level or heater is heating?
1 x Shelly 1
1 x RFLink
4x Cam IPC-T240H
1 x Shelly 1
1 x RFLink
4x Cam IPC-T240H
ulfh2018
I have changed the whole project, and I'm now using Telldus sensors and RFXtrx433XL. Had a problem with wireless connections and stability at some of the rooms, but RF at 433 MHz is working perfec. I also changed and control everything from using the IDX.
When I used rules, it would look like this:
on BadNede do
TaskValueSet 2,1,%eventvalue%
if [Variables#Soverom1]>32
TaskValueSet,2,1,32
endif
timerSet,1,5
if [%eventvalue%] <= [Floor#Bad-Nede]
TaskValueSet 5,1,1
gpio 16,1
SendToHTTP 10.0.0.89,8080,/json.htm?type=command¶m=switchlight&idx=10&switchcmd=On
endif
if [%eventvalue%] > [Floor#Bad-Nede]
TaskValueSet 5,1,0
gpio 16,0
SendToHTTP 10.0.0.89,8080,/json.htm?type=command¶m=switchlight&idx=10&switchcmd=Off
endif
endon
on Soverom1 do
TaskValueSet 2,3,%eventvalue%
TaskValueSet,2,3,32 // Verdi til Soverom1
endif
TaskValueSet 2,4,([Variables#Soverom1]-[Room#Soverom-1])
timerSet,1,5
if [%eventvalue%] <= [Room#Soverom1]
TaskValueSet 1,1,1
gpio 16,1
SendToHTTP 10.0.0.89,8080,/json.htm?type=command¶m=switchlight&idx=11&switchcmd=On
endif
timerSet,1,5
if [%eventvalue%] > [Room#Soverom1]
TaskValueSet 1,1,0
gpio 16,0
SendToHTTP 10.0.0.89,8080,/json.htm?type=command¶m=switchlight&idx=11&switchcmd=Off
endif
endon
on BadNede do
TaskValueSet,2,1,32
endif
timerSet,1,5
TaskValueSet 5,1,1
gpio 16,1
endif
TaskValueSet 5,1,0
gpio 16,0
endif
endon
on Soverom1 do
endif
timerSet,1,5
TaskValueSet 1,1,1
gpio 16,1
endif
timerSet,1,5
TaskValueSet 1,1,0
gpio 16,0
endif
endon
