OK, I have this Agocontrol RPi working. It shows two dual switches, each show up as three separate devices. One seems to be main and then two actual switches. Works fine in AGO.
I'm trying to convert my setup to Domoticz. So I use the same hardware, same Aotec controller, same RPi. And one of switches shows up properly - the main and two real switches. The other one is main only, no real switches are seen by Domoticz.
Can someone suggest a remedy?
Some switches are missing - weird!
- emme
- Domoticz version: latest
Re: Some switches are missing - weird!
what kind of hardware these switches are?
"We always done this way"
Segfault
- Domoticz version: GIT
Thanks for reply!
Enerwave ZWN-RSM2 - if you do a net search you'll find it. The weird thing is the switches are identical. And they both show up and work in AGO. The last resort is to try and exclude/include the switch. Perhaps it will reset something. I really wouldn't like to reset the controller - and then start including everything all over again.
