Updating Last Seen - with no notification
pipiche
Post by pipiche »
I'm looking for a way to update a domotciz device in order to get the 'last seen' updated, without triggering any notifications ( no trigger of LUA or dzVent script)
Is there a particular way to do that ? As the Update Api from the Python Framework always trigger notification, which could be annoying.
The main issue today is if you have a door sensor, it only update its state on Domoticz when someone Open or close the door. However this sensor is communicating on a regular basic like sending battery information ... ( for instance Xiaomi is sending every 10' a status update). It would be annoying to get a notficiation every 10' while nothing really happen except that the device is alive!
Dnpwwo
Re: Updating Last Seen - with no notification
Post by Dnpwwo »
Sounds like you are really looking for a kind of 'Device.Touch' function.
I would prefer adding an extra function like that rather than continuing to overload the Device.Update function.
pipiche
Post by pipiche »
I think you found the point and agree with you. This is a kind of device heartbeat.
Is that something making sense ?
Dnpwwo
Post by Dnpwwo »
Pushed an experimental 'Device.Touch()' function to the beta channel.
Does that do what you need?
pipiche
Post by pipiche »
Thanks, I have updated the code on my end, Set clause was missing.
It is now on test
pipiche
Post by pipiche »
pipiche wrote: Thursday 07 March 2019 12:36 Thanks, I have updated the code on my end, Set clause was missing.
It is now on test
Line 1434 of PythonObjects.cpp - 'SET' was missing in the UPDATE statement
m_sql.safe_query("UPDATE DeviceStatus [b]SET [/b]LastUpdate='%s' WHERE (ID == %s )", TimeToString(NULL, TF_DateTime).c_str(), sID.c_str());
pipiche
Post by pipiche »
@Dnpwwo, I think that API is perfect and doing what it should do.
I'm just wondering to avoid to much Write I/O if a Query should be done prior to write and if the delta between the Read Last Seen, and thhe time to write is below 1 minute, then we do not write .
What do you think ?
pipiche
Post by pipiche »
@dnpwwo
It looks that there is a side effect not working as expected.
For instance the Touch() is updating the Database , but it seems that the Devices structure seems not to be updated.
SO for example, if you try to access lastupdate from dzVent script it seems not updated accordingly
domoticz.devices(name).lastUpdate
Is that possible ?
Dnpwwo
Post by Dnpwwo »
@pipiche,
I think it is better to allow plugin developers to choose how often they call Touch(). This is easy to do by comparing the current time with Device.LastUpdate and only 'Touching' if the difference is greater than x seconds/minutes. Different authors will have different needs so imposing a restriction on them unnecessarily will just cause frustration.
The main event system reads device data prior to invoking the script but I don't know anything about dzVents so can't confirm it does the same. If the database is being updated correctly then I would suggest raising a separate issue on the dzVents sub-forum for this
pipiche
Post by pipiche »
Dnpwwo wrote: Saturday 09 March 2019 1:39 @pipiche,
Make sense.
pipiche wrote: Friday 08 March 2019 22:47 It looks that there is a side effect not working as expected.
Is that possible ?
My understanding of what you try to achieve with the Touch() function is that you update the LastUpdate field in the database but don't want Lua or dzVents to react (no script Trigger).
Without such a trigger dzVents will not renew it's device information.
This is by design and changing it will take away the big performance advantage of only getting device information when really needed and then get all information for all devices, variables, groups, scenes, cameras and settings in one pass.
pipiche
Post by pipiche »
@waaren you are totally right.
