dzVents OpenURL json to LUA how to read  [Solved]
snuiter
Post by snuiter »
I am trying to get the weatherdetails from the KNMI API via
http://weerlive.nl/api/json-data-10min. ... ,5.1124231
The result from the openurl is in the following format
{ "liveweer": [{"plaats": "None", "temp": "0", "gtemp": "0", "samenv": "Gebruik een plaatsnaam of lat/lon-paar om het weerbericht op te vragen", "lv": "0", "windr": "0", "windms": "0", "winds": "0", "windk": "0", "windkmh": "0", "luchtd": "0", "ldmmhg": "0", "dauwp": "0", "zicht": "0", "verw": "0", "sup": "0", "sunder": "0", "image": "0", "d0weer": "0", "d0tmax": "0", "d0tmin": "0", "d0windk": "0", "d0windknp": "0", "d0windms": "0", "d0windkmh": "0", "d0windr": "0", "d0neerslag": "0", "d0zon": "0", "d1weer": "0", "d1tmax": "0", "d1tmin": "0", "d1windk": "0", "d1windknp": "0", "d1windms": "0", "d1windkmh": "0", "d1windr": "0", "d1neerslag": "0", "d1zon": "0", "d2weer": "0", "d2tmax": "0", "d2tmin": "0", "d2windk": "0", "d2windknp": "0", "d2windms": "0", "d2windkmh": "0", "d2windr": "0", "d2neerslag": "0", "d2zon": "0", "alarm": "0", "alarmtxt": "0"}]}
Now I am trying to retrieve the specific values from the output, I convert the JSON to a LUA table. Looking in the forum, internet and the dzVents wiki but not getting any value out of it.
Any ideas, this is the if loop in the script I am using? I have tried many formats but no luck, never any value in my output apart from the '-'
Appreciate your suggestions or hints in the right direction :D
		if (item.isHTTPResponse) then
		    if (item.statusCode == 200) and (item.isJSON) then
                          domoticz.log('JSON was detected',domoticz.LOG_FORCE)
		          print("-----------------------------")
	         	  -- print(item.data)
            	          print("-")
               	          print("-")
               	          print("-")
                          local a = domoticz.utils.fromJSON(item.data)
                          print(a)
            	          print(a[3].value)
                          print("-")
                          print(a.liveweer.plaats)
                          for i,line in ipairs(a) do
                               print(line)
                          print("-")
				-- 	domoticz.devices('testweer').updateText(someValue) 					-- update some device in Domoticz
				domoticz.log('There was a problem handling the request', domoticz.LOG_ERROR)
				domoticz.log(item, domoticz.LOG_ERROR)
Re: dzVents OpenURL json to LUA how to read
snuiter wrote: Saturday 02 March 2019 21:37 Hi, I am trying to get the weatherdetails from the KNMI API. Appreciate your suggestions or hints in the right direction :D
Have a look at this one
-- knmi.lua
            on = {   timer  =   { "every minute" },},
        logging    =    {
                            level       =  domoticz.LOG_DEBUG,
                            marker      =  "KNMI"
    execute = function(dz)
        local function logWrite(str,level)             -- Support function for shorthand debug log statements
            dz.log(tostring(str),level or dz.LOG_DEBUG)
        local testData = '{ "liveweer": [{"plaats": "None", "temp": "0", "gtemp": "0", "samenv": "Gebruik een plaatsnaam of lat/lon-paar om het weerbericht op te vragen", "lv": "0", "windr": "0", "windms": "0", "winds": "0", "windk": "0", "windkmh": "0", "luchtd": "0", "ldmmhg": "0", "dauwp": "0", "zicht": "0", "verw": "0", "sup": "0", "sunder": "0", "image": "0", "d0weer": "0", "d0tmax": "0", "d0tmin": "0", "d0windk": "0", "d0windknp": "0", "d0windms": "0", "d0windkmh": "0", "d0windr": "0", "d0neerslag": "0", "d0zon": "0", "d1weer": "0", "d1tmax": "0", "d1tmin": "0", "d1windk": "0", "d1windknp": "0", "d1windms": "0", "d1windkmh": "0", "d1windr": "0", "d1neerslag": "0", "d1zon": "0", "d2weer": "0", "d2tmax": "0", "d2tmin": "0", "d2windk": "0", "d2windknp": "0", "d2windms": "0", "d2windkmh": "0", "d2windr": "0", "d2neerslag": "0", "d2zon": "0", "alarm": "0", "alarmtxt": "0"}]}'
        local rt        = dz.utils.fromJSON(testData)        -- convert complete json to table
        local weer      = rt.liveweer[1]                     -- liveweer is a key in table (or "associative array") rt and contains one or more subtables. You want the first one
        for key, value in pairs(weer) do
            logWrite(key .. ": " .. tostring(value))
snuiter
Post by snuiter »
Thank you !! got it figured out now, and then it becomes so simple to use.... :roll:
waaren wrote: Saturday 02 March 2019 22:37 Have a look at this one
-- knmi.lua
        logging    =    {
                            marker      =  "KNMI"
pvklink
Domoticz version: latest b
Post by pvklink »
Hi @waaren, need your help again!
Wunderground has changed its ratings and i want to get rid of it. I use the temperature for managing a livingboat like a told before.
I just made an account with http://weerlive.nl/api/json-data-10min. ... =Amsterdam and i can use it every 5 minutes for free!
Do you also have a dzvents version of the lua script ?
Jablotron connection, Ikea
pvklink wrote: Saturday 09 March 2019 9:57 Hi @waaren, need your help again!
Something like this ?
local response = "KNMI_response"
    on =        {       timer           =   { "every 10 minutes" },
                        httpResponses   =   {  response } },
    logging =   {       level   =   domoticz.LOG_DEBUG,      -- change to LOG_ERROR when script runs without problems
                        marker  =   "getTemperatures" },
    execute = function(dz, item)
        local apikey        = "xxxxxxxxx"
        local latitude      = dz.settings.location.latitude   -- replace with your latitude when not yet on dzVents V2.4.14
        local longitude     = dz.settings.location.longitude  -- replace with your longitude when not yet on dzVents V2.4.14
        local currentTemp   = dz.devices(nnn)   -- define as virtual sensor type Temperature or comment this line if not needed
        local maxTemp       = dz.devices(nnn)    -- define as virtual sensor type Temperature or comment this line if not needed
        local minTemp       = dz.devices(nnn)    -- define as virtual sensor type Temperature or comment this line if not needed
        local windChill     = dz.devices(nnn)   -- define as virtual sensor type Temperature or comment this line if not needed
        if item.isHTTPResponse then
            local weer  = {}
            weer        = item.json.liveweer[1]
            logWrite("Temperaturen voor    : " .. weer.plaats    )
            logWrite("---------------------------------------------------")
            logWrite("Huidige temperatuur  : " .. weer.temp      )
            logWrite("Gevoels temperatuur  : " .. weer.gtemp     )
            logWrite("Max temperatuur      : " .. weer.d0tmax    )
            logWrite("Min temperatuur      : " .. weer.d0tmin    )
            if maxTemp       then maxTemp.updateTemperature(weer.d0tmax)    end
            if minTemp       then minTemp.updateTemperature(weer.d0tmin)    end
            if currentTemp   then currentTemp.updateTemperature(weer.temp)  end
            if windChill     then windChill.updateTemperature(weer.gtemp)   end
            local url = "http://weerlive.nl/api/json-data-10min.php?key=" .. apikey .. "&locatie=" ..
                        latitude .. "," ..
                        longitude
            dz.openURL({
                  url = url,
                        method = "GET",
                        callback = response})
pvklink
Post by pvklink »
@waaren, thank you very much!
It works GREAAATTTT
now killing my wunderground.....
pvklink
Post by pvklink »
Hi, i added value "alarmtxt" and that wend well when there is an alarm.
But for now there isn't an alarm, and in that case the variable isnt even there in the list, instead of "alarmtxt": ""
Where do i put the check if the variable alarmtxt is available?
-- { "liveweer": [{"plaats": "Amsterdam", "temp": "8.6", "gtemp": "4.3", "samenv": "Geheel bewolkt", "lv": "74", "windr": "ZW", "windms": "10", "winds": "5", "windk": "19.4", "windkmh": "36",
--"luchtd": "1008.5", "ldmmhg": "756", "dauwp": "4", "zicht": "16", "verw": "Kans op zware windstoten. Vanmiddag buien.", "sup": "07:06", "sunder": "18:36", "image": "bewolkt", "d0weer": "bewolkt",
-- "d0tmax": "9", "d0tmin": "5", "d0windk": "4", "d0windknp": "16", "d0windms": "8", "d0windkmh": "30", "d0windr": "W", "d0neerslag": "8", "d0zon": "0", "d1weer": "regen", "d1tmax": "5", "d1tmin": "5",
-- "d1windk": "3", "d1windknp": "8", "d1windms": "4", "d1windkmh": "15", "d1windr": "W", "d1neerslag": "90", "d1zon": "10", "d2weer": "regen", "d2tmax": "7", "d2tmin": "2", "d2windk": "3", "d2windknp": "10",
-- "d2windms": "5", "d2windkmh": "19", "d2windr": "W", "d2neerslag": "70", "d2zon": "30", "alarm": "1",
-- "alarmtxt": "Aan het einde van de ochtend en in de middag is er vooral bij buien kans op zware windstoten van 75-90 km/uur uit westelijke richtingen.
-- In de loop van de middag en vanavond neemt de wind van het westen uit af."}]}
-- http://weerlive.nl/api/json-data-10min.php?key=xxxxxxf&locatie=xxxxx,xxxxxx
    logging =   {       level   =   domoticz.LOG_ERROR,      -- change to LOG_ERROR when script runs without problems otherwise LOG_DEBUG
        local apikey        = "xxxxxxx"
        local currentTemp   = dz.devices('Strijp_temp')   -- define as virtual sensor type Temperature or comment this line if not needed
        local currentalarm  = dz.devices('Weeralarm')   -- define as virtual sensor type Temperature or comment this line if not needed
            local weer  = {}
            logWrite("Alarm                : " .. weer.alarmtxt  )
            if currentalarm  then currentalarm.updateText(weer.alarmtxt)    end
                        latitude .. "," ..
                        longitude
            dz.openURL({
                  url = url,
                        method = "GET",
pvklink wrote: Monday 11 March 2019 19:25 Hi, i added value "alarmtxt" and that wend well when there is an alarm.
changing line
to
if currentalarm  then currentalarm.updateText(weer.alarmtxt or "Geen alarm" )    end
should do it.
pvklink
Post by pvklink »
remarkable that you can set n or statement in a place where a value is expected!
i was trying with:
if weer.alarmtxt ~= nil then
but your solution is much better!
pvklink wrote: Monday 11 March 2019 20:26 remarkable that you can set an or statement in a place where a value is expected!
That is the way the "or" syntax works in most languages. Only if the left part of an "or" statement evaluates to false / nil; the right part is evaluated. If the left part evaluaties to anything else; the right part is ignored.
pvklink
Post by pvklink »
2019-03-11 20:50:01.643 Status: dzVents: Error (2.4.15): getTemperatures: An error occured when calling event handler DZ_weer
2019-03-11 20:50:01.643 Status: dzVents: Error (2.4.15): getTemperatures: ...i/domoticz/scripts/dzVents/generated_scripts/DZ_weer.lua:38: attempt to concatenate field 'alarmtxt' (a nil value)
i will try this :
@update: this works! and now i also have a fine message when there is no warning, so thanks again!
pvklink wrote: Monday 11 March 2019 20:53 2019-03-11 20:50:01.643 Status: dzVents: Error (2.4.15): getTemperatures: ...i/domoticz/scripts/dzVents/generated_scripts/DZ_weer.lua:38: attempt to concatenate field 'alarmtxt' (a nil value)
you can do something similar there. Try
logWrite("Alarm                : " .. (weer.alarmtxt or "Geen weeralarm actief") )
pvklink
Post by pvklink »
oh, does that or also works in that place, i will change it!
Bitterbal
Post by Bitterbal »
I started today with Domoticz so newbie question here.
I used the code from Waaren shown below, filled in my api key and saved it as .lua file in de Domoticz folder.
What I expected was an automatic update in my devices list with the weather information.
Nothing is happening. Do I need to add a dummy hardware device or something?
Still figuring out all the options of Domoticz.
Furthermore, the information I also wanted to get from the api is sun set and sun rise. How to include those?
Edit: I was looking for these parameters: https://weerlive.nl/delen.php
sun set and sun rise is added to the code using the parameters mentioned in the link.
waaren wrote: Saturday 09 March 2019 10:57 Something like this ?
            local weer  = {}
                        latitude .. "," ..
                        longitude
            dz.openURL({
                  url = url,
                        method = "GET",
Bitterbal wrote: Thursday 02 January 2020 18:22 I started today with Domoticz so newbie question here.
When not yet familiar with dzVents please start with reading Get started Before implementing (~ 5 minutes). Special attention please for "In Domoticz go to Setup > Settings > Other and in the section EventSystem make sure the checkbox 'dzVents disabled' is not checked. Also make sure that in the Security section in the settings you allow 127.0.0.1 to not need a password. dzVents uses that port to send certain commands to Domoticz. Finally make sure you have set your current location in Setup > Settings > System > Location, otherwise there is no way to determine nighttime/daytime state.
Yes you need to define dummy hardware with hardwareType: "Dummy (Does nothing, use for virtual switches only)" first and then create some virtual sensors as described in the script using the button on this hardware (on the hardware tab)
Bitterbal
Post by Bitterbal »
Thanks waaren for the link. I already set the settings you mentioned, but I made a mistake by placing the lua file in Domoticz\scripts instead of Domoticz\scripts\dzVents\scripts. I got it working now :)
jake
Post by jake »
@waaren : I managed in the past succesfully to work with a json in my dzvents script. With the next one, I don't get it to work, even after digging around on the internet for help. I assume I don't have a 100% understanding of json <> lua tables.
When I put this in the browser: http://user:[email protected]:8080/json ... :{booleans:[Player.HasAudio]},id:1}
than the response is: {"id":1,"jsonrpc":"2.0","result":{"Player.HasAudio":false}}
My code snippet is:
if (device == testButton) then
   domoticz.openURL({
      url = 'http://user:[email protected]:8080/jsonrpc?request={jsonrpc:2.0,method:XBMC.GetInfoBooleans,params:{booleans:[Player.HasAudio]},id:1}',
      method = 'GET',
      callback = 'kodiIdleTimer'
   elseif (device.isHTTPResponse and device.ok) then
      -- we know it is json but dzVents cannot detect this
      -- convert to Lua
      local json = domoticz.utils.fromJSON(device.data)
      -- json is now a Lua table
            print("The result true or false from the request is ".. json.result.Player.HasAudio)
elseif (device.isHTTPResponse and device.ok == false) then
  print("Response was not OK)
When I flip my testButton, the response in de domoticz log is:
attempt to index a nil value (field 'result')
I guess I have to do something with the Player.HasAudio, because it is on 1 level, but the 'dot' makes it look like the 'next level down'?
jake wrote: Sunday 30 August 2020 23:54 When I flip my testButton, the response in de domoticz log is: attempt to index a nil value (field 'result')
What do you see with this code snippet?
   domoticz.openURL({
      method = 'GET',
      -- convert to Lua
	 domoticz.log(device.data,domoticz.LOG_FORCE)
         domoticz.utils.dumpTable(json)
      print("The result true or false from the request is ".. json[1].result['Player.HasAudio'])
jake
Post by jake »
   domoticz.openURL({
      method = 'GET',
      -- convert to Lua
The force log learned me stuff:
2020-08-31 18:14:57.112 Status: dzVents: !Info: {"error":{"code":-32700,"message":"Parse error."},"id":null,"jsonrpc":"2.0"}
2020-08-31 18:14:57.112 Status: dzVents: > jsonrpc: 2.0
2020-08-31 18:14:57.112 Status: dzVents: > error:
2020-08-31 18:14:57.112 Status: dzVents: > code: -32700
2020-08-31 18:14:57.112 Status: dzVents: > message: Parse error.
The result showed id:"null", while in the browser it is displayed as id: 1
This triggered me to put the " " back in the url: {"jsonrpc":"2.0","method":"XBMC.GetInfoBooleans","params":{"booleans":["Player.HasAudio"]},"id":1}
This improved the results in the log:
2020-08-31 18:56:51.571 Status: dzVents: !Info: {"id":1,"jsonrpc":"2.0","result":{"Player.HasAudio":false}}
2020-08-31 18:56:51.571 Status: dzVents: > jsonrpc: 2.0
2020-08-31 18:56:51.571 Status: dzVents: > id: 1
2020-08-31 18:56:51.571 Status: dzVents: > result:
2020-08-31 18:56:51.571 Status: dzVents: > Player.HasAudio: false
2020-08-31 18:56:51.980 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2020-08-31 18:56:51.571 Error: dzVents: Error: (2.5.7) An error occurred when calling event handler kodi3
2020-08-31 18:56:51.571 Error: dzVents: Error: (2.5.7) /home/pi/domoticz/scripts/dzVents/scripts/kodi3.lua:192: attempt to index a nil value (field '?')
Line 192 is:
UPDATE: well, well, I finally got it: I first 'tried' to change line 192 to json.result['Player.HasAudio']. This gave me the clue in the log:
Error: (2.5.7) /home/pi/domoticz/scripts/dzVents/scripts/kodi3.lua:192: attempt to concatenate a boolean value (field 'Player.HasAudio
So i tried a different line of code on line 192 and finally with success:
if json.result['Player.HasAudio'] == false then print ("No audio is playing") end:
2020-08-31 19:14:54.734 Status: dzVents: No audio is playing
2020-08-31 19:14:54.734 Status: dzVents: !Info: {"id":1,"jsonrpc":"2.0","result":{"Player.HasAudio":false}}
2020-08-31 19:14:54.734 Status: dzVents: > jsonrpc: 2.0
2020-08-31 19:14:54.734 Status: dzVents: > id: 1
2020-08-31 19:14:54.734 Status: dzVents: > result:
2020-08-31 19:14:54.734 Status: dzVents: > Player.HasAudio: false
Thanks for pointing me in the right direction
Although I can now continue my script, I would like to know out of curiosity how I could still show the 'false' in a log line, instead of domoticz failing with 'attempt to concatenate a boolean value'
jake wrote: Monday 31 August 2020 18:59 Although I can now continue my script, I would like to know out of curiosity how I could still show the 'false' in a log line, instead of domoticz failing with 'attempt to concatenate a boolean value'
You can with
print("The result true or false from the request is ".. tostring(json.result['Player.HasAudio']))
or
domoticz.log("The result true or false from the request is ".. tostring(json.result['Player.HasAudio']), domoticz.LOG_FORCE)
