Raspi 3, with a Aeonlabs Zwave stick Gen5 (on a long USB cable away from other stuff)
I have around 30 z-wave devices in my house
Once every week a node dies, I get a error message like;
2019-03-02 19:05:22.959 Error: OpenZWave: Node has failed (or is not alive), Switch command not sent! (NodeID: 104, 0x68)Things I tried;
- -Reset domoticz
-heal the network
-heal the node
-push the button on the node to have it send a INF frame
-take the power on/off with the failed node
-tried the z-wave control panel trick, test & heal with the node number and a message count of 8
But since my devices are behind physical wall mounted switches, this really, really, I mean, really, sucks.
To give you an idea;
- -power down my NAS
-take out the power (main fuse box)
-open the wall mounted socket
-have the z-wave device hanging out
-put the power back on
-remove the device from the z-wave network
-add the device to the z-wave network
-turn off the power again
-boot Domoticz
-test to see if the device works
-trying to fit the z-wave device behind the switch again
-turn on the power again
-turn on my NAS
-and hope and pray I don't have to repeat this tomorrow.
