Need some help to update text device
Lebo2d9
Domoticz version: L stab
Post by Lebo2d9 »
I have a script running to check for dead devices.
Now i have created a dummy text device and I want to update the value of the text device to all me dead devices
The text device is called "deaddevices"
This is the code I have
	active = true,
        timer = {
            'every 2 minutes'
            --'at 22:00'
	execute = function(domoticz, _)
	    local message=""
	    local message2=""
        domoticz.devices().forEach(function(device)
            if (device.description ~= nil) then
                _, _, threshold = string.find(device.description,"CDA:(%d+)")
                if (threshold ~= nil) then
                    local name = device.name
                    local minutes = domoticz.devices(name).lastUpdate.minutesAgo
                    local hours= minutes/60
                    local days= hours/24
                    local rounded= (string.format("%2.1f", days))
                    if ( minutes > tonumber(threshold)) then
                            message = message .. 'Device ' ..
                            name .. ' blijkt niet meer te reageren. Geen heartbeat gezien sinds ' ..
                            rounded .. ' dagen.\r'
                            message2 = message2 ..
                            name .. '\r'
        end)
        if (message ~= "") then
                --domoticz.notify('Dead devices', message, domoticz.PRIORITY_HIGH)
                domoticz.log('Dead devices found: ' .. message, domoticz.LOG_ERROR)
                domoticz.devices(deaddevices).updateText('message2')
                --domoticz.notify('Dead devices', message2, domoticz.PRIORITY_HIGH)
I always get the following error
2019-03-02 15:32:00.544 Status: dzVents: Info: ------ Start internal script: check dead device timer:, trigger: every 2 minutes
2019-03-02 15:32:00.853 Status: dzVents: Error (2.4.6): Dead devices found: Device $Badkamer raam contact blijkt niet meer te reageren. Geen heartbeat gezien sinds 30.9 dagen.
Device $Mama groot contact blijkt niet meer te reageren. Geen heartbeat gezien sinds 31.7 dagen.
2019-03-02 15:32:00.853 Status: dzVents: Error (2.4.6): An error occured when calling event handler check dead device timer
2019-03-02 15:32:00.853 Status: dzVents: Error (2.4.6): ...ts/dzVents/generated_scripts/check dead device timer.lua:38: attempt to call field 'updateText' (a nil value)
2019-03-02 15:32:00.853 Status: dzVents: Info: ------ Finished check dead device timer
Can someone help me with the "attempt to call field 'updateText'(a nil value)?
Kind regards
Koen
Domoicz on RPI3 (wifi) directly connected 3x ds18b20 for CV temp, Evohome (9 zone), 1 remote 220V switch based on ESP-12. RFXtrx433E, 16x AMST-606, 5 Somfy RTS motors
Domoticz on RPI3(wifi) as slave for terraruim control
More to come
Re: Need some help to update text device
Lebo2d9 wrote: Saturday 02 March 2019 15:35 I have a script running to check for dead devices.
You mixed up the quotes. Change line
to
  domoticz.devices('deaddevices').updateText(message2)
Lebo2d9
Post by Lebo2d9 »
Thx Waaren,
Now it is working.
More to come
