I have set up my old Aldi IP security camera (a Maginon IPC 1a) which still works fine with Domotiz, by adding it with the following parameters:
Camera enabled: checked
Protocol: HTTP
IP address: <Camera IP address)
Port: 80
Username: <left blank>
Password: <left blank>
ImageURL: snapshot.cgi?user=USERNAME&pwd=PASSWORD
BTW I have to add username and password in the url; if I fill these in in Username and Password fields, it does not work.
So with these settings, I can click the Test button and take a snapshot. And if I save, return to the Domoticz camera list and then click on 'Stream Video', I see video. But if I click on 'Take picture' in this list, a blank screen is opened with the URL <Domoticz address:Port>/camsnapshot.jpg?idx=1. So where has the picture gone? Does the Take Snapshot button work differently from the Test button?
I also added a front door sensor to the Cam Devices list, triggering the sensor does not take a picture. According to the log file, the sensor is triggered just fine, but the camera does not show up in the log at all.
Is there some setting that I overlooking?
Aldi IP camera (Maginon PIC1a): test works, video works, but no snapshots after that...
- pgielen
- Domoticz version: 2020.2
https://robothuis.nl, RPi4B, RFXCOM XL, Aeotec Z-Stick, ESP Easy, Weatherstation, several switches and sensors, Ikea Trädfri, Philips Hue, Foscam, Reolink, Lyric T6, Ring
hoeby
- Domoticz version: V2022.1
Re: Aldi IP camera (Maginon PIC1a): test works, video works, but no snapshots after that...
please post your script, maybe we can help
i have this working with the xiaomi hacked cam and with some axis camera's. Works just fine.
also post on which kind of device you are running domoticz
- pgielen
I have no script, just added the setting in Domoticz > Settings > More Options > Cameras, where I have added an active device (Switch Frontdoor Sensor, when: On, Delay: 0). That doesn't work.
It would be ideal if I could take a photo (or a series of photos) when someone opens the door and send it (or send the link to it) as a Pushover notification to my phone. Can you tell me how to let the Aldi camera take a photo through a dzvents script?
hoeby
I don't send with pushover, but with telegram.
Here is the DZvents code i use, it works on Linux (Pi), because 'wget' and 'curl' are Linux commands.
The camera doesn't have to be configured in domoticz
What do you need to fill in:
- The device which triggers the script
- your telegram token
- your telegram chat id
- the string of the camera, for getting the camera image (the local domoReq line). The string in my example is for axis camera's, for your camera this is different.
Using pushover, you need to modify the scripts.
On the pushover website, i found this. Maybe a start to modify
The 'wget' command line stays the same, this is for getting a snapshot.
The 'curl' needs to be different, this is de command line for sending the image.
When DZvents modification doesn't work, you also can put in a .sh file and add the line in scripts on/off of your device
devices = {'Camera voordeur'},
if(device.state == 'On') then
local teleTok = 'Your telegram token'
local chatId = 'Your telegram chatID'
local snapFile = '/home/pi/domoticz/scripts/camera_'
local domoReq = 'http://XXX.XXX.XXX.XXX/jpg/1/image.jpg'
local camName = 'Voordeur'
os.execute('wget -O "'..snapFile..camName..'.jpg" "'..domoReq..'"')
os.execute('curl -s -X POST "https://api.telegram.org/bot'..teleTok..'/sendPhoto?chat_id='..chatId..'" -F photo="@'..snapFile..camName..'.jpg"')
os.execute("rm " ..snapFile..camName..'.jpg')
}Using pushover, you need to modify the scripts.
curl -s \
--form-string "token=APP_TOKEN" \
--form-string "user=USER_KEY" \
--form-string "message=here is an image attachment" \
-F "attachment=@/path/to/your/image.jpg" \
https://api.pushover.net/1/messages.jsonThin-client --> Docker Domoticz main environment
- pgielen
Thanks, I'll give this a try!
