create virtual hardware at command line
All kinds of 'OS' scripts
funky
Domoticz version: newest
Post by funky »
When I run this in the browser it works:
 http://192.168.178.33:8080/json.htm?type=createdevice&idx=9&sensorname=test_gf&sensormappedtype=0xF449
but when I run it on the command line in linux with:
curl http://192.168.178.33:8080/json.htm?type=createdevice&idx=9&sensorname=test_gf&sensormappedtype=0xF449
it gives:
   "status" : "ERR"
The strange thing is that I can make a virtual dummy at the command line with the following command:
curl http://192.168.178.33:8080/json.htm?type=command&param=addhardware&htype=15&name=presence_detection&enabled=true&datatimeout=0
whats the difference with my create device vs my add hardware wich works ..
funky
Re: create virtual hardware at command line
Post by funky »
already found the clue curl http must be within quotes
