Aeotec door / window sensor 6 (z-wave plus) - duplicate OFF ON messages
tbryel
Post by tbryel »
I've started using the following door sensor in Domoticz v4.9700 (stable) (installed on Synology NAS, Domoticz as a package by Jadahl, great job).
Doorsensor details: https://aeotec.com/z-wave-door-window-sensor
I've included the device securely as well as non-secure and have excluded, re-included as well as rebooted my Domoticz system multiple times but the messages keep coming in twice.
Domoticz duplicate logs and notifications
Is any one else experiencing the same behavior and/or using an Aeotec sensor without duplicate messages? I've seen some discussions on github but they all seem solved/closed. Therefore I thought I should raise this behavior here first.
Thank you for everyone's help.
Kind regards,
Tim
tbryel
Re: Aeotec door / window sensor 6 (z-wave plus) - duplicate OFF ON messages
Post by tbryel »
Without changing anything the logs stopped appearing twice and are now appearing once per. This is great however no clue what happened that solved this, I didn’t update Domoticz nor did I make any changes to the zwave device.
The only thing I can think of that changed is the battery charge level. Obviously it’s no longer 100%.
Nevertheless the issue solved itself and therefore this topic can be closed/resolves.
Kind regards,
Tim
