Lua script running every 5 - 10 seconds
zodracom
Domoticz version: V4.7900
Post by zodracom »
Hey Guys,
I'm new with Domoticz, and trying to make a LUA script for splitting my DHT11 temp/hum sensor.
this is the code, i found it online and changed it for my needs.
The problem is that my log-file is full of status triggers for this script. How can i add a line to it, so the value is the same, it does not update the dummy switch?
so.. when the temp or hum changes, it wil trigger the LUA script?
Thanx for the help all...
:oops:
sensorTemperature, sensorHumidity, sensorHumidityStatus = otherdevices_svalues['Schuur temp']:match("([^;]+);([^;]+);([^;]+)")
table.insert (commandArray, { ['UpdateDevice'] = string.format("%d|0|%.2f", otherdevices_idx['schuur temperatuur'], tonumber(sensorTemperature)) })
table.insert (commandArray, { ['UpdateDevice'] = string.format("%d|%d|%d", otherdevices_idx['schuur vochtigheid'], sensorHumidity, sensorHumidityStatus) })
Lebo2d9
Domoticz version: L stab
Re: Lua script running every 5 - 10 seconds
Post by Lebo2d9 »
you can add the line
if (devicechanged['MyDeviceName']) then
Domoicz on RPI3 (wifi) directly connected 3x ds18b20 for CV temp, Evohome (9 zone), 1 remote 220V switch based on ESP-12. RFXtrx433E, 16x AMST-606, 5 Somfy RTS motors
Domoticz on RPI3(wifi) as slave for terraruim control
More to come
zicht
Domoticz version: 2023.1+
Post by zicht »
see also
https://www.domoticz.com/wiki/Events
there is a lot of info on the wiki pages
